Question about Canon PIXMA iP1600 Printer
Paper jam it said that the error is paper jam, but when i check the printer if there's a paper in the printer, its already remove and its still in paper jam error..
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
Mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";}@page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;}div.Section1 {page:Section1;}--> lets tryfew troubleshooting for paper Jam issue.
locateand slowly pull out the stuck paper, perform the following steps:
1. Turn off the printer.
2. Open the printer cover.
3. Locate the stuck paper.
4. Remove the paper.
5. Close the printer cover.
6. Power the printer back on.
Locateand Remove any obstructions Inside the Printer and Input Tray
1. Open the front cover and make sure thekickstand (if there is one) is engaged.
2. Locate and remove any obstructions withinthe printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for anyobstructions.
6. Remove any visible obstructions.
7. Reinsert the paper.
Adjustthe Printer Paper Guides
Extendthe front paper support on the printer.
Try aDifferent Piece of paper in the Printer
1. Take the top 10 sheets off of the **** ofpaper.
2. Verify that the remaining sheets of theream are not wrinkled or dirty.
3. Replace the remaining part of the ****back in the printer.
Reseatthe Dell Printer Power Adapter.
If yourprinter has a momentary loss of communication with your computer, it may benecessary to reset the printer to re-establish communication. You can reset aprinter by unplugging the printer power cord from the electrical outlet andfrom the back of the printer for 10 seconds then reattaching the cord at bothends.
Try aDifferent Type of Print Media
Manyimage quality and paper feed issues are caused by the type of print media beingused.
Try adifferent type of print media that is specifically made for this printer.
Whenthere is no different print media available, take out the top half of the stackand flip it over.
Tryholding the printer upside down and shake it moderately
Make sureyou remove all the cables from printer before performing it
Checkwith manufacturer if printer is still covered under warranty...
If yesthen get it replaced.....or else get a new printer
Posted on Nov 07, 2008
SOURCE: canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Posted on Jun 16, 2008
SOURCE: PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Posted on Jul 22, 2008
frcs68
  • 1605 Answers
SOURCE: Paper Jam error
try to open the cover and reseat the ink.
the machine is trying tell you there is something stuck inside where the switch or the senser is located. usually right before the heater path. after the paper pickup roller.
Posted on Oct 15, 2008
  • 3 Answers
SOURCE: canon ip1880 continous paper jam error on screen
first you turn off your p.
Posted on Mar 26, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
My printer says that there is paper jam,i already removed the back cover to check if theres paper,but theres nothing into it..i shut it down and on it again and its also again that theres paper jam...how...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Oct 27, 2010 | Brother DCP 130C All-In-One InkJet Printer
My Canon MF4010 printer shows "paper jam" even i have already removed paper
the paper jam could have caused errors so remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 28, 2010 | Office Equipment & Supplies
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Printer says there is a paper jam and there is no paper in there.
first thing you need to do is will do the overriding the error
1. open the pritner access door fo the printer
2. if the printhead or ink cartirdges already in center remove the ink cartridges and the printhead
3. If the printhead already removed close printer access door., Turn Off the pritner then after 10sex turn It own.
4. Now your pritner should detect no printhead installed not paper Jam., If you still recieved paper jam error without the pritnhead installed you need to have a printer replacement call kodak toll free number 1 800 421 6699 ext 05
5. Now if the message is pritnhead not installed., reseat the printhead and the ink cartordges then close the pritner access door., If your ecived same message paper jam., You need to replace the printhead you may also call kodak 1 800 421 6699, and have your free printhead replacement.
Most of the time overriding the error message solve the problem
Nov 17, 2009 | Kodak ESP 5 Printer
I'm trying to replace black color cartridge, but get an error message: carrier jam How do I unjam it? Already did the unplug- check for paper jam and replug...no luck!
Remove all paper...(inspect closely for paper jammed way inside!)
also remove both ink cartriges, reinsert them one at a time carefully and properly....also double check the number code on the ink
the jam error could be either paper or cartriges confusing the printer. let me know if it works....k
Apr 19, 2009 | Dell 924 All-in-One InkJet Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
Paper jam
Usually paper jam error message on this machine is either caused by a physical paper jam or a printer error. To distinguish between the two I understand that you have already checked with the printer if there any paper or foreign object but there is none however, just to make sure you have checked everything out, check the left the side to double check. Now there is really nothing that you can see I really means that it is a printer error and that you would need to contact Epson directly to get a replacement. I do not recommend tearing off the printer because that's voids your one-year manufacturers warranty.
Jul 14, 2008 | Epson Stylus CX9400 Photo Printer
Error message "paper jam"
u need to remove the fuser and remove the paper in it, put fuser back in the reverse
Jun 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
Canon PIXMA iP1600 Printer Logo
63 people viewed this question
old marine
old marine
