Question about ASUS P4S533-MX Motherboard
P4s533 mainboard i have some problem .when i have changed cpu .bios screen always appear that "you have change cpu" and warning to configure so i change jumper mode .that screen did not appear but mainboard cann't always detect HDD, pls tell me what can i do to recover that problem
  • 781 Answers
Reset BIOS back to default
1) remove M/board battery for 5 to 10 minutes
or
while booting press the DEL or F2 or ctrl+esc
or check lower part of screen during boot will tell you hoe to fet into BIOS
Once BIOS reset to default boot computer if OK.
you can change BIOS to suite CPU etc
Posted on Oct 29, 2008
System fan cannot be detected in MS 7352 V1.0
Hello here is the homepage:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3459272&prodTypeId=12454&prodSeriesId=3459270&swLang=13&taskId=135&swEnvOID=1093
The bios is set to give a warning when the system fan is not working or goes dead (in this case it probably isn't detected or has gone out). You should be able to get into your bios and look for items such as "processor fan warning: on/off" "system fan warning: on/off...etc. If you turn the system fan warning to off it will resolve the problem you are having. The fan for the cpu, must be connected to the CPU_FAN connector on the mainboard.
If the problem is still there, replace the fan, and renew the thermal paste, between the cpu and the cooling element.
Clean also the pc out for dust, with compressed air.
BE CAREFULL when you work on the mainboard, and please take antistatic precautions.
Visit also a computer repair shop, if working on the mainboard is unfamiliar to you.
Good luck
Jan 19, 2013 | Intel Computers & Internet
Bios rom checksum error
Hi, the download site for the mainboard is here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D101GGC
I think you have change the battery on the mainboard:
Its a 2032 watch type battery 3 volts.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
It could also be a fault in the ram memory or the cpu.
Aug 22, 2011 | Intel D101GGC Motherboard
Cannot boot up and brings us the
When you power up the computer press F1 or F2 or "del " key so you see bios setup screen.
then check that your harddisk is dected or not .set time and date.
Set first boot device as your harddrive.
Then save settings and exit.
Soemtimes cmos low voltage create this error so open cpu cabinet and change cmos cell .
Then check.
Let me know if you need more assistanse.
Sep 19, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Problem with my bios
the first thing i would do is check// change the battery to see if it is any good because it looks like the battery may be bad causing the system to forget the time and things like that,,,, then the next time it boots into bios look at the time and date and location ect..ect section and make any changes to it that it may need , that is why they want you to make changes to the first 4 fields when it boots into bios is to select fail safe options if you have that option and see if it will boot . if not go to default settings ok please keep me posted on this i can help you aout a lot more if needed ok best regards mike
Aug 25, 2008 | ASUS P4S533 Motherboard
Bios is always re-starting
is called ottimised defaults or load defaults.. or simply enter then save and exit or load the defaults then save and exit
if after you load the defaults and it pops up again then the mainboard battery may need replacing
Jul 20, 2008 | ASUS P4S533-X Motherboard
Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Apr 22, 2008 | Biostar P4M80-M4 Motherboard
CMOS Checksum error - Defaults loaded
When the CPU speed stored in BIOS and the actuall speed of CPU differs then this error comes.
To fix this you have to select the actuall speed of your attached CPU to the board. Just set the actuall speed and save the changes. It will fix your problem.
Thanks
Iqbal
Mar 23, 2008 | EliteGroup P6STP-FL Motherboard
Big problems
start the system hit delete or F2 to enter setup load system defaults then exit saving changes.
if it didnt work
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then exit saving changes.
Nov 16, 2007 | Acer Aspire 3000 Notebook
CPu fan turns for 1 second and then stops.
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
Apr 07, 2007 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
ASUS P4S533-MX Motherboard Logo
179 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
