Question about RCA RP3711 Clock Radio
I can't get the alarm to go off as the radio.
I have a RP3711 and when the alarm goes off, it is just a faint buzz. I can not get the radio to go off as the alarm. Thoughts?
  • 3 Answers
To turn off, hold down the mode button until the alarm/radio symbols disappear. To turn off nap, hold down nap button. Is the alarm volume controlled by the radio volume?
Posted on Jul 25, 2009
HOW DO I SHUT OFF THE ALARM FEATURE?
I had the same problem so I simply turned it from buzz to music then turned the volume to "0". The alarm goes off but I don't hear it.
Nov 09, 2014 | Audio Players & Recorders
How to set presets on nelsonic clock radio nlc 618
To set this alarm first ensure that when you press the Mode button several times the FM/AM radio does not turn on . If the FM or AM radio does turn on or the lcd displays "AU" press the Power button that is next to the Mode button 1 time (pressing the Power button toggles you between 2 settings). You should now be able to press the Mode button at least 3 times without the FM/AM Radio turning on.
Next you press and hold the Alarm 1 or Alarm 2 button and (while continuing to hold down one of the Alarm buttons) press the Hour or Min buttons to set the time of whichever alarm button you are holding down.
When you have the alarm time set you can release the Alarm 1 or Alarm 2 button and press the same button (do not hold the button down this time) to cycle between the types of alarms you can use. You will see the blue circle indicator move between Buzz and Radio when pressing the buttons (Blue circle on left side is for Alarm 1 and blue circle on right side is for Alarm 2). There is a third option as well but I'm not sure what the alarms will do if you set them to it because the blue circle indicator disappears entirely after cycling to Buzz and then Radio.
Hope that helps!
Apr 23, 2014 | Audio Players & Recorders
Dont know how to set time or alarm
Press and hold the Set Wake button and the press either the fwd or rev button until the desired Wake time is reached. Release the buttons to return to the current time display. To display the wake time, press and release the Set Wake button. To turn off the alarm, press and hold Wake Mode until the alarm icon disappears. (This button lets you choose Wake to Music, Wake to Alarm or Off.)
The owner's manual is available here: http://support.radioshack.com/support_audio/37571.htm .
I hope this helps.
Mar 11, 2011 | RCA RP3711 Clock Radio
I must have pressed the wrong button on my old but excellent Proton 320 clock radio because the radio no longer comes on at the time set on its alarm. The radio is fine when I just turn it ON; it goes...
when you set the alarm it is activating by itself ...see that you have the button that will set it to go to radio or buzzing noise..and in the back it has a knob for a separate volume on the alarm I think this is what you have lower and the alarm is not heard even if it kicks in ..
let me know if that is the issue or I should see further ..
Jan 23, 2011 | Proton R5A Clock Radio
I can't figure out how to set the alarm and make sure that it's set. The instructions with the clock radio are not clear. Also not sure how to turn off the alarm when it buzzes in the morning.....Help!!
Hello Barb,
To set the alarm hold either alarm 1 or alarm 2 buttons down. While holding down the button adjust the hour by pressing the tune+ button. The bottom left of the display there will be a light letting you know if it is pm or am. While still pressing the alarm press tun- to select the minutes. If you want to wake with radio or a buzz keepholding the alarm button down and press the am/fm/aux button. Release the alarm button when done. To select an alarm just press the alarm botton you want once, a light on the right side of the display will turn on. To unselect press the same alarm button once and the light will turn off. To turn the buzzer off in the morning select power/al off button located at the top left of the unit.
Jan 05, 2011 | GPX C389B Clock Radio
I can not find where to turn off the alarm until i reset the time.It alarms everyday
Hold down the mode button until the alarm/radio symbols disappear. (To turn of nap, hold down nap button.)
Jun 23, 2009 | RCA RP3711 Clock Radio
Missing Battery Cover
Hi, I've got a battery cover for your RP3711A . My radio died so I can part out the old one. Send me your add. I'll need a few dollars for the shipping if you want it. My email is bryan041@centurytel.net
May 29, 2009 | RCA RP3711 Clock Radio
Need free manual
just hold the mode button...it will turn the alarm off
Jul 08, 2008 | RCA RP3711 Clock Radio
Changing between the buzz and cd setting for alarm clock
From the manual (miraculously, I still have it)...
To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
SNOOZE-BOOST
To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
Sep 14, 2007 | Sharper Image SI686 Clock Radio
RCA RP3711 Clock Radio Logo
380 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
