Question about Onkyo TX-DS939 Receiver
ONKYO TX-DS939 (sound and heat/fan issues)
Greetings FixYa,
First off, I own an ONKYO TX-DS939 Receiver. The first thing I noticed that was happening was it would get hot, VERY hot and the fan wasn't coming on for some reason unless I had the volume turned up FULL BLAST. As a result from it getting so hot if I would turn it off then BACK ON (right away) there would be no sound coming from the speakers besides a LOUD POPPING and CRACKLING sound. (like my speakers were blown or I was getting some feedback)
I want to stress the fact that my speakers are in MINT shape and have been tested on another system so it is NOT them. Currently my receiver will turn on and all the displays work and video feeds but if I turn on the volume at all its nothing but SNAPPLE, CRACK, POP!!!! Also, the fan doesn't work properly. It seems to me like it could be a power thing but who knows. Any help would be GREATLY appreciated as I paid a boat load of money for this back in "98.
Thank you.
Mike
Any help with this would be greatly appreciated.
Thank you.
Mike
  • 4,234 Answers
This sounds like the amp is seeing too small an impedence load. In other words, the amp is expecting to see an 8ohm load and is being presented a 4 or 2 ohm load. This will force the amp to work really hard and generate excessive heat. Does the amp generate sound at all? ever? If not, then you probable have a situation with high frequency oscuillations that you can not hear. This means that the amp is sending out a lot of power to the speakers that the crossovers are shunting to ground. Without seeing the output of the amp with a scope, I can not confirm this. This is not a problem that will be solved remotely. Bring the unit to a shop and request that the output be examined using a scope to check the waveforms. I suspect that a bad feedback look internally is causing the generation of the high frequency signals.
Keep us posted.
Dan
Posted on Oct 29, 2008
Can the speakers surround sound work if the optical out is not red?
Yes.
There are several other methods for your surround sound channels to operate without your optical connection.
Jan 01, 2011 | Onkyo TX-DS939 Receiver
Amp always entering protection mode/ on and off it self
Hello, I am sorry about your issue. I f the receiver does not stay on with nothing connected it would need to be serviced. Thank you, Onkyo USA
May 26, 2017 | Onkyo TX-DS787 Receiver
Connecting Airport Express to my Onkyo Receiver
Plug it into the cd input, with the two rca cables. We've had this set up for years. No longer use a cd player at all.
Mar 24, 2009 | Onkyo TX-SR803 Receiver
Onkyo TX-DS939
I have to ask the obvoius, did you get the manual, have you used the onscreen menu to set up the speakers, you can calibrate the speaker levels on the TV screen if you use the S video or RCA vidoe connection .have you turned off tape monitor?
Apr 27, 2008 | Onkyo TX-DS939 Receiver
Desply and sound gos off Onkyo TX-DS939
On my device there were quite a few bad solderings on power card. May be you have the same and it does not tolerate heat. Power card is that horizontal one on top, when you open the box. It is easy to remove so that you see under the card to check those solderings. One screw from left side of case, which holds that noise eliminator on AC lines, six screws from back keeping those connectors and four screws away from board corners. I disconnected only that connector in the middle of card, because it was a bit tight. Then I was able to turn that card upside down and after some fixes to those bad solderings device is like new again.
Apr 23, 2008 | Onkyo TX-DS939 Receiver
Sound cutting in and out
Same problem here....took it to authorized onkyo repair and cost was $700+ for new board. Got the 707 from crutchfield instead.
Nov 09, 2007 | Onkyo TX-DS838 Receiver
Need to buy the jumper plug
What do you mean by a jumper plug. Are you referring to the preamp jumper plugs?
Sep 01, 2007 | Onkyo TX-DS939 Receiver
Onkyo TX-DS939 Receiver Logo
722 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
