Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
What is F4 error on fisher paykel dishwasher?
  • 3,230 Answers
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
On our Fisher and Paykel Nautilus dishwasher, the error code was firstly F4 then after the initial cleaning it showed F8. (We hadn't cleaned the filters for ages). We put brown vinegar thru the dishwasher during a Normal cycle to eliminate the calcium build-up and it works again. We must remember to put vinegar thru it each month... to stop that build-up. Apparently the hard calcium deposits can settle on all the sensors ... and it just stops with error messages.
Posted on Dec 11, 2009
SOURCE:
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
Krazytech
  • 725 Answers
SOURCE: F4 error on fisher and
No increase in water
temperature during
wash cycle. --->
Faulty element.
Electronics controller
faulty.
Faulty temperature
sensor.
Check the heater thermistor and the wires to both...
Posted on Jun 16, 2008
A-OK
  • 10 Answers
SOURCE: error 'u1' on fisher paykel dishwasher
Water Inlet Valve!
Posted on Nov 23, 2008
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
  • 69 Answers
SOURCE: F4 error fisher & paykel nautilus dishwasher
F4 is a heating error- dishwasher has not reached temperature in allocated time. If intermittent fault, problem is usually with electronic board, which has temperature sensor attached. Sometimes the wiring to the control board burns out and can give intermittent false readings causing F4 error. Disconnect from power, remove front panel (4 screws down each side). You can now see wiring going to control board- check for burnt wires. Also check temperature sensor (small square with two purple wires) is stuck to inner door panel- if this is not stuck to inner panel, temperature sensor will not work properly. If in any doubt, call in the experts!!
Posted on Mar 09, 2010
I have a Fisher and Paykel integrated dishwasher and there is no lights working on the switch on the top drawer and when the power is turned on and off it says it has an f4 fault on the internal panel. The...
F4 implies a problem with water heater not working or temperature sensor giving wrong value. Check if the drawer is cold or too hot at the time of the error.
Sep 29, 2013 | Fisher and Paykel Dishwashers
Fisher and Paykel Dishdrawer-DS605SS F4 fault code
No temperature increase has been recorded when the element is on.
The element is not connected.
The element has gone open circuit.
Temperature sensor or electronics ADC has failed.
Oct 04, 2012 | Fisher and Paykel DishDrawer DS605FDSM...
Error F4
Hi there Shauna, F4 relates Faulty temperature sensor
or element. I hope this helps regards Gary
Nov 13, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Error message F4
Hi.
F4 on Fisher and Paykel means that there is a problem with water temperature.
F4 in Whirlpool and other dishwashers means that there is a drain problem.
Regards.
G.
Nov 03, 2010 | Dishwashers
F4 fault on fisher paykal dish drawer
F4 fault would inidicate the temperature sensor that senses the water temperature is faulty or the heating element is not working.
Looks like you will need a technician to visit and have a look.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
May 25, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Top drawer Fisher & Paykel Dishdrawer no lights lcd
Your original problem, F4, was the machine trying to tell you that the heater plate was not working. When you turned the drawer up-side down, you may have damaged the wiring harness. If you do get a technician, call a fisher paykel authorized servicer, not an independent, and make sure you tell him about the F4 problem. A new problem has been introduced by the cleaning procedure, and both issues will need to be resolved.
Dec 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F4 error on fisher and paykel double drawer dishwasher
temperature during
wash cycle. --->
Faulty element.
faulty.
Faulty temperature
sensor.
Jun 15, 2008 | Dishwashers
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
3,496 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Mark Davis
Level 1 Expert
Bruce Denton
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
