I need to know where the body control module is located on my 2007 nissan armada
SOURCE: where is the body control module located on a 1997 town & country
It is located on the back side of the underdash fuse box (junction block). You remove the lower steering column cover and knee blocker reinforcement. Then remove two plugs from the bottom of the BCM.
Remove the bolts holding the junction block to dash panel mounting bracket. Remove the junction block from the bracket. Remove screws holding the BCM to the junction block. Slide the BCM downward to disengage guide studs on jb from channels on BCM mounting bracket
SOURCE: Where is the Body Control Module located?
It is located on the back side of the underdash fuse box (junction block). You remove the lower steering column cover and knee blocker reinforcement. Then remove two plugs from the bottom of the bcm.
Remove the bolts holding the junction block to dash panel mounting bracket. Remove the junction block from the bracket. Remove screws holding the bcm to the jb. Slide the bcm downward to disengage guide studs on jb from channels on bcm mounting bracket
Remove bcm from jb.
SOURCE: Body Control Module - 2000 Chevy Blazer
Not sure about a body control module, there is a pcm under the hood on the pass. side that controls most everything on these, however i would check your fuses for the seat, on the 00 models the headlights do stay on all the time while driving due to daytime running lights but if they stay on after you take the key out then id check the headlight switch or sensor on the pass side dash.
SOURCE: BODY CONTROL MODULE
the body control module is located under the center console under shifter silver box four colored plugs
SOURCE: body control module location
the location of the bcm is at the passenger side glove box area
