Question about NAD T743 Receiver
Intermittent Volume Control
Suddenly, my volume control knob has become intermittent.  When I rotate the knob, the volume may change or may not change or may move in the opposite direction from my intention.  The volume control on the remote control works well.  I bought the schematic and assume that I need to change the M201 Rotary Encoder NAD part # 35-6001219-00-08.  They list it as a "ENCODER ROTARY L=20mm VER W/O CLICK". I was hoping that the schematic would give me a commercial part number so I could purchase the encoder before pulling apart the receiver.  Any idea what commercial part I can purchase to replace this component?  Is my assumption that the rotary encoder needs replacing a reasonable one?  Thank you very much.
  • 1 more comment
  • gwozdz Oct 29, 2008
    The posted solution was for generic "rotary knobs" and most were high power potentiometers. I need a very specific rotary encoder part number that matches the NAD part # 35-6001219-00-08. When I look in my Mouser Electronics catalog, they have 3 pages of rotary encoders but I don't know which one is the correct one if any are.
    The second solution offered also did not provide me with any specific information. I still don't know what to order.
    I have not resoldered the connections because it is such a chore taking the system apart. The receiver is sitting on the bottom of the stack of components and must have 20 cables running into it. I was hoping to have a new rotary encoder in hand when I take it apart so that I only have to do it once and my system will only be down for one day instead of two weeks looking for the correct part at that time. If I cannot find the correct component then I will consider your solution since it does make sense. Thank you.
  • NAD Master
  • 19,396 Answers
What you need is a rotary encoder L=20mm W/O ECB16
I did not find the part for sale.
Try first contacting NAD and see if they distribute the part.
If not have it remanufactured with same specs (click here).
Posted on Nov 02, 2008
    President:
  • 624 Answers
The rotary encoder listed in the schematic is the only one you can use to replace the original. There are no generic types for your unit. It is the cause of your problem. When they go bad, they do the exact things you have described. I used to work at an authorized NAD service center and have never found any generic types of rotary encoders. You need that exact one so that it fits properly on the board. You can try cleaning it with a contact cleaner. It has been known to help in many occasions. Spray the contact cleaner into the encoder with the power off. Try to get it inside the encoder, they are sealed pretty good, but spraying it at all angles should get some cleaner inside of the encoder. Then just turn the encoder back and forth for a couple of minutes and see if it solves your problem.
Posted on Oct 29, 2008
  • Dave DeGain
    Dave DeGain Oct 29, 2008
    According to NAD, the only way to get the part you need would be to order it from an authorized NAD service center. You can go to this webpage for NAD http://nadelectronics.com/parts-service or just call this number to find the closest NAD service center near you 1.800.263.4641
    NAD parts are not sold to anybody but authorized service centers.
    President:
  • 2,712 Answers
The best people to call in this regard would be the manufacturers themselves. They may have the required spare pare or will specify what generic model can be used instead.
  • Swilin Sampson
    Swilin Sampson Oct 29, 2008
    Here is another suggestion. If you can actually remove the present rotary encoder and take it to an electronics shop, they should be able to find the correct replacement based on size and specifications. That way you do not need to keep it disassembled for a week or two..you could get it fixed the same day :)
  • 320 Answers
Just for argument's sake, have you tried resoldering the connections on the current rotary encoder?
    Sergeant:
  • 306 Answers
Yes ofcourse u need to replace it witha new one.. there r many rotary encoders available.. for more details bout it chek out.. http://posital.de/us/products/POSITAL/AbsoluteEncoders/AbsoluteEncoders_base.html?gclid=CLyWzrfey5YCFRX5egodzFGrzQ
    President:
  • 1,952 Answers
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
Mackie 450, signal light off, Sound only comes out when amp. turned up above 75%, when usually used at 40-50%. too loud at 75% and UP, does not Work at ALL below 75%. only 2 years old, with 25 uses... i...
Doesn't sound like a fuse. They don't fix themselves when you reach 75%.
Try shaking the volume knob while in the 30-50% range and/or try (with the power off) rotating the volume knob numerous times from 0% to 100%. If when you plug it back in it responds ANY differently, you might have a bad volume potentiometer. If when you shake the knob you hear static or intermittent sound, you have a bad volume pot.
The only other thing I can think of is that the wiper of the volume pot is not in contact with the windings inside the pot until you reach the 75% mark. When the volume comes on at 75%, does it start off kind of "static" then come in loud and clear? Also try this.... adjust the volume pot to 74% (or when the sound just begins to come on). At this point shake the knob. If you hear static, replace the volume pot.
Unplugging it when still on shouldn't cause any damage... in fact it probably hasn't considering it works at 75% plus.
