GE Zoneline AZ55H07D Air Conditioner Logo
Anonymous Posted on Oct 29, 2008
Ptec allways draines water back in to room pisspoor design
Who designs this problumatic **** anyways its all pretty much disposable
best design were older ge modles longest lifespan figure out a better way to drian
Air Distributors Company, Inc.
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 11, 2008
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
10101
Points
12
This is most likely due to the installation. The unit should have at least 1/4 inch slope towards the outside to provide for proper drainage. If it is sloped towards the inside, that's where the water will go. To check, take the unit out of the sleeve and place a level on the inside bottom of the sleeve, and check the slope. If its flat or sloping towards the inside, the sleeve will need to be removed and re-installed.
PTAC Dude
GE Zoneline Specialist
2answers
Each year when we get back from vacation the Kitchen Aid Dishwasher KUD J230YWH1 will run but the water won't drain out.
It is possible that while you are gone, debris may all float down to the drain and drain screen and settle there causing a buildup. I would check the drain and drain screen.
Apr 20, 2010 • Dishwashers
tip
How to unclog a garbage disposal
Before you tackle this problem, you should understand how to use your disposer so you'll probably never have to deal with a clog again. You can easily use put a sinkfull of waste down your disposer without a hitch. It's all about controlling the amount of water mixed in with the waste. Your disposer is designed to break waste down to pieces a little smaller than a BB. This is efficient but without much water, the pieces will clump together right where the disposer connects to the drain line, and will cause a clog. Never turn on the disposer without a full flow of cold water. Cold water not only helps to cool the motor, but keeps any fat solidified so that it doesn't build up on the walls of the pipes. The full flow of water will allow the disposer to mix the waste in and it'll go right down the drain. The second thing you must control is the amount of waste that goes in the disposer. It's really a bad idea to put more than like half a cup of waste in the disposer without it running. Ideally you'd turn on the water first, then start the disposer, then feed the waste in. Listen to the disposer running with waste in it. It sounds different when the waste inside is gone. Use this to get yourself used to keeping up with its pace. The problem with any disposer is that they work so fast, they can grind the waste faster than the water can carry it away.
Whatever you do, don't use a chemical unclogging product. Over time, this can damage the metal components of the disposer, and if you have to call a plumber, they will charge you extra because these chemicals make their equipment wear prematurely and can burn the skin.
If water doesn't drain, make sure the problem isn't fixed by simply turning the disposal on. If the water just swirls around, you'll probably need a plunger. When you want to use a plunger to unclog your disposal, the easiest way is to use suction more than pressure. When you push down on the plunger, the pressure from it will cause the backed-up waste to compress even further and make it impossible to push water down. You want to push the plunger down so that it "leaks" water out, and, when the plunger can be pushed down no farther, make sure it then has a good seal on the disposal's opening, and yank the plunger up pretty hard. This will pull the backed up waste back, mixing it with the water and will probably unclog the unit in only a couple strokes. Be careful not to soak yourself when pulling up on the plunger. In a pinch, a full soda can will actually form a seal and can be used in place of a plunger for disposals that have a splash guard made of one piece. If water is backed up into the other sink bowl, that means the clog is in the trap and not in the disposer itself. One way to fix this is to make sure the other bowl(s) of the sink are firmly stopped up. If you use a stopper you'll most likely have to push down hard on the stopper while plunging the disposer to form a good seal. If none of this helps, you may need to take apart the sink trap. This can be done by loosening the two nuts on the part of the drain pipe assembly shaped like a "U". You then may be able to clean the clog directly out of the u-bend or you may need to snake the pipes. If you take the pipes apart, have a bucket under there to catch the large amount of that will gush out.
on Dec 07, 2009 • Plumbing
I replaced a disposal and now when I run the washer cycle the used water shoots out the drain that is on top of the sink. It didn't shoot out that drain while the old disposal was working and the dishes...
The new disposer has a plug inside the dishwasher nipple that you must knock out. The dishwasher hose nipple is plugged so water won't leak out if you don't have a dishwasher connected. You must take a flathead screwdrivers and knock out the plug inside the nipple with a hammer or something. Make sure you don't leave the plug inside! The air gap is designed to prevent water from siphoning back into the dishwasher. With the disposal's drain connection blocked, the water exits through the air gap!
1helpful
2answers
Our freezer leaks water on the floor. Looks like
I had the same problem, and the solution is that the drain valve was plugged. On my unit, I removed the lower back panel and started cleaning. It was filthy, and I don't think it had been cleaned for 8 years or so. Anyway, there is a drain hose that releases into a flat pan. The pan is really long and weaves its way through the all the other components under the fridge. It is designed to increase surface area and allow the defrosted water to evaporate. Anyway, the drain hose into that pan was plugged. I just removed it from the point of connection to the drain and blew into it (from upstream) and that dislodged the dirt plugging it up. My system allowed relatively easy access, but I would guess some designs might be pretty tricky. Also, make sure you have some towels standing by because when you remove the drain hose, all the backed up water will come streaming out. This was a surprisingly easy job, and only took about 30 minutes total. The main work was vacuuming all the dirt. The lesson learned is that this should be done every few months. Also, a lot of the insulation around the components had pretty much disintegrated, so that was more clean up, and I imagine there might be some issues now with efficiency and maybe hot or uneven spots in the fridge itself.
2helpful
Bottom of fridge collects water
Hello there:
I have written a few steps for you to follow and try ok?
  1. Manufacturers have different ways to dispose of the water created during automatic defrost cycles. The most common design routes the water down a rubber tube on the back of the fridge to a tray beneath. This tube often gets plugged with breadcrumbs, peas etc. and can generally easily be removed and cleaned.
  2. Make sure the end of the hose is sitting in the defrost tray.
  3. If your hose was not plugged and you have found water running down the back wall inside the fridge or a pool under the bottom crisper has formed. Check if there is a small funnel located on the back wall near the top inside the fridge. It can also get plugged; you can use a small wire and work it in and out of the hole.
  4. Some designs do run the water down the back wall and have a drain hole under the crisper, make sure it is not plugged.
I hope that this has been verry helpfull for you
best regards michael
1helpful
Water tank fills up every 3hrs
The amount of water that is getting extracted from the air in the room is based on how humid the air is. The good news is your unit is really getting quite a bit of moisture out of the air and as such, is working well to cool your room.
It is working as designed. You may want to see if you can connect a hose to a drain port (if yours has that included) to let the unit room longer without the need to drain the condensate (water) every 3 or so hours.
Hope this helps and best regards!
2helpful
3answers
Water still in the bottom of the dishwasher
If there is no air gap (silver cap) located on your sink next to your faucet, you could have a clog in the drain line or at the drain port at the motor/pump assembly. Also, check to see if the drain hose (under sink) has a loop in it before it goes to the disposal or pipe. If there is no loop, water could be backing up into the tub.
1helpful
3answers
Installation
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Top GE Heating & Cooling Experts
vince
Alfredo Texmenistan
Level 1 Expert
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
