Question about American Standard Flowise 2480.216.020 White Dual Flush Right Height Elonga
Not enough water in the toilet bowl
When the toilet is used and then flushed there is not really enough water to flush and you must wait till it is totally through running and flush again.
  • 3 more comments
  • Anonymous Dec 01, 2008
    toilet won't flush all the way...
    handles must be held down completely until flush process completes
  • tgosandygoo Jan 18, 2009
    I have the same problem. You must hold handle down. The flapper inside closes to quickly and doesn`t allow a proper full flush of tank. In-turn your bowl will not fill up because the amount of water left in the tank is significant, so the amount of water to fill tank again is limited. This causes little water to return to the bowl. I am considering change the mechanics in tank.
  • lotsaputs Jan 22, 2009
    When flushing the flapper closes to soon . Must hold handle down to complete the flush. My BK 37 has a yellow float on the chain the float seems to small to keep the flapper open for a complete flush. Adjusting the float does nothing.Would adding another float help or maybe replace the plastic flaper with a rubber flapper? HELP PLEASE JOEIII
  • easybuck May 05, 2009
    I have the same problem with a proper full flush. I have also notice durning a flush there no water from the rim holes. Any ideas about the rim holes?
  • mrcontento May 11, 2010
    cool pic
  • 3 Answers
WellI had the same problem with a client. never seen a stubborn problem like this. I was worried there was no vent on the toilet. My resolution was to get a new flapper from Moen. I replaced the existing flapper that had the yellow float. the float is designed to kepp the chain away from the flap. the existing flap had a vent hole in it. compare it to the new moen unit and you will see what im talking about. After the replacement things were better. Cheers
Posted on Jul 17, 2009
  • 36 Answers
Adjust the floating stopper in the tank to allow more water to fill the tank
Posted on Oct 29, 2008
What is a flush cylinder
It is really the valve that opens up to let water flow through the bowl when activated by the flush lever, to flush the toilet. it should prohibit water from flowing after the toilet flushes.
Aug 03, 2014 | Kohler - Toilet - One-piece - Santa Rosa -...
Can't get enough water in toilet bowl to flush the waste
Adjust your tower to let the bowl fill up more.....google your problem if you dont understand...depends on what kind of tower you have....should have teeth on the tower itself to make it fill more...try pulling up on the float...
Mar 15, 2012 | Jacuzzi Bath Perfecta EZ33 959 White round...
When I flush the tank only half empties and not enough flushing action is the result as well as the bowl does not adequately fill after the flush.
Hi, if you remove the cistern lid and flush the toilet, look at the float (back left) to see if this is rising freely when the water fills back up. Once the water has stopped filling, check the fill level lines on the large syphon in the middle of cistern. Your model of toilet has an eco flush which will be lowest line to save water, so not as much water will flush out. There is a long plastic screw on the float (back left) which you can turn to adjust the water level to the higher line on syphon (1.6 gallon flush) and turn it slowley till the water level reaches that mark. flush a couple of times to see it is filling back up to the set amount.
Jan 14, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
When flushing toilet, water spins in bowl but does not flush away. Have used plunger to no avail. However, if I pour a 3 gal bucket of water into the toilet bowl, it flushes just fine and the water level...
Alot of times this problem occurs when there is not enough water in the tank behind the seat and bowl. Lift off the tank lid and see how much water is it, It should be near full.If it is not your problem is not enough water.
Feb 21, 2010 | American Standard 2071.016 Heritage One...
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
When flushed, not enough water flow to empty sides and waste
make sure water level is sat at factory settings. there should be a black line that reads WATER LEVEL. If this is not the problem. then you have calci buildup. get a gal. of muratic acid,plunge all water out of toilet bowl. then dump in at least 1/2 gal. let set over nite. with water turned off. get up turn on water then flush. You mite have to do it twrice. hope this helps you.... duane.
Sep 28, 2009 | Kohler Barrington Pressure Lite Elongated...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
American Standard Flowise 2480.216.020 White Dual Flush Right Height Elonga Logo
5,209 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