Mar 14, 2008 | Audio Players & Recorders
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
My Rotel RA-931 integrated has an intermittent left channel. It occasionally cuts out or loses most of its volume. The key thing is this: if I crank the volume it'll suddenly come back and be okay for a...
This could be a bad solder joint, or dirt in the volume control. Try spraying the volume control with Servisol Video 40, available from electronic shops such as Maplin, or Radio Shack.
Dec 22, 2009 | NAD C272 Amplifier
Technics SU-G95 Amplifier, Intermittent popping/crackling noise
The heat sink has the power modules attached but also has 2 power transistors that become disconnected from the circuit board when the heat sink moves or flexes. The pins on each need to be resoldered (it helps to bend them a bit too, prior to soldering). Had the same problem on the same amp today and that was the fix. There was no sound other than a clicking when the volume control was rotated.
Jun 09, 2009 | Audio Players & Recorders
Intermittent volume level
Radio Shack does provide a volume control cleaner that you could gently spray to clean the contacts, but you may simply have a defective knob. (The first S350DL I bought had a defective volume control.) Don't hesitate to call Eton Customer Service either.
I hate to say this, but I've become a little wary of buying radios at Radio Shack. I have a suspicion that occasionaly radios that are returned get "recycled" back into stock rather than sent back to the manufacturer. I had to return 2 radios directly to Eton / Grundig after getting back to back defectives at RS.
Oct 21, 2008 | Grundig S350 AM/FM/SW Radio
The rotary volume knob on my DEH 9400MP head unit has stopped working. this also happened to my friend's. the steering wheel remote still works. is this common? can it be fixed please?
Although I can't check this fix works for 1 month, a really simple explanation and fix was offered.
The rotary knob/control has 2 contacts, which when the knob is rotated c/w or anti-c/w it generates a pulse. The diagnosis is that as the remote still works, the PCB & volume circuit is fine. What is likely is that the 2 contacts/switches have become dirty or clogged.
SUGGESTED FIX: Take head unit faceplate apart to access PCB & rear of rotary control (4 screws). Spray WD40 into rear of volume control and rotate liberally to clean contacts. Dry of with lint free cloth, tissue or air dry.
I am confident this will work and the volume control will function again.
Sep 27, 2008 | Pioneer Car Audio & Video
Sound cuts out
It would seem that your volume control is spotty. A short term repair would be to spray the inside with electronic contact cleaner while rotating the volume control. Of course the best solution is to replace the component.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | Motorola GP300 Compatible 2 Way Radio...
Remote no longer works for volume control
Guys, I might have accidentally found the problem because the fix worked for me :). I have the RX-V995 and for the last 2+years or so, I had resorted to getting up and using the knob manually for volume control. System will show 'voluem up/down' in the display, but the knob didn't rotate. Same problem as yours.
I was getting ready to buy the service manual, find the knob motor which I thought was the main culprict and replace with a new one.
So I took out the top cover (just a few screws), the front face-plate (again just a few screws. The inner details were all visible. The volume knob circuit board was vertically placed. They were all covered in a good layer of dust. I got my Dyson vacuum cleaner and gently and carefully tried to **** up all the dust that had settled down. With soft front brushes, I agitated the dust I couldn't reach with dyson wand direclty, once dust were loose, dyson did a great job even with picking up those last dust pieces.
I couldn't succeed in taking apart the volume knob circuit board, as I was still awaiting for the service manual. I put all the covers back on and guess what? I used my remote and the knob was moving again. Responding very well, the knob made the full turn, when I was on the remote. It has been working perfectly for the last few days now.
I think I know what was happening. Teh top of the RX-V (and I am sure many Yamaha receivers) are very porous to allow for good heat dissipation. Over time, this allows a large amount of dust to collect on top of the parts. Most parts are electronic (not mechanical) and hence don't get affected by the dust. But the few mechanical parts might have adverse affect if dust settles down in between the rotating mechanisms.
My volume knob had stopped responding to remote command, very slowly. Initially it worked a little, missed a little, then it missed a lot and eventually it didn't rotate. That proves the theory to some extent that if the motor had completely failed, it would stop working from the get-go, not intermittently. Dust build-up provided intermittent contact between the parts and hence the response was intermittent.
The dyson vacuum did a great job in pulling out those fine dust from such parts and amazingly, things are looking very good at present. Honestly, I hadn't the slightest hope that vacuuming would fix the problem. I had vacuumed to make it easy for me to work on the parts :).
So, it doesn't hurt at all to just give it a try. Do open the covers so that you can reach closer to the real boards and parts.
Good luck and let us know!!!
cheers
PN from San Jose, CA
Apr 02, 2008 | Yamaha RX-V995 Receiver
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
NAD T743 Receiver Logo
764 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
