Question about Passport 8500 Radar Detector
Does not turn on
When inserted in cig lighter escort does not turn on in several cars. Cig lighter works for other electrical gadgets. Could it be chord or unit itself?
  • 1 more comment
  • rexou Oct 29, 2008
    I opened the smart chord and there is no fuse in it.
  • mmeissner Dec 29, 2008
    A few months of flawless operation and then unit just stopped working. Yes, no fuse in power cord. Pathetic design flaw.
  • spikemeister Feb 14, 2009
    I had the same problem after a couple of years, it just quit working and wouldn't turn on.
    What gives? Do these always fry?
  • 102 Answers
This might sound crazy but have you turned the volume button up? It is also power on button
Posted on Dec 04, 2008
  • 905 Answers
See if the fuse is blown in the plug of the cord , just unscrew the end that goes into the lighter socket
it will have a fuse in it
Posted on Oct 29, 2008
  • jason Oct 29, 2008
    the cord wires could be broke or
    then the power circut needs repair and checked for other bad components
    electech
    and if there is no fuse then there should be
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Toyota Corolla seca1998 radio/cig not working, replaced fuse for cig and it has worked but for no more than a minute or 2, keeps blowing. Assuming it's something to do with a shortage between the cig fuse...
hi there. ok what I advise is to simply disconnect the cig lighter, then replace fuse and turn on stereo. this will tell you which is causing the problem. if fuse blows its the stereo if fuse is good then its the cig lighter. you may have had a child etc put coins in the slot thinking it a slot machine...ive been there before but sadly it was only pennies....they rattle around in the stereo and hit electrical parts. also look into the cig lighter hole and see if a coin or similar stuck down there bridging the sides with the bottom... simply use your finger to check this and not a screwdriver to short it again.
hope this helps you.
May 01, 2014 | Cars & Trucks
Cig lighter, radio, clock, side mirrors, dont work which fuse is it
in my 2005 corolla, what if i replaced the fuses in "dome" (under hood), "p/point and "cig" and it still is not fixed?
Apr 27, 2012 | 2005 Toyota Corolla 1.8
The front lighter is not functioning (no electricity in). The fuse for the lighter is OK, so the problem must be somewhere else. Please, let me know what could be wrong. Thank you! J. Picman...
some cars need key on to turn on cig lighter but if thats not the case, ive also seen circut breakers for cig lighters on back of cig lighter socket so check that also.
Jan 24, 2011 | 2007 Saturn Outlook
I need to know where the fuse is for the power outlet / cig lighter on a 2003 ford escort zx2
Hi!!
That fuse is usually located in the fuse panel under dash, driver's side. Remove the cover and look inside, you'll find a lay out of the fuses position, name and amps. Look for the fuse that says CIG. LIGHTER.
Good Luck!! Don't forget to rate this post!!
Sep 22, 2010 | Ford Escort Cars & Trucks
Hi,i'm having trouble with the cig lighter on my car, it keeps blowing fuses. can i wire it directly to the battery with an inline fuse? How would i do this?
you could do this by running 2 wires directly from the battery to the back of the cig lighter and by fusing the positive.if it is only when using the cig lighter and not when charging a phone ect.it could be element on the cig lighter shorting
Apr 05, 2010 | 2000 Volkswagen Golf
Please help me with power in cig lighter
Hi, grab a voltmeter and test volts at car lighter connector, near to car lighter socket, if there is volts in there (uncommon) , then check for short or broken contact on car lighter socket, or replace the first socket connected in line.
If there is no voltage getting to cig lighter, check the two connections at the back of the fuse box, on the cigarette lighter fuse.
If there is volts only on one side, then fuse is gone again, in that case there is a short on wiring, maybe on one of lighters, locate it and fix it.
If there is power on both sides of the fuse, then fix or replace wiring between fuse box and cigarette lighter, one wire is broken.
If there is no power on both sides of lighter fuse, then fix the wiring between fuse box cig. lighter contact and battery, if this is too complicate you can even build a new wiring and solder in place of the old one.
If the lighters have more than one fuse, do the same job for both lighter. Cig. lighters do not use a relay, and there is no additional fuse, the above procedure is enough to fix any possible problem on such a simple device.
If you have no practice with this kind of repair on car electrical system, then better to go to a car electrician or mechanic rather then messing up the car electric system.
Please do not forget to leave us feedback afterward, that is important for us.
Many thanks.
Apr 22, 2009 | 2002 Mitsubishi Montero Sport
Need to change out cig lighter dont work fuse is good 1995 dodge ram 1500
remove the ashtray and reach behind the cig lighter you should feel a nut you take the nut loose and the cig lighter comes right out just unplug the wires and plug them on to the new one. and if you get your new cig lighter first you will get the idea of what i am talking about the nut
Apr 21, 2009 | Dodge Ram 1500 Cars & Trucks
Where do I change the fuse for the cig lighter?
You are correct. The fuse is the 15 Amp CIG fuse.
Oct 17, 2008 | 2007 Toyota Yaris
Utility cigrette lighter in dashboard
you may have burned out the lighter unit.check the wires for melting also!
Sep 23, 2008 | 2004 Toyota Camry
Passport 8500 Radar Detector Logo
336 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
