17" monitor has power running into it but when you press the power button, speakers crackle but no image on monitor & power LED goes off
  • 1 more comment
  • desjw Oct 29, 2008
    Yes
    Tried it on three computers with 2 different leads. Sorry, forgot to mention I'm a pc consultant, but totally lost when it comes to repairing monitors
  • Jeff Strader
    Jeff Strader May 11, 2010
    is the data cable connected from the moniter to the computer?
  • 796 Answers
See if the signal coming to the monitor is active...
you can check this be disconnecting the rs232 cable from monitor to cpu..
when u disconnect it.it will display the no signal icon on the monitor...else there is some problem with your monitor...
Posted on Oct 29, 2008
HP vs17 (PK657AA) problem: the image is displayed for 3 seconds
first try entering VGA mode in the startup menu. u can get the startup menu by pressing the F8 key immediately after the POST screen. if the screen stabilizes try changing the resolution to 1024 by 768 which should work in normal mode. if that doesnt work then the monitors internal bulbs may be burnt. an electrician may fix this problem for you.
Nov 18, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Just bought HDMI to DVI cable to connect my VL193 to my HP laptop - unable to get the monitor to "pick up" the signal - just a blank screen - if I power it on & off, just goes right to power...
Hi
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I hope this helps.
Aug 24, 2011 | Princeton Digital VL193 19 in. Flat Panel...
Lg e700sh monitor out of shape i need the settings of original shape
try factory settings
- Press Power to turn screen off
- Press and hold Select/Auto
- Press Power to turn screen on. LED will be Orange instead of Green
- Release Select/Auto
- Press Menu
- You will see 2 additional options (Factory 1 & Factory 2)
- Exit as normal
- To return LED to Green, Power off then Power on
To reset colour:
- Choose Factory 2
- Choose Auto Color1
Jun 14, 2011 | LG Flatron F700B 17" CRT Monitor
My Samsung SyncMaster 740N occasionally turns itself off. Timing varies and the condition varies. Usually the screen just goes black - from seconds to hours after it is turned on - the blue LED remains...
This could be because of the 'eco' friendliness of the monitor. Basically a lot of monitors are designed to turn off into a low power state when not in use so to preserve power and life of the monitor. I would return the monitor as the sensors that control this seem to be broken in your monitor.
Mar 15, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
Image is off center bottom is cut off so I cannot see commands
This page is for ACER products. Select the DISPLAY, the choose the correct model for your monitor. There select Guides and Manuals. When you get the PDF file open, look for ADJUSTING DISPLAY SETTINGS. (page 6)
This is what was one one product's manual. This is similar to what my HP monitor uses. Hope this helps.
User Controls
A brief description and the location of all LCD Monitor function controls and indicators:
Figure 2-1
Stereo Speakers
PC Audio Stereo output.
Speaker Volume Control
Increase Volume - Turn the knob clock wise.
Decrease Volume - Turn the knob counter clock wise.
DC Power Switch
Press the power switch to switch the monitor ON/OFF.
DC Power-On Indicator
LED lights Green color --- Power is ON.
LED lights Yellow --- Monitor is in "Power Saving Mode".
LED is off --- Power is OFF.
5
Function Select Buttons
Press either left or right control button for OSD (On Screen Display) menu selection.
6
Adjustment Control Buttons
Press the left button to decrease the OSD setting and press the right button to increase the OSD setting.
7
External Headphone Jack
The monitor speakers will be disabled when using an external headphone or external speakers.
Good luck
Feb 18, 2010 | Acer Computers & Internet
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor Continually Goes Blank
You are right in assuming it to be the monitor.
It is the inverter circuit that powers the backlights inside the LCD.
No backllight, no view. If you shine a bright light into the screen you will see it is still working, just not visible.
The Viewsonic range of monitors have a habit after several years use developing bad capacitors that need to be replaced. It's something that happens to most LCD's and alot of other electronics.. so not a design flaw, just age.
If you have modest electrical knowledge then its an easy job, If not then take it to your local TV repairman and have them do it. It should not cost alot to have it done. The main expense in this case is the labour.
Call a few shops in the area and get rough quotes to have it done. You will be surprised how much the cost can vary for the same simple job.
Apr 21, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
