THE UNIT QUICKLY SHUTDOWN WHEN SCANNING BEGUN.
DURING COPYING, WHEN I PUSH THE START BOTTON OF THE UNIT IT IS AUTOMATICALLY SHUTDOWN AND AFTER A FEW SECOND IT WILL ON AGAIN.
  • 318 Answers
Please inform me the make and model
Posted on Oct 31, 2008
Why-print-comes-all-black-all-over-paper/
Check the scanning lamp, when copying see if the scanning is not working,,it should be turn on when copying, if yes, then replace the scanning lamp, or drum unit, drum unit have certain life span or copying yield about 100 to 300 thousand copies produces. Check your counter reader in your machine. If yes, then replace drum unit, hope it help.....
Jun 15, 2014 | Kyocera Mita Office Equipment & Supplies
Lexmark x9350 will not copy or scan.
Great job on trying to do it both ways, scanning and copying. Try to refresh the printer by uplugging the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Make sure other end of the power cord is plugged in straight to the power outlet in the wall, bypass any surge device or power strips. Plugged the power adapter back in the printer after 30 seconds. It should automatically turn on. If not, press the power button. Try scanning and copying again. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the hardware problem in the printer. Hope I can assist you more on this.
Jun 29, 2010 | Lexmark X9350 All-In-One InkJet Printer
My Dell Inspiron 1525 is shutting down at it own during working. From last 4 months I having this problem. during working, laptop shutdown automatically. And after that once I'll start again, its again...
there are 2 possibilities 1. cpu fan ventilation got blocked, so use you old tooth brush to clean it 2. the system is infected with virus. so user online virus toll to clean the virus any i recommend to us this link to clean the virus. it clean virus, spy ware & malware.
www.bitdefender.com/scanner/online/free.html.
i hope it will help you.
May 07, 2010 | Dell Inspiron 1525 Notebook
How to turn off the safty
just click the start botton and win you see the icon name shutdown then click it or if not .press quickly the power botton, or simply go to run then just type a command shutdown -s
Mar 03, 2010 | Valor ITS-702W Car DVD Player
Restart at shutdown
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Nov 22, 2009 | Microsoft Windows XP Professional
The standby botton blink 7 in my sony trinitron
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
May 07, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
POWER SHUT DOWN
Here you can't do nothing the machine has problem with the power supply board and it need to be fixed by electronics technician
Oct 29, 2008 | Ricoh Aficio 450 Copier
Cuts off left hand few letters in a word
Either put the paper closer to the other side of the glass, or go into the settings to see if it is copying or scanning at 100% See if gives you the option of stretch or shrink to paper size. Also, see if it says Crop Automatically versus copying or scanning entire glass. If there is a choice between Automatic, Home Mode, or Professional Mode, try each one. There is always a reset button to return to original defaults. If you are given the option of seeing a preview first, always do that, even though it takes a little longer.
Aug 06, 2008 | Dell A960 All-In-One InkJet Printer
How do I copy a CD on my denon CDR-W1500
Operating instructios can be downloade here:
http://www.retrevo.com/s/Denon-CDR-W1500-CD-Players-review-manual/id/363ci860/t/1-2/
10 COPYING PROCEDURE
About copying
 Copying can be performed easily from the set’s CD unit onto the CD-R unit.
 There are two copying speeds (normal and high) and four copying modes.
• The mode switches as described below each time the normal speed copying button (NORMAL) or the high speed copying
button (HIGH) is pressed.
• The recording level is automatically set to the default value (0.0 dB).
• The repeat and random play modes are canceled when the copy mode is set.
• During normal speed copying you can listen to the sound as you copy.
• During high speed copying no sound is produced.
• No signals are output from the digital outputs during high speed copying.
• During copying, buttons other than the CD or CD-R stop buttons do not function.
• When CD TEXT compatible CDs are copied, the disc names and track names are also copied.
 When copying, switch the relay mode to the normal or dual mode. Copying is not possible in the relay or mix mode.
 For optimum recording, make sure there are no fingerprints, scratches or dust on the signal surface of the source side CD or
the CD-R/RW.
 The auto track function is always activated in the copying mode. It is not possible to assign track numbers manually.
Disc dubbing: In this mode, entire CDs can be copied onto CD-R/RW.
(“All Tr Dubb” is displayed.)
Make CD: In this mode, entire CDs can be copied onto CD-R/RW then finalized automatically.
(“Make CD Dubb” is displayed.)
1TR dubbing: In this mode, single tracks on CDs can be copied.
(“1Tr Dubbing” is displayed.)
Scan REC dubbing: In this mode, the desired tracks can be selected from CDs and copied.
(“Scan Rec Dub” is displayed.)
Jan 14, 2008 | Audio Players & Recorders
Mistankenly i connect config jumper on fan connecctor
Try resetting the BIOS to default,and see if it clears the error.
let me know if this works.
Thanks
Dec 12, 2007 | Intel D945GNT Motherboard
22 people viewed this question
k24674
jasbo
jasbo
