Question about HP DeskJet 5550 InkJet Printer
Prints in color for test print but not for real print
My printer prints the test in color but when i print normal it only prints black ank white
    President:
  • 1,901 Answers
First thing to try is to insure that the "Print in Grayscale" box is not checked.
Click on Start>Printers and Faxes. Right click on the icon of your DJ5550 printer and select "Properties".
First make sure on the "Quality" tab, that you have not selected "Fast Draft".
Then click on the "Color" tab and see if the box is checked by "Print in Grayscale". If it is uncheck it. Problem solved. If it is not checked Comment back and let me know.
Posted on Oct 29, 2008
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
My Canon MP560 won't print black
I have problem with my canon IR 2420 DISPLAYING E000007-0000
WHAT CAN BE APROBLEM
Nov 17, 2013 | Canon MP560 All-In-One InkJet Printer
Out of magenta toner, but need to print in black
normally most printers when you select properties and advance you can select the quality of printing there you can select grayscale instead of color that will do it
steps
click start printers right click properties for pinter select advance change the settings. print a test page will come only black if not repeat steps.
Jul 26, 2010 | Xerox Phaser 7300DN Laser Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
How do I program the printer to only print in blck/white
Any default (or normally used) settings, can be made by changing the Printing Preferences for that specific printer.
1) Find the printer...ex: [Start]--> [Settings]--> [Printers and Faxes]...then [right-click] on the printer name/icon.
2) The pop-up menu that appears should list an option to select called, "Printing Preferences".
3) Under the [Paper/Quality] TAB, you can select "Black and White" (instead of the normally default, "Color").
4) Make sure to click OK, and that printer should (by default/ normal) print in B/W now.
--- you can change this to "Color" in Print Setup...but it is temporary for that printing job, and should revert to it's default state, afterwards.---
-Printing Preferences- is where any changes you make will become the Normally used setup.
.Hope this helps
Mar 10, 2010 | HP DeskJet 932c InkJet Printer
The printer won't print color only black and white
Sounds like the print head on the color side is ether plugged on its plunger or the print head failed totally the real way to do any testing is get yourself a printer cleaning kit and follow the direction on that if that does not shore it up replace the plunger and or printhead around $45-50 bucks respectivly.
Oct 08, 2009 | HP PSC 950 All-In-One InkJet Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Printer will only give me black & white documents, I need color
If you can copy in color without problem, then you have to check the print settings. On your print screen click on [Properties], then [Graphics]. Verify that color, and not grayscale is checked. Make sure to click on [Apply] before closing the window. Write me if that does not solve the issue.
Sep 30, 2008 | Samsung CLX 3160fn All-In-One Printer
Printing in black & white when color cartridge ran out
One of the possible reason why you can't print black in white because Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. More than that Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head.
Apr 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
Shades of gray printing as brown
does the black do a complete nozzle test print.if not clean several times and try nozzle test again
Dec 26, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
HP DeskJet 5550 InkJet Printer Logo
116 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
