Question about Singer 3116 Simple
How to re-insert bobbin shuttle
The needle jammed down in the fabric and I could not raise the needle using the wheel. I removed the bobbin case and saw that thread was jammed. In order to reach it, I had to remove the outer ring thing and the shuttle. I cleared the jam and the needle moves up and down. But now I can't figure out how to re-insert the shuttle and outer ring thing. Please help!!
  • 3 more comments
  • mmtc6 Nov 13, 2008
    same as the original poster. i had a thread jam and took apart the front ring and shuttle and now don't know how to get it back in.
  • sewgirls Nov 15, 2008
    my thread keeps knotting up under the material also, jamming my machine. The three bobbin pieces are a test of luck to get back together. I've managed to twice, after about 30 minutes, but am not sure how I did it. I can't seem to get it together this time.
  • 1948dawn Dec 05, 2008
    Unable to watch DVD as it starts and ends before it gets ti the instructuctions. Also I would like to have a manual to refer too. So far the machine is just sitting on our table. Simple? I,m beginning to think we made a mistake. Ellen, Ma
  • Anonymous Dec 18, 2008
    inserting the bobbin shuttle correctly
  • Julch Jul 13, 2013
    this worked for me:http://au.answers.yahoo.com/question/ind...
  • 4 Answers
Maybe one of the parts diagrams at the Singer site would help? or us the contact there?
Posted on Nov 30, 2008
This worked for me: http://au.answers.yahoo.com/question/index?qid=20091110224043AAD9X1x
Posted on Jul 13, 2013
2 Suggested Answers
  • 1788 Answers
SOURCE: the needle jammed down in
I solved it myself this way. This is not hard, in fact you can go to www.singerco.com and download your manual for free, then go to page, 82, and enlarge( 200%) the diagram, you then can see your parts really easy. Just take a deep breath and relax, you can do this. Let me know if this helps. I know it is so frustrating when that little thing does not want to cooperate. Good luck. You can also call Singer customer service at 1-800-4singer
Posted on Oct 12, 2010
How to remove sewing bed where fabric lays when sewing to get to bobbin area of Brother LS - 2020 sewing machine
http://download.brother.com/welcome/doch000256/l30ls17172020ug03enfrpoes.pdf
Lower bobbin threading Brother
  1. Turn the power switch to "o".
  2. Raise the needle to its highest position by turning the balance wheel towards you (anti-clockwise) and raise the presser foot lever.
  3. Open the shuttle cover behind the extension table on the the front of the machine and remove the bobbin case by pulling its latch towards you and pulling it out of the shuttle race. (fig A).
  4. Unwind about 10cm (4") of the thread from a full bobbin and insert it into the bobbin case. (see fig B-1). Pull the trailing thread into the slot then down and to the left, as shown in fig B-2, until it enters the delivery eye under the tension spring (fig B-3).
  5. Holding the bobbin case by the latch, fully insert the bobbin case into the shuttle race and release the latch. Make sure the bobbin case finger fits into the notch at the top of the race as shown in fig C.
Sep 13, 2016 | Brother Sewing Machines
My needle is jammed in a down position. What do I need to do to get it to move and to get my fabric out?
You have a "birds nest" of thread in the bobbin case. work the flywheel back and fourth until you get the needle to raise. Then you will need to cut bobbin thread under fabric before you can remove fabric.
Oct 03, 2014 | Sewing Machines
Singer futura quartetis stuck in zig zag stitch. How do I get it out?
1.Switch off your machine and raise the presser feet up.
2.Raise the needle by turning the hand wheel towards you.
3.Carefully using your ripper or embroidery scissor to cut off the threads underneath the fabric(you may have to loose that part of your fabric if its too much entangled)
4.If the threads are still stuck in the bobbin case, use your GS screw driver to open the screws holding the throat/needle plate. Be very careful not to scratch the bobbin case when getting the threads out.
5.Once the entangled threads cleared, install back your bobbin case to be nicely seated on the grove of the rotary hook, then fix back the throat/needle plate. Before putting back the bobbin, turn hand wheel to bring needle up and down to ensure no jam. If OK you may proceed your sewing.
