Question about Toys
4 wheeler by peg perego
The battery shows charged and noises work, but vehicle will not move at all when pedal is pushed. How can I check the pedal to see if it is bad or not
    Problem Solver:
  • 9 Answers
Its most likely bad. put the leads from a test light on the terminals of the motor and press the pedal. If the light DOES turn on, you have a bad motor, or at least bad brushes in the motor. Most likely, the light will not come on, and you should check all the wiring for loose connections or faults going from motor to the pedal switch, and from battery to switch. The switch should be a momentary contact switch, and cheap universal replacements can be found at hardware stores, auto parts stores(NAPA is your best bet), and radio shack. Bring the switch with you to the store! Also, use the test light on the wiring coming off the switch going to the motor right at the switch. If the light comes on, and the switch is good, that'll tell you that the wiring from the switch to the motor is faulty somewhere.
Posted on Oct 29, 2008
    Problem Solver:
  • 19 Answers
If you have a clicking noise but it doesn't turn, it may be a bad gearbox. You can replace the peg perego gearbox, but make sure the wires are secure on the motors. I found them at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-gearboxes-and-motors.html
They also helped me with other problems I had with the vehicle.
hope this helps
Posted on Apr 08, 2009
Peg perego 4 wheeler
is it a 12v or 6v four wheeler?
Jun 27, 2013 | Toys
The battery is charged but the car will not operate. Push on the pedal and nothing happens
check the battery with a multimeter and make sure that it is showing at least 12 volts
Aug 19, 2012 | Polaris Outlaw 12-Volt Ride-On in Pink
We have a Peg Perego John Deere Buck 4-wheeler that will no go. I thought maybe the battery was bad so I replaced it with a fully charged new one and it moved about 300 feet and then wouldn't do anything...
try jumpering the battery directly to the motors to see if the motors spin, if they don't then replace the motors as needed, if they do spin, then use a multimeter and check for 12 volts at the motor wires when the accelerator is pressed, if its showing no volts then work your way back to the shifter switch and check for volts, then to the foot pedal to find where the power isn't getting through then replace components as needed
Jul 08, 2017 | Peg Perego Toys
My son has a 700 twin sportsman peg-perego four wheeler. Weve charged thae battery . But when we hook it up the four wheeler will only go really slow as if the battery is dying or dead. Does it need a new...
check the battery with a multimeter and see if its showing 12 volts or more, if it is showing volts but not 12 or more then put it on the charger for about 8 hours, then check the battery again if it still hasn't went up check the voltage of the charger with the multimeter and make sure that the charger is putting out 13.8 volts or more, iif it isn't then you need a new charger, if it is then you need a new battery
Nov 30, 2010 | Peg Perego 12v Battery
My son had peg perego 4 wheeler electric and I had extra battery He only 1 cricle around the house and it stop even battery been charge please help
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Aug 30, 2010 | Peg Perego John Deere Gator HPX Ride on...
Thomas train shows as fully charged however when trying to use it, music starts but then a clicking noise and train doesnt move
the music is run by three aaa batteries so that will work no matter what, did you reconnect the battery to the vehicle after charging it
Jun 25, 2010 | Peg Perego IGED1084 Santa Fe Train
Peg Perego John Deere Gator not working at all
It sounds like you need a pedal switch or it has a loose connection in the wires. It is a specific Peg Perego Switch that will fit under the foot pedal. I have a gator that was doing the same thing so i replaced the shifter switches and the foot pedal switch, but I bet you could start with just the foot pedal switch.
I bought mine at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html but you could also call them as well.
Hope this helps
Dec 21, 2008 | Peg Perego 12 Volt Rechargeable Battery
Peg perego polaris 4 wheeler
If it runs only in slow speed your hi/lo speed switch is bad. Cheapest I've found is at tigerimports.com part#MEPU002 for $11.00 plus $2.00 shipping USP. Hope that helps.
Oct 18, 2008 | Toys
Toys Logo
1,215 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
