Question about Palm Treo 650 Handheld
Contacts will not sync
Using the palm contacts, I cannot get the contacts to sync. Sync goes into a loop. I can get all other functions to sync between desktop and treo, but not contact. Am not using outlook using Windows xp, Installed Act, and really had problems, so unintalled, that is when the problem started
  • jeff ross Sep 05, 2006
    Have found that the Address area is the problem.
    I have all areas marked to do nothing, except address.
    When I sync now, the treo shuts down 15 seconds after it starts to sync with the address.
    gives error code 6410 connection lost.
    gone through all the Palm notes on 6410, and even installed FileZ, but found I do not have the expertise to use this program.
    I can sync with all other areas of the palm except my address book.
    Do not really want to re-enter all into my desktop manually.
Turned on this morning and screen shows access powered then changes to palm screen. can not get to complete start up and get into any other of the phones functions. removed battery and let set for 30 minutes. put battery back in an it keeps doing the same thing. HELP
Posted on Feb 24, 2010
I had this exact same problem did everything U discribe. I even change cables stood in the wind facing north and sacrificed a small animal (hahaha) I called Palm, they said do ahard reset. (haha) reinter 24 day of data manually into the desktop, I dont think so. Then I shut down all the conduits but calender. then I set the conduit to have the handheld over-write the desktop. PROBLEM solved!! No data loss No hard reset No re-entering data. I then folowed up with several test syncs in several conduit configs, including test data in both desktop and handheld. hope this helps.
Posted on Sep 21, 2007
SOURCE:
My T5 will not synch my calendar in Outlook
Welcome to Fixya
Double check the Palm or palmOne program in Windows. Click Start then All Programs then Palm or palmOne. You should see an icon in there called Sync with Outlook or something similar. Click that icon and the Outlook conduits will replace those for Palm Desktop. Some conduits, like Media/Photos will continue to sync with Palm Desktop, but Calendar, Contacts, Tasks, and Memos will sync to Outlook.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Aug 10, 2011 | Palm Tungsten T5 Handheld
Putting contacts on the SIM card
When I migrated from my Palm Centro (best smartphone ever) to my current BlackBerry, I did the following: 1) Export Palm contacts from the Palm Desktop software to CSV (comma separated values or tab-delimited text) format. 2) Import the CSV file to your Google Contacts account. 3) Wirelessly sync Google Contacts to your new phone using the free Google Sync app (link below). 4) Verify data was transferred appropriately.
Google Sync works with iPhones: http://www.google.com/mobile/sync/
You should be able to follow the same process for your Palm Calendar by exporting your Palm Calendar from the Palm Desktop software to a file (save the exported file to your desktop, or an easy to find location on your computer), then import the Calendar file into a NEW Google Calendar, not your primary calendar (in case there's conflicts or problems, you can delete the secondary Google calendar without losing your primary Google calendar items). Google Sync should allow you to choose more than one Google Calendar to sync with your iPhone.
Apr 25, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
Copy Contacts from Palm Centro to SIM Card
Google Sync details: http://www.google.com/mobile/sync/
You should be able to follow the same process for your Palm Calendar by exporting your Palm Calendar from the Palm Desktop software to a file (save the exported file to your desktop, or an easy to find location on your computer), then import the Calendar file into a NEW Google Calendar, not your primary calendar (in case there's conflicts or problems, you can delete the secondary Google calendar without losing your primary Google calendar items). Google Sync should allow you to choose more than one Google Calendar to sync with your new phone.
Dec 29, 2009 | Palm Treo 500 Centro
Sync Palm Pilot Contacts to Blackberry Pearl
generate a file from the palm pilot program. I think there is a application within palm pilot specifically for that purpose. Once you have generated the file move it to your blackberry manager program and sync the phone
Dec 24, 2008 | RIM BlackBerry Pearl Smartphone
Why will my Garmin not sync into my computer?
First, right click the hotsync button in the task bar and make sure "USB" is selected (assuming you're using USB...).
If that doesn't work, let me know.
Oct 06, 2007 | Garmin iQue 3600 GPS Receiver
Palm data and ActiveSync
You won't be able to do that. Lotus Organizer as well as Lotus Notes and OutHook are PIM some plus e-mail, just like Palm Desktop is a PIM. So you can have the Treo sync with Lotus Organizer AND have the Axim sync with it also it is because there are conduits buit for them. There is a middleware that allows both to talk to one. Now if you can find a piece of software out there that will sync a PocketPC with Palm Desktop, I'm sure a lot of Palm converts would love to know that.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Sync
Unfortunately, it's doing what it's supposed to do. When you change the contact in your T5, it still has the old one on your PC. When it goes to sync, it thinks they are two different contacts (because they are different), so it adds the updated one to your PC, and the old one to your T5 resulting in both the old and new being in the T5 and your PC. It is easy to fix, although aggravating. Try right clicking the HotSync Manager icon in your toolbar and for the Contacts section make the handheld overwrite the desktop. I think it goes back to "sync" after you perform the sync, but you better double check my advice :)
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
How can I hotsync both ways?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 11, 2005 | Palm Zire 31 Handheld
Palm Treo 650 Handheld Logo
100 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
