Question about Hoover Vacuums
Hoover upright model u5095-930 belt change
Can't find where to hook belt on to when changing..took off cover and removed roller but cannot find agitator to replace belt
    President:
  • 1,901 Answers
I couldn't find your specific model but this may be similiar to another that you have to position the new belt around the agitator (beater bar) on the bottom of the vacuum, replace the cover, and then turn the vac over and remove the TOP cover to lift the new belt up and place it on the motor shaft/pulley. The new belt may require some effort to pull it over the pulley.
Hope this helps.
Posted on Oct 29, 2008
  • John McFaull
    John McFaull Dec 14, 2013
    Thanks but I need to access the motor area , not just the belt pulley
How do you replace the beater bar belt on the hoover u 6626-900
It is not a "Beater Bar". Hoovers have brush rollers and are easy to replace. Turn the machine over and remove the 4 screws which hold the cover on, over the brush. Remove the brush roller. Slide the new roller through the small belt (self propelled models) and secure into slots (note: slots are different, match roller sides to correct slot.
Sep 20, 2011 | Hoover U6630-900 WindTunnel Bagless...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Hoover makes terrible screaching sound when using upright.
It's most likely the bushings/bearings in the beater bar (roller). The beater bar cover is fairly easy to remove -- take it off and investigate. Could be that the roller only needs lubricating on the ends. Also, check the belt to see if it's intact or damaged.
Clean area thoroughly.
If this is not the problem, please, let me know.
Charlie
Aug 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Mar 24, 2009 | Hoover WindTunnel V2 U8148-900 Upright...
Lost instructions,need to change belt
The customer operation manual can be downloaded from the hoover web site hoover.com
the bottom cover comes off with 4 screws. install the belt on the motor, then roller, stretch to install roller into cavity. replace cover.
Feb 24, 2009 | Hoover U5753-900 WindTunnel Bagless...
How to change the belt on a Hoover High Performance upright vacuum cleaner
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Most of the Hoover upright vacuums service from the bottom and to start remove the bottom plate, that should expose the belt – if this is the case, some Hoover’s might be self propelled, if not the self-propelled vacs have 2 belts and the non self propelled models have one belt – so remove the belt(s) and then lift up on the brushroll and slide the belt onto the belt pulley then take a screwdriver tool with a hook on the end and stretch the belt onto the motor shaft – once this has been done the track the belt(s) and it should straighten out and run straight, re-install the bottom plate, plug in and test. If you cannot get @ the belt from the bottom the look for 2 or 3 screws – remove the screws and the top cover will lift off and then follow the procedure mentioned above… Questions? Please feel free to contact your local vacuum dealer in your area or in the yellow pages or contact the Hoover factory for more details.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 22, 2008 | Vacuums
Hoover elite belt change model number U4245
real simple you have to articulate the belt a little sideways and the belt should slide right between the pulley and the plastic.
Hope this helps.
Feb 06, 2008 | Hoover Elite U5061-900 Bagged Upright...
Changing the belt
I'm not familiar with that model, as it is fairly new to the market, but the previous models had a plastic plate that covered the roller. There are two clips that must be depressed as you gently pull the plate away from the machine. This will allow the removal of the plate so that the roller can be removed and a new belt installed. This is a new model, so you must have the manual still. You can also check www.hoover.com for more instructions and last time I checked, they had a manual download feature available.
Oct 24, 2007 | Hoover Elite Rewind Bagless Upright...
Vacuums Logo
1,369 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
