Question about HP Photosmart C4280 Aio Printer
CANT INSTALL CD ON LAPTOP
I HAVE A LAPTOP THAT DOESNT HAVE A CD DRIVE HOW DO I INSTALL CD
    President:
  • 1,901 Answers
Here are a couple things you can do:
1) You can go to HP Support for C4280 where you need to select your operating system. On the next page you can select the software you need/want, either basic or full feature, and download it to your computer. After you download it, you can run it to install the software.
2) Have a friend copy your CD to a flash drive and then install the software from it.
Here is a link for you to download any manuals for your printer also. C4280 Manuals
Posted on Oct 29, 2008
Hi,i have notebook acer aspire 5738zg. i have problem to opein cd drive when ever i try to open its taking tomuch time and after that i cant open it what i have to do
Hi our cd drive is probably stuck try tipping the laptop differnet ways to get it unstuck if that doesnt work take the back off the laptop remove the cd drive this is quite hard on laptops and you should search google for a guide for your model. unscrew the cd drive and push the drive open and closed this should get it moving put it all back together and open ta da it works lol hope it helps
May 07, 2011 | Lifetime Acer Aspire 5738ZG Replacement...
Recently formated my laptop via a usb flash drive since my cd/dvd rom doesnt seem to work,and unfortunately the cd/dvd rom still doesnt work,doesnt appear under my computer,i ve no way of accessing data on...
Hello
Head of to the Acer website.Put in your model and serial # of your laptop. Find and download the cd or dvd drivers and install them on your laptop.
Also have you done the windows updates? Usually this will solve the problem.
Mar 25, 2011 | Acer Computers & Internet
Lost webcam driver
Download driver off net from vendor
You will need to install driver BEFORE you plug n webcam or will not work at all.
Only plug it in when told to.
Mar 29, 2010 | GE EasyCam Webcam
IBM laptop cant load XP from externall CD drive
If you have a floppy drive on it you are in luck.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;310994#XSLTH3135121122120121120120
That would be the most straightforward way to do it.
If not.
Are you able to boot off the external CD?
If so there is another way using the PE , preinstallatoin enviroment.
If not , you said you formatted it externally , which I assume means you have either a 2.5 to 3.5 IDE adapter or a USB to IDE adapter and another PC to format it with.
If you can hook the drive to another PC , you can do the install there , change some hardware settings , run the SYSPREP utility and swap the drive back into the laptop.
Mar 04, 2009 | IBM ThinkPad T23 2647 Notebook
My computer's dvd player doesnt detect the cd i ve inserted
what is your operating system. Did you install the operating system. go to the control panel then add hardware click, click next you can find your dvd , select it and install it.
Jan 21, 2009 | Computers & Internet
Acer aspire cd/dvd drive not working
Most likely if you have to use a paperclip to open the door, your drive is bad and needs to be replaced. They are pretty easy to install, directions depends on if you have a desktop or laptop Aspire.
Nov 05, 2008 | Acer (91.AB264.023) Internal 32x CD-ROM...
Cd drive/ USB/ reinstall XP
Nifty little IDE to laptop ide adapters on ebay for under $10 delivered..
remove laptop HD.. use adapter, plug into desktop as second drive.
Load up XP install to a folder.. use a decent file copier so you get hidden files. try filesync 2.xx (look for it),
Back into the laptop, try it..
Only other thing would be LEGACY USB SUPPORT in the bios and an external usb drive... Hopefully your usb problem is XP related and not hardware related..
Feb 12, 2008 | Acer Aspire 3690-2196 Notebook
Install a roxio cd into my laptop
You need a replacement CD drive most likely.
The 5300 can be swapped for almost any generic laptop optical drive. I would pick one up from directron.com or geeks.com they have new drives cheap.
Then just unscrew the plastic mounting rails attached to the side and back of the drive, swap them over to the new drive and go!
Dec 20, 2007 | Gateway Solo 5300 Notebook
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
HP Photosmart C4280 Aio Printer Logo
64 people viewed this question
Ben Johnson
