Question about GE Zoneline AZ55H07D Air Conditioner
Turned it on smelled like rottin crawfish
Turned unit on and crawfish smell poured out of vents
    New Friend:
  • 30 Answers
The crawfish smell is algae buildup in the drain. the unit needs to be cleaned at the evaporator and the drain needs to be checked.
Posted on Oct 30, 2008
I have a strange situation going on in my house. When I turn on my airco frequently I get a nasty smell from the airco vents. Sometimes we have it running all day and it's fine (no smell at all) then at...
You should look in the air handler( Where the indoor blower is located) or in the plenum (where the duct system originate at the air handler) for any dead and rotting rats. Residential central air systems are sealed (uses circulated air only) and do not use outdoor air.
Aug 27, 2013 | Heating & Cooling
Bathroom sink smells strongly like sewer when water runs fast.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
Oct 15, 2012 | Plumbing
Sour smell coming from back of fridge on outside
Check the drain pan under unit. Maybe something has got in there. May need to remove the back our go through the front. Can pour a very small amount of bleach our Lysol to kill in the drain pan to kill mold. Hope that helps.
Aug 18, 2012 | Hoover Refrigerators
Help with gas fumes smell
Was fuel smell present before you had fuel pump replaced? If yes I would sugest you drop tank and see if fuel vent hose is plugged forcing fuel back pressure line to vent through cap. If fuel smell was not present before you replaced fuel pump and seal. I would suggest you drop tank back out and check all fittings and hose conections. also if you still have old sending unit you could check to make sure they are exactly the same. As Sometimes you have to pull relief valve from old sending unit and install it in the new one, as some sending units wont have one in it. and some will have one that is regulated at a different fuel pressure. hope this helps Vic
Mar 01, 2012 | 1999 Chevrolet Malibu
Bad smell from a/c
Do you leave your climate control in the Auto position. This is bad. What happens is the evaporator which is located in the vents never dries out and you begin to grow mold. Does it smell musty, locker room type smell.
Also since it came out the heat vent it could also be a leaking heater core. Check you coolant level and reservior. If low this is an indication heater core is leaking. It may not of leaked enough to tell but usually these are the only reason the vents would smell unless a rodent ended up there and died.
May 30, 2009 | 2006 Nissan Quest
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
AC-Smells
that job I haven't done yet. the smell you are getting is it a real sweet smell? If it is possible antifreeze leak. Beyond that I;m not really sure. Unless someone poured something down into the cowl vent. Do you get the smell when the ac is on with vents open or recirculator button pushed?
Jun 10, 2008 | 2004 Suzuki Forenza
GE Zoneline AZ55H07D Air Conditioner Logo
133 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
