Question about Philips 36PT842H 36" TV
Dead Phillips 36PT842H
My television was turned on and was being watched for about 30 minutes when we went to change the channel the picture went blank. My daugher escaped out of the satellite menu and there was no picture. They tried to display the menu for satellite, still nothing. The TV was unplugged, turned back on and the light on front next to the power button blinks 5 times and is blank for a few seconds then blinks 5 times again. I switched satelitte receivers and still no picture or sound
  • 1 more comment
  • redfeather49 Feb 17, 2008
    shut tv off when trying to turn back on got nothing
  • Anonymous Jun 01, 2008
    We have the same problem. Is there a 1-800 number to call?
  • Anonymous Jul 27, 2008
    tv clicked and went blank, does have sound but no picture
    Top Expert:
  • Philips Master
  • 76,016 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Posted on Jun 03, 2017
  • 52 Answers
SOURCE: mAGNAVOX mODEL 27ms3404/17 shuts down
first place to start on this chasss is with a known failure in the horizontal circuit. there is a capacitor 2455 and 2 transistors locations 7461 and 7463 that have caused a wide variety of failures. i would recommend replacing these components before proceeding as they could be the whole of the problem.
Posted on Aug 20, 2008
Bassplyr1
  • 77 Answers
SOURCE: TV set self turn off after few seconds
It sounds like the voltage regulator in your power circuit. Also you have a capacitor that's going bad somewhere and won't hold a charge. That's why the picture is fine for a while then turns green. Unless you service TV's this one will have to be brought into the shop. Unfortunately it'll cost more than the TV is worth to get it fixed unless it's still under warranty. These days TV's that small aren't worth fixing. You're better off buying a new TV.
-An Ex-TV Repairman
Posted on Jul 12, 2009
  • 188 Answers
SOURCE: philips 21rf vardan tv
Check option code's.
Posted on Jul 29, 2009
  • 6 Answers
SOURCE: My Magnavox plasma screen tv, model number:
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Posted on Jan 03, 2010
  • 9 Answers
SOURCE: Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Posted on Jun 12, 2010
Screen started to go black while watching the tv.
yes, by canging the bulb. it proboly went out while the television was already dead. you can try but i would hire a proffesional. it may cost 100$ or more.
Oct 11, 2009 | Philips 47PFL3603D LCD TV
Black screen, good sound
Ur backlight video inverter board is dead,need a new board.
Oct 03, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Was watching TV and the picture just went black (still had sound)
eithor the flyback just craped out or the tube went
try turning up the flyback failing that call a service tech and ask for a quote
quote cose 30-50 bucks
atleast you will know forsurre if it's worth fixing
Aug 06, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Phillips 32 in. tv
bad front panel need to get new one ok sumthing loose or went out
Feb 04, 2008 | Televison & Video
Sound stays on & picture goes to blank screen
I do not see any reference on this problem and I even checked with Sony. If you are on a cable box, I suspect that is the problem.
Oct 25, 2007 | Sony KP-43T70 43" Rear Projection...
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
Phillips hd 55 inch
It could be either place probably on the back of the screen itself. If it were on the picture tubes it would be big. You'll have to take the back off and check it. Stargazer
Apr 19, 2007 | Philips 36PT842H 36" TV
Philips 36PT842H 36" TV Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
