Question about RCA HD52W58 52" TV
What could be wrong?
I have a 52'' big screen RCA television, under 3 years old. Here lately while turned on the t.v. will change to channel 2 and then turn off. When powered back on it will not work. We have to unplug and then plug back in. Right before the t.vv switches off it makes a hissing type sound. What could be wrong?
    Problem Solver:
  • 17 Answers
These old technology sets (rear projectors) are notorious for high voltage problems, and this is probably what you have. RCA is now, sadly, a Chinese junk brand with poor support, but your older unit may still be slightly viable, but not very. Put it into a big truck and take it to a shop. Home service may not be available, or may be nearly worthless. Better yet, get a new TV. I suggest a 1920X1080 LCD model. (Panasonic, Sharp, Sanyo, even Funai or Orion are the best choices) Forget plasma, DLP, or any of the rear projectors. These huge, ugly (and mostly empty) boxes really belong in the Smithsonian, not in your home! When you see the new LCD's, you will forget about your old boat anchor in a heartbeat.
Posted on Oct 18, 2007
My big screen tv keeps changing channels. when i set it on one channel
YOu channel changing button on the TV have pressed in, just try pressing the channel button in you tv so that it gets released..
This should solve your issue..
Please rate this solution if this solves your issue, or leave me comment ill help further
RNJ VINODKUMAR
Dec 17, 2009 | RCA P52926 52" Rear Projection Television
Hi I have a 52" RCA big screen tv that is only 3 years old however we turned it on today and it is showing some red blue and green lines and the picture is blurry
Hello clara7,
This denotes a convergence problem. I would suggest that first you enter the menu of your TV ad try to do an auto converge on your set, if this does not work I would suspect that the convergence ICs have gone bad and need to be replaced. I would suggest that you have a qualified TV repair technician replace the convergence ICs in this set.I hope this helps,Shuttle83http://www.electron-age-technologies-llc.com
Jun 08, 2009 | RCA P52939 52" Rear Projection Television
We have rca tv model 52950 need year made
I have the same television and bought it brand new late 2001 and was delivered to my home January of 2002.
May 26, 2009 | RCA P52960 52" Rear Projection Television
My RCA is a big screen 52 " is about 7 years old
yes this problem can be fixed but the price may scare you!
Sep 09, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD TV
i also have this problem rca SUCKS i had a tech look at and the power board is shot same problem as you easy fix right NOT rca changed the boards to a upgrade now i have to search for one mine is 1 year old hope this helps my guy said adout 300. if he can get the board i called rca and talked to them i ask what happens to the tv in 1 year again cause its the same board no upgrade JUNK i let you know if i get one OH YEAH RCAS ****
Jul 10, 2008 | RCA HD52W59 HDTV Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Rca big screen tv
How old is the set. im guessing from my research the set could be about 4 to 6 years old?.... this could be many things but first thing i would guess is the fluid in the tubes could be getting old..as they age the fluid grow alge and blurrs the image. also dirt and smoke tend to dirty the lens on the crt. most tv shops can change this fluid. If they do the tend to charge quit abit. our shop would charge between 250 to 400 to do this. I find this to be a rather involed repair. removeing 3 crt remove the fluid cleaning the tube and replaceing and adjusting them. so first thing is to clean the lens and the mirror
Feb 06, 2008 | RCA P52939 52" Rear Projection Television
RCA big screen TV
Replace splitter RCA #205064, Q4101, U4101, C4102, C4118, C4108
Jan 02, 2008 | RCA P52937 52" Rear Projection Television
Screen size changes
RCA hads a problem with it's sets switching back and forth on their own. This is covered under warranty. Some say first turn off the autoformat feature in Customer Menu, if this doesn't work, a board need to be replaced. I would contact Manufacturer and ask is under warranty. RCA/GE same !
Oct 06, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
RCA HD52W58 52" TV Logo
105 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
