Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Info on the rca d52w15
Where can i find a SERVICE MANUAL for d52w15 i am looking for the value resistor rw007 and cap cw008
  • 2 more comments
  • mitchel taylor
    mitchel taylor Oct 29, 2008
    no i cant it a (SOP) surface mounted part and the part is removed from the board. it in the section 0/e on the conversion board (cad -ref:10805970.1a.000
  • mitchel taylor
    My TV D52W15 chassi # ITC222
  • jason May 11, 2010
    whats the chassi # ?
    can you see the color code on the resitor?
  • 4,234 Answers
I can not supply teh schematic for contract reasons, but I can look up the parts. I will post them tomorrow.
Dan
Posted on Oct 29, 2008
  • 899 Answers
Well i can't get the schematic free
sorry i just don't have that one yet
, but there are some tips and a schematic for sale
here is the tip area , you can also ask here , just don't know how long before they get to you
but here is one of the tips for your tv http://www.freelists.org/archives/techassist/12-2005/msg00321.html
here is where you can buy your chassis schematic
http://www.electronicsrepair.net/scemes.html
Wavetek 9100 i need 10 ohm 22w and 10 ohm 21w
interesting - you can troubleshoot Fluke calibrator but cannot source 2 resistors
First you label both resistors as R10 (is this a designator or actual value on the resistor - btw if this is a value written on resistor then R10 is 0.1 Ohm which would show as short and would explain high wattage also) and probably there is nothing wrong with them.
Need more info or pictures of what you thing are faulty resistors.
Also you can find Service manual here which would help in identifying components:
http://manx.classiccmp.org/details/59,15579
Dec 28, 2013 | Measuring Tools & Sensors
HI I HAVE A RCA D52W15 BIG SCREEN AND IT HAS A BLUE IMAGE IN THE LEFT SIDE OF THE SCREEN WHAT COULD CAUSE THIS ANY INFO WOULD HELP THANK YOU
Might be to the fault to degaussing. Contact any service technician. If you wish to get more details, check the site linked here
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 09, 2013 | RCA D52W15 TV
Replaced convergence board, fixed problem, and now want spare.
The usual order of probability I have found is:
Semiconductors
Electrolytic caps
Regular caps
resistors
inductors/trnasformers
Static testing OFTEN will not reveaal the failure.
Dec 31, 2009 | RCA D52W15 TV
Rca d52w15
Most likely a bad flyback. It's a cheap part, but service people are even having a harder time getting ahold of one since they are failing often.
Apr 01, 2008 | RCA D52W15 TV
RCA CTC203
with your new flyback transformer ther should have had a resistor and cap in the kit.if you look at the fly back from the rear ,on the right side very close to the transformer.and on the other side 3 resistors one has changed value about 38k-ohm.
Mar 28, 2008 | RCA F36669 36" TV
Part numbers
wiil get back to you.
Mar 16, 2008 | RCA 32F531T 32" TV
Rca d52w15
Possible short and safety is keeping the set from burning up. A service man should be able to find the short hopefully in a small amount of time.
Nov 05, 2007 | RCA D52W15 TV
Need value for part R14109
R14109=750ohms 5% 1/4w (Resistor(750r5%.25W/R14109/179317) There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it. If you need the manual, go to http://www.samswebsite.com/photofact/pf_search.asp and type in "F31317" into the search field, you will several listings. If you decide to replace it yourself, here's some more part numbers in case you need them. Model: RCA\F25422TX41 Symptom: Dead Necessary parts: Transistor(Q14401) Main Voltage regulator Q14101 Resistor R14109 open. Research indicated the flyback transformer most probably bad \\CTC203AC4\HOT/D2578(Q14101/242224)* Flyback(14536119A/T14401/244229)* Main reg(P9NBSO/Q14101/244223) \Reg(MPS8599/Q14102/147665) Resistor(750r5%.25W/R14109/179317) Reg(MPSA06/Q14103/232218) Hope this helps you. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | RCA F31317 31" TV
Rca hd model #d52w15
That flashing means that the sweep power supply didnt start up along with the main power supply. It could be a shorted horizontal output transistor or a bad flyback transformer. Youll need a service manual to scope out the horizontal drive and see why itsnot starting up or staying on. if your not a servicer then there are no real user serviceable parts inside so contact your local AUTHORIZED servicer as they will have all the right service manuals as well as acess to all the proper parts. Not that an unauthorized shop is a bad thing its just they the unauthorized usually are not aware of troubles that rca sends there peeps. Good Luck
May 28, 2006 | RCA D52W15 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
213 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
