Question about Minolta magicolor 2400W Laser Printer
Magicolor 2400w won't print on top of page, then jam
It has been working for a year. Now it doesn't print the text on the top part of the page, but it starts printing at about 2 inches from the top. So of course the bottom part is not printed, and often the page doesn't go completely out of the printer: about 2 inches stay in teh printer, and it says "paper jam".
I've cleaned it, still same problem.
Thanks for your help!
  • 210 Answers
I kept digging until I found some helpful, lucky people that stumbled across a solution. The cost of doing the repair yourself is about $1 for superglue.
I detailed the repair in my blog:!5BA5F950B86A8BE5!182.entry.
I don't know if that URL will work as a permanent link. So, just in case, the same information is on my business web site on the Tech Tips page:
I hope to have helped.
If anyone can use a custom web site, I can really use the work. I left work a couple of years ago to be a stay-at-home dad and to try to start up a web site business. Things started out okay. But the economy soured, all of my business dried up, and now I can't find full time employment.
Posted on Dec 15, 2008
Magicolor 2400w paper jam error at transfer roller
In correctly installed transfer belt. and or roller reseat both. do the internal l machine prints demo page etc. jam if not check the print properties and paper setting of the machine in the draws they must match one could be set to letterhead paper the other normal both have to match.
Feb 10, 2014 | Minolta magicolor 2400W Laser Printer
Text is printing too low on the page
I have a Magicolor 2400w and had the same problem... I hope I'm not to late because I almost put mine in the trash.
How I fixed the problem was I adjusted the solenoid behind the fan on the right side. I made a video and posted is on YouTube. Search YouTube for Magicolor 2400w paper size error. or follow the link.
Hope this helps
Dec 29, 2012 | Konica Minolta magicolor 2400 Laser...
Magicolor 2400w top margin off
I spent a while troubleshooting a similar issue on my 2400W. It turned out to be the SL2 registration solenoid, which failed to engage properly. The purpose of SL2 is to stop the page temporarily until it lines up with the image on the transfer belt. Unfortunately, SL2 is very finicky, the foam pad that stops the lever flattened too much and got sticky, so the lever wouldn't engage anymore, and the paper went straight through instead of pausing briefly when using B&W mode driver, resulting in the shifted image. In color mode, I got no image, just a "paper jam at transfer roller" error message, even though the paper came out empty without jamming. I had to adjust SL2 a few times to get it to work optimally, i.e. with minimal travel and maximal holding force. Then everything worked well again.
Jul 28, 2012 | Minolta magicolor 2400W Laser Printer
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Paper keeps jaming!
Print a test page, then when it jams, notice if the paper made it's way in to fuser (toward the back of the unit. If it got that far, your fuser may be bad.
Let me know.
Nov 22, 2008 | Minolta magicolor 2400W Laser Printer
Konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
May 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Minolta magicolor 2400W Laser Printer Logo
352 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
