Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Please help-question about sony optical blocks
Wondering if there is any way you could tell me if the optical blocks in some Sony TV's are the same, for example:
KDF-60xs955 and KDF-E60A20
I've got the blue blob on the 60xs955 and the blinking light on the other tv, I was wondering if I could make one good tv out of the two broken ones????
    Novelist:
  • 135 Answers
Talk to Sony about the blue blob issue, they may still replace the optical block for free.
If not, fix the blinking light TV.
Blink Codes
3X - Lamp cover not installed correctly, usually after lamp change, or cover detect switch is bad.
4X - Check fans (one or more failed to pass RPM test during power on diagnostics)
5X - Lamp ballast (power supply)
6X - Usually the thermal fuse - usually from inadequate air flow (fans dusty)
All other codes usually require a trained technician to diagnose and repair.
Posted on Nov 09, 2008
How do I replace a optical block on a Sony 64"hdmi KDS 60A2000
The optical block is usually pretty expensive. Some Sony models have a recall on this item (mine did) and it will be replaced for free. If not, here is a video that might help: http://www.youtube.com/watch?v=oP2nNPOjn_Y
Jul 10, 2013 | Televison & Video
Optical Block needs replacing
unfortunately the optical blockissue kills any resale value except for the chassis boards value for used boards. Parting it out will be your best bet as alot of people may be needing the boards.
Feb 27, 2013 | Sony KDS-60A2000 60" HDTV
I have a sony kdfe50a10 and the picture in the middle is perfect but there is all around it a yellow color. I replaced the bulb around a year ago.
Hi my name is Roety,
I can help you with your issue,
Your Sony LCD projector TV has a bad Light Engine also known as the Optic Block.
Blue blurr, yellowing, green picture and white dots all indicate a bad optic block.
The whole Optic Block needs to be replaced , the possible good news is Sony may be covering it under warranty.
Some models have a three year warranty on the Optic Block, some expire at fixed dates, regardless of when purchased.
Click on this link here to see if your model is one with the three year warranty.
A repairman would charge over $750 to repair it out of warranty, call a sony authorized repairman or try to find one using this link Click here
I hope this is good news and has helped you find a solution
If you need more assistance,please tell me your
Thanks
Dec 10, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Green tint on entire screen of Sony KDS-55A2020.
When I was reading the instructions for this tv, It was saying if the projection bulb is reaching the end of its life you will get strange color changes. You can also reset your settings in the setting section. Go to your menu and go to settings and them picture. You can reset your picture to factory settings in this menu. Now you can reset in different modes also. You have to be in these modes to set factory settings. These are Vivid, Standard and Custom. Take a look. You can go to sony and it tells you haw to do all of this. You punch in your TV type and you can go into the instructions. I learned how to change my projection lamp.
Sep 19, 2009 | Sony KDS-55A2020 55" Television
Blue splotch in bottom left quadrant of screen
yes this is the optical block call Sony your set has an extended warranty on this optical block until June 30,2010 so you can get it replaced free of charge.
Sep 08, 2009 | Sony KDF-50E2000 50" HDTV
I have a red band at topand a blue band at bottom of the screen of my 50inch Sony Bravia KDF 50E2000 rear projection TV. Cany sugestions as to how to resolve this or what is causing the problem?
Your TV has a bad optical block. Mine has the same problem. Sony has extended the warranty on the optical block till 6-30-2010. I called Sony and they offered me a newer model 52 inch flat panel LCD for $450 and told me to keep the old TV. They will also pay to have your TV repaired if desired. Here is the email I recieved from Sony:
Dear Valued Sony Customer,
Models: KDF-42E2000, KDF-46E2000, KDF-50E2000, and KDF-55E2000
US Based Customers: KF-42E200A and KF-50E200A
As part of the Sony commitment to quality, Sony is announcing that it is extending the limited warranty (parts and labor), in the United States, on the optical block of the above-referenced 2006 model Micro-Display Rear Projection televisions until June 30, 2010, regardless of purchase date. For any customer who requires repair of the optical block on one of the affected models, Sony will cover the cost of the optical block repair (parts and labor) at no charge through June 30, 2010. This extended warranty does not apply to the replaceable projection lamp or the other parts that may be used in the televisions.
