Question about Xerox Phaser 8500/DN Printer
Replace Maintenance Kit
So, I am being told to replace this kit after x pages. I don't see any problems with the print and don't really see why I should replace the kit right yet. What are the issues? Not a tightwad, just want to know the necessity.
  • 3 Answers
There are two reasons why the machine might tell you to replace the kit. The first is based on page count and if that is your case then you need to replace it. Sometimes in a printer with low use it expires by the date but will continue to work and it still has lots of use left. So you need to confirm if yours is "life over" or "expired"
Hope this helps.
Dan
Posted on Jan 13, 2009
How to reset hp laserjet m5035 maintenance kit problem
When page count approaches 200,000 pages printed, the device alerts to order a maintenance kit. The message can be temporarily cleared by using the Clear Maintenance Message item on the Resets submenu under Administration. When the page count reaches 200,000, the message can no longer be cleared and the maintenance kit must be installed. To check the number of pages that the device has printed since new maintenance-kit components were installed, print either a configuration page or a supplies-status page. The print-engine maintenance kit includes the following items:
  • Fuser
  • Rollers (transfer, feed and separation)
  • Separation pads
  • Installation instructions
Mar 02, 2011 | Office Equipment & Supplies
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Mar 24, 2010 | HP LaserJet 4345mfp Printer
I need to purchas one maintenance kit for HP 5100 laserjet printer. what contents should be there in manitenance kit. I got no authorised information about this on hp site
To ensure optimum print quality, the printer will prompt you to perform printer maintenance every 150,000 pages. When the PERFORM PRINTER MAINTENANCE message appears on the control panel, you will need to purchase a printer maintenance kit and install the new parts. To check the number of pages the printer has printed, print a configuration page.
To print a configuration page:
1 Press [Menu] until INFORMATION MENU appears.
2 Press [Item] until PRINT CONFIGURATION appears.
3 Press [Select] to print the configuration page.
To order the printer maintenance kit, contact an HP authorized service or support provider. (See the telephone support flyer included with the printer.)
The kit includes:
fuser assembly
transfer roller
feed rollers
necessary instructions
For more information on installing the printer maintenance kit, see the instructions that accompany it.
Sep 07, 2009 | HP LaserJet 5100 Printer
XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Apr 07, 2009 | Xerox Phaser 8560MFP Laser Printer
Paper is printing but top edge of paper is creased and torn
It sounds like your maintenance kit is defective.
The excess oil leads me to believe that.
Jun 04, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8560 mfp Printing issue
That really sounds like you need to replace the maintenance kit.
The white roller most likely is black and has depleted itself of lubricant a bit prematurely.
May 21, 2008 | Xerox Phaser 8560MFP Laser Printer
Print Quality - Shadowing
What does the white roll on the maintenance kit look like?
Is it really dirty? It could be either the kit, maybe the ink.
But in partiular if the kit was stood on end and not stored laying flat, the lubricant in the kit may have saturated one side and depleted on the other.
I have never seen the non Xerox ink, and have no clue if it would cause a problem like that.
I suspect a maintenance kit, that it is dry on one end.
Mar 30, 2008 | Xerox Phaser 8550DX Laser Printer
Maintanance kit replace
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Mar 30, 2008 | Xerox Phaser 8400 Laser Printer
Ricoh aficio ap410n printer, Replace Maintenance Kit
unbelievable... you guys charge for discussion??!!! get real! i'll find one of about 1,000 free places where i can discuss this and find an answer....
puleeze
Feb 28, 2008 | Ricoh Aficio AP410N Laser Printer
Hp 4300 laserjet
Does it jam at the fuser when doing a single print?
These machines have a Maintenance kit required every 200 000 prints, these MK's include all feed rollers, a transfer roller and the entire fuser assy. To replace the kit fixes all issues I've seen in these printers besides when the cartridge affects print quality.
If it is jamming at the fuser on a single print done via the printer operations panel, and your paper is fresh, it could only be the feed roller having trouble gripping the paper or the fuser not turning/stuffed.
Feed Kit, I have my doubts as to this being your problem
Maintenance Kit Fixes 98% of the time
Was is noisy before it died?
I have seen a few with stuffed fuser drive gears but not many and customers could hear it wearing.
How many prints since last MK? via keypad print a configuration page, count is there ie pages since last maintenance xxxxxx
Jan 31, 2008 | HP LaserJet 4300n Printer
Xerox Phaser  8500/DN Printer Logo
603 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
