Question about Clarke Power Products Welding Tools
Mig welder powers up but only clicks when trigger is squeezed
Clarke 100en nogas mig welder
  • bubarge72 May 11, 2010
    Does the wire feed? If not, does it continue clicking when pulling the trigger, or does it only click once for each pull of the trigger?
  • Dave Hoitenga
    Dave Hoitenga Jan 29, 2014
    I have changed the fuse but it blew again. The wire feed has to be turned all of the way up before the wheel will turn.
  • 92 Answers
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
Posted on Jan 23, 2009
Clarke turbo weld 100en mig welder will work somtimes then it starts to hum and it wont weld
1) Unplug, take off the cover and check the inside power connections 2) Check the contact point for on/off
Oct 15, 2013 | Welding Tools
CLarke 130 en everything works Great except when I select # 4 on the heat then it won't feed when the trigger is pulled?
i put a new motor on the welder an i have 9 to 12 vote coming to the motor but the motor wont run all works but the motor
Mar 14, 2012 | Clarke Power Products Clarke 130EN...
THE WIRE CONTINUOUSLY FEEDS THROUGH THE GUN EVEN WHEN IM NOT PRESSING THE TRIGGER. IT JUST KEEPS COMING OUT
The trigger engages a relay that starts the feeder motor. Make sure your trigger is not stuck. Listen for a "click" when you squeeze it. Next, take the side cover off and look at the motor relay. If needed, remove the motor wire from the relay and try it again. My guess is the relay has arched shut. Please let me know how this works out.
Roger
Apr 03, 2011 | Clarke Power Products Welding Tools
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
Can i weld 1/4 steel with my clarke 100en
yes but it is going to take time and patience,if possible you need to grind a v groove in the two pieces your going to weld ,it is going to take several passes to fill in groove for the penatration of the weld.
Mar 25, 2010 | Welding Tools
Welder hums when you turn it on but it still welds. Sounds like a 3-phase motor with a dead leg. Ever setting is the same.
ive got a crapsman mig welder that does the same thing, i took it apart and the transformer looks to be fine, probably bad news in the long run
Apr 12, 2009 | Clarke Power Products Clarke 130EN Mig 110...
Clarke weld 85 en welds when gun trigger is not operated
hello make sure its not set on auto or the pin inside the set is not bent good luck
shaun
Mar 24, 2009 | Welding Tools
Welding Tools Logo
350 people viewed this question
Top Clarke Power Products Welding Tools Experts
 Kenneth
Kenneth
Wade Mobley
Wade Mobley
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
