POWER SHUT OFF
WHEN I START COPYING THE UNIT AUTOMATICALY SHUT OFF AND AFTER A FEW SECOND IT IS RESTART AGAIN AND SO ON.
  • doijode Feb 19, 2009
    Hello Sirs, I have HP 290 copier, when the system is done "ON" it will show "INITIALIZING" and gets shut down and it will restart. This process will repeat for number of times. But the system will not get booted. So please guide me Sir.
    Regards,
    D.N.MADAN
  • 25 Answers
You probably have a power supply problem.
Posted on Nov 04, 2008
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
Clear memory - casio QT - 6000
Locate the battery that maintains the information on the unit. Remove the power cell, turn on the device and shut it down soon after. Restart and see if it was cleared.
Mar 17, 2014 | Casio QT 6000 Point of Sale Terminal
My Goodman model GMS90703BXA has a problem wherein after a cycle, the ventilator / discharge fan doesn't shut down properly. It stays on after the burner has shut off and after the main fan has shut off. ...
Hello, usually this happens when the pressure switch remains open, this could be due to a blocked flue pipe, water inside the tube between inducer motor and pressure switch, or the switch itself is going bad. Condensation can form and leak back to the pressure switch through the tubing and causing an intermittent problem with the inducer motor running continuously
Mar 01, 2011 | Goodman GMS90703BXA Heater
Dewalt Pressure washer keeps shutting off for no reason. plenty of gas and oil, water running to it. starts fine and as soon as I start spraying it shuts down.
Had a similar issue with my dewalt 4200 pw. Unit starting shutting off after spraying for about 5 min. Then difficult to restart, but would start again eventually only to shut down a few min later. Had new engine oil, new pump oil, good gas. I changed the spark plug and unit runs great again!
Aug 08, 2010 | Dewalt 3800 PSI Pressure Washer
Emachine wont start
remove all external and internal peripherls.
example for external: mouse, monitor, keyboard, printer.
Internal: hard drive, memory modules, video cards, modem (if there's any), optical drive or dvd drives.
just leave the motherboard, power supply and processor intact, try turning on the computer with out those components mentioned. see if you get a beep sound before it turns off, but if not the most logical part that needs to be replaced on this type of problem is the power supply if that doesn't work the next thing to do is replace the motherboard. hope that helps
hit me back on the results. thanks!
May 25, 2009 | eMachines T6211 PC Desktop
POWER SHUT DOWN
Here you can't do nothing the machine has problem with the power supply board and it need to be fixed by electronics technician
Oct 29, 2008 | Ricoh Aficio 450 Copier
Pc is not working
as computer starts hold down F8 and youll see a safe mode. use the safe mode and it might just come back, restart it....sometimes strange viruses does this but i dought in your case.it should come up in safe mode allowing you to save your files ...folders to cd record disks...then you can format and reinstall all programs.
Sep 01, 2007 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
43 people viewed this question
jasbo
jasbo