Nov 08, 2013 | Sewing Machines
The needle is stuck in the Shark 612C model sewing machine, any solutions?
Try http://www.fixsewingmachine. com I also suggest that you clean bobbin case. Now, when needle is "stuck", this requires patience and care in "jiggling" the hand wheel to and fro until needle point begins to clear the jammed area. Carefully snip one thread that moves up under needle and jiggle hand wheel by carefully turning hand wheel toward you to see if you can move the take-up lever all the way up to the UP position. Look at bobbin case area and remove bobbin. Cut bobbin thread and remove bobbin case. Sweep gently with brush underneath case and carefully, gently sweep over the feed dogs, poking very ends of brush bristles into "teeth" area to remove lint, fuzz ball/s, and any loose thread/s. Raise presser foot, remove (possibly bent) needle. Insert new needle of appropriate size for fabric weight. Make sure needle pushed all the way up into needle bar groove, at side to back. Keep presser foot RAISED while rethreading. This allows thread to locate tension discs, and HOLD THREAD TAUT. Replace bobbin, making sure thread is EVENLY distributed on it. Imablanced bobbins cause jams, and bobbins with burrs and scratches can real havoc as well as the hook part of the shuttle where the bobbin fits. Smooth such areas with emery cloth carefully, ever so gently. Hope my suggestions are a solution for you. Jimmy
Apr 06, 2012 | Euro-Pro Shark 60 - 384
The needle jammed down in the fabric and I could not raise the needle using the wheel. I removed the bobbin case and saw that thread was jammed. In order to reach it, I had to remove the outer ring thing...
Oct 12, 2010 | Singer 3116 Simple
Bobbin trouble
Remove the needle plate for better access and try using a seam ripper to gently cut the threads and continue to remove with the tweezers.
The needle plate is the metal plate under the presser foot and is held into place with at least two screws.
The bobbin fits into the bobbin case.
The bobbin case fits into the bobbin shuttle.
Once you get the jam cleaned away, raise the needle to it's highest position and remove the bobbin case and/or replace the bobbin case.
Jamming can cause the machine to be out of time.
If you thead the machine with the presser foot up, have the bobbin inserted into the bobbin case correctly and the stiching is loose and loopy the machine may need to go into the shop for service.
May 01, 2010 | PfaFF Hobby 4260
Brother innovis 700e jammed can i take the case off
It would not be a good idea to take a computerized machine apart.
Turn off the power. Remove the needle and presser foot.
If the hoop is still attached, remove the inner hoop to release the fabric and then remove the outer hoop.
Lift up the fabric and use a seam ripper or narrow-blade craft knife to cut the threads.
Take the fabric away.
Open the needle plate and remove the bobbin and bobbin case.
Clean the shuttle and surrounding area from any accumulation of lint or thread from the jam.
Change to a new needle.
Try a different, simple design to see if the machine is working correctly before going back to the design you were using when the machine jammed.
If this continues, the machine may need to go into the shop as jamming can cause the timing to be off.
Mar 01, 2010 | Brother Sewing Machines
Corect threading needle for sewing on brother lx3125
please follow the instruction
1. raise needle to its hieghest position
2. remove hand hole cover plate
3. remove bobbin case from shuttle, pull open latch of bobbin case
4. pull bobbin case straight out of shuttle
5 insert bobbin into bobbin case making sure thread is coming from bobbin.
6. pull thread through slot
7. pull thread under tension spring
8. holding latch open position case into shuttle, and release latch. case should lock into place when latch is released
happy sewing.
regards please rated me.. thanks
Mar 31, 2009 | Brother Sewing Machines
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Fabric not feeding and jamming occurs
When this happens it is because the thread tension was not right so it gets stuck under the bobbin case and the feed dogs. Use a bigger lint brush and take out the bobbin casing and clean out the shuttle. When you rethread pull slightly on the thread before you feed it through the needle. This will make sure the thread is properly in the tension discs.
Jun 13, 2006 | Kenmore 19233 Computerized Sewing Machine
Singer 3116 Simple Logo
1,794 people viewed this question
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