Sony is also announcing that for any owner of these model televisions who paid out-of-pocket expenses on or before February 28, 2009 for an estimate or repair service to replace the optical block, Sony will reimburse the customer by mail for the cost of the optical block and the labor expense to replace it, subject to certain conditions. To receive reimbursement, please follow completely the directions on the claim form; for reimbursement all claims must be postmarked by April 15, 2009. See the claim form for complete terms and conditions.
All other terms of the Sony limited warranty continue to apply. Sony utilizes a network of hundreds of qualified independent third-party servicers to perform in-home television warranty service. Sony, through its authorized servicer network, will endeavor to repair your set within 30 days of your first contact. For diagnosis, warranty service, or if you are not provided a repair within 30 days, please contact Sony at (888) 649-7669.
Sincerely,
Sony Electronics
You received this email because our records show you registered an eligible Sony product. This is a one-time customer notice and will not impact your status with regards to other Sony emails, nor will it result in additional emails.
If you have not subscribed to Sony Style updates and would like to do so, please click here.
If you would prefer not to receive further email communications from Sony Electronics, please click here.
Or send an email to unsubscribe_sony-ctg0aib7gaab2lyq6eyzcveybhkian5q@sel.sony.com.
If you'd like to update your email address with Sony Electronics, please click here.
Sony Electronics Inc.
Personal Information Management Office
1 Sony Drive, MD 1E4
Park Ridge, NJ 07656
© 2009 Sony Electronics Inc. All rights reserved. Reproduction in whole or in part without written permission is prohibited.
Privacy Policy/Your California Privacy Rights | Legal/Trademark Dear Valued Sony Customer,
Sincerely,
Sony Electronics
Jun 06, 2009 | Sony KDF-50E2000 50" HDTV
Sony kds-60a2000 has a green tint to picture
I have had the same problem for about 6 months, and never paid much attention to it. I also noticed that when trying to change the menu color, the colors do not show up correctly.
Now it seems to be getting worse, and so I started doing some research, starting with the Sony site. That is when I found out there is an extended warranty for the KDS series (50a2000, 55a2000, 60a2000, r60xbr2, and r70xbr2) TVs because of an optical block issue, until June 30, 2010, no matter when you bought the TV.
You can see the recall here: http://esupport.sony.com/US/perl/news-item.pl?news_id=277&mdl=KDS60A2000
It seems they are extending the warranty, but not doing a recall. In other words, they aren't telling anyone, but if you happen to find the information, they will replace the optical block, if necessary. The closest I could find to the green hue issue is a purple haze on the screen.
I don't know if this is the problem, but I have scheduled an appointment to have the optical block changed. I will repost after the optical block has been changed and inform whether this is the fix to the problem.
Either way, the optical block seems to be an issue and would get it replaced whether you need it or not.
Feb 22, 2009 | Sony KDS-60A2000 60" HDTV
Sony 50we610 optical block
hi there how much you want for the optical block thanks javedahmed31@hotmail.com
May 09, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Green Smear
It sounds like your optical block has failed. If you can see the picture but it has a green smear through the picture, this is likely the problem. Sony has extended the warranty on the optical block and is covering parts and labor for the repair. Contact Sony at 800-222-SONY to schedule a tech to look at the TV and replace the optical block
Jan 01, 2008 | Sony KDS-R60XBR2 Television
Yellow spots
I have no suggestions but I am having the exact problem, yellow haze in the top right corner of the screen with a yellow line running down to the bottom of the screen. I guess we need to call tech support.
Dec 09, 2006 | Sony KDS-R50XBR1 50" HDTV
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
285 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
