Question about Toshiba Portege S100-S1133 Notebook
Laptop display resolution vga only
S100-S1133 laptop will boot in vga mode only. can't change screen resolution.
    Problem Solver:
  • 16 Answers
Sounds like a driver issue. Check your drivers by going to: Start>Control Panel>Performance and Maintenance>System>Hardware Tab>Device Manager. Look for any yellow exclamation marks. This means the driver is bad and needs to be reloaded. Hope this helps.
Posted on Oct 29, 2008
Hi i have a portege s100-s1133, i try to install new os but the hdd cant not detected, but if i tried to boot into windows the hdd are detected. and im tried to go to bios settings because i want to change...
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Nov 17, 2010 | Toshiba Portege S100-S1133 Notebook
No screen display after resolution change
Restart your computer press F8 key from the displayed option select safe mode. After entering in to the safe mode go to device manager in my computer property, Hardware option. In that remove the display driver and restart your PC.
Sep 30, 2010 | Computers & Internet
I have an acer 5310 i booted up and the screen is black i can get a display in safe mode i have tried all the tests i can think of but i am no expert i would be thankful for any help you can give
When you power up the computer press F8 key 5 to 6 times then you can see safe mode and other menu enter in "Enable vga mode" then go to start->control panel->display->settings.
Change screen resolution to 1024*768 then apply .
But if you are not able to enter in VGA mode .
Then enter in safe mode and uninstall graphic driver then reinstall then set screen resolution to 1024*768 then apply.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 19, 2010 | Acer Computers & Internet
My s100-s1133 protege will not boot-up. The screen is full of checkard black boxes. Could this be the motherboard and if so, how much for the repair?
This is unfortunate, as that points at a display problem which in my experience with these laptops comes with very little chance of repair.
In my opinion it is caused by overheating of graphics processor due to the portege's relative small build. The fix would require dissasembly of entire laptop and re-soldering of graphics processor. This takes a technician using a microscope equipped station,( my father does this and makes over $40 an hour and I bet his company charges more. It is not cheaper than some new laptop models available today. The non-expensive fix but risky, would be to disassemble board and attempt to re-flow graphics processor connections by heating with heat gun. When I attempted this I lost entire display. My recommendation is to use external monitor if possible, which may prove futile since issue with graphics will likely be visible on that too. good luck
Apr 15, 2010 | Toshiba Portege S100-S1133 Notebook
QUESTION: Monitor says:
Reboot your computer and press the F8 key right before you see the XP loading splash screen. You should get a menu that lists things like safe mode and vga mode. Select the vga mode option and hit enter twice. This will boot windows into 640x480 resolution and will allow you to change the resolution back to 1024x768 at 60hz
Nov 23, 2009 | Computers & Internet
GX520 screen display message: cannot display this video mode
This means that the windows setting you have set can not display on your current monitor. There are two ways to fix this, one is to boot the computer in safe mode by pressing f8 after the POST screen and change the resolution and the other is to plug the computer into a different monitor to see if supports that resolution and then change the resolution in windows to a lower setting.
In case you don't know how to change the resolution in windows, follow below.
Right click on the desktop
Properties
Settings at the top
Move the slider to 1024x768
Click ok
Try rebooting. If that still doesn't work, try another resolution.
Oct 19, 2009 | Dell OptiPlex GX520 PC Desktop
My toshiba s100 display doesnt come on and it just stay on the black screen
either the backlight has burned out or the ribbon cable to the screen has come loose
www.aa1consuling.com
Jul 24, 2009 | Toshiba Portege S100-S1133 Notebook
My portege s100 cannot boot, screen full of garbled
hello
If your system is not properly booting you can try the system restore..
and if the system restore does not work please mention the error message it is showing and elaborate your problem..
Thank you
Jul 15, 2009 | Toshiba Portege S100-S1133 Notebook
Password
Toshiba will sell you one. Around $20.
Jun 06, 2009 | Toshiba Portege S100-S1133 Notebook
No display
I believe you are referring to a desktop PC.
You can press F8 repeatedly while booting to get the Boot options screen. It should contain a VGA Mode - this will boot your regular desktop with a lower resolution. Once in windows adjust the screen resolution to one that your Monitor supports.
Right click the desktop anywhere. Choose properties. Go to the right most tab "settings". Slide the screen resolution option until its where you want it. Click Apply. Do Not Hit any keys on the keyboard. Wait until it finishes changing resolution than click Ok. Close the Window.
If your screen goes black during this waiting 30 seconds should automatically revert it to the previous settings.
May 07, 2008 | Dell Inspiron 8500 Notebook
Toshiba Portege S100-S1133 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
