Question about Sony Cyber-shot DSC-W50 Digital Camera
E91:01 Constant flash sign on Cybershot DSC-W80
The flash sign is flashing continuosly - but never flashes when taking pictures. The error message is E91:01. I am not finding any way of resetting the camera to factory settings.
Nellanatt
  • 1 more comment
  • Anonymous Oct 30, 2008
    RESET UNIT IT WORKS FINE.
  • nellanatt Nov 06, 2008
    It helped in initializing the camera. But the problem with the blinking flash sign has not stopped, even though the camera was initialized several times. Further, the camera flash does not flash even when shooting in the dark.
    Thanks for trying !
    Nellanatt
  • Anonymous Dec 22, 2008
    I have a Canon PowerShot SD1000 Digital ELPH Camera that will not flash. Even if I set the camera to flash all the time, and not just auto, it still won't flash--the orange light just keeps blinking but the picture won't take and the flash won't go.
  • 74 Answers
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Posted on Nov 03, 2008
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
Jun 14, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
Feb 17, 2010 | Sony Cybershot DSC-H3 Digital Camera
The flash won't work on my Sony DSC-W80, no matter if the flash is on.
The flash unit that is along with ST board needs replacement, The detail of part along with part No. Description and picture is given below,
Thanks
Part No. Description
A-1246-052-A ST-160 BOARD, COMPLETE
Jan 18, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
E:91:01 in DSC-W80
I can't recall all the Sony error codes off the top of my head, but I believe E:91 is that your flash is not working.
Can you take pictures at all or do you get just the error code? If you can take a picture with the flash off then your flash needs to be replaced.
If you can't use the camera you need to first press the reset button, then reset all camera settings to default.
1-3. PROCESS AFTER FIXING FLASH ERROR
When "FLASH error" (Self-diagnosis Code E : 91 : 01) occurs, to prevent any abnormal situation caused by high voltage, setting of the flash is changed automatically to disabling charge and flash setting. After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the HOME screen.
Method for Initializing the Flash Error Code
Initialize
Initializes the setting to the default setting. Even if you execute this function, the images stored in the internal memory are retained.
1 Select [Initialize] with v/V/b/B, then press z. The message "Initialize all settings" appears. 2 Select [OK] with v, then press z. The settings are reset to the default setting.
To cancel the resetting
Select [Cancel] in step 2, then press z.
· Make sure that the power is not disconnected during resetting.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flash of sony cybershot dsc-w200 is not working
i think i had the same problem, if u press the home button and then press shooting then hit the flash button on the right hand side it should change the mode.
Jun 22, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
E91:01 error code W80
I will forward a link to a page where you can get the information regarding this error message.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C1002686
Jun 16, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Blurring pictures
I had the same problem. Somehow my flash was set on "SL - Keep subjects and distant backgrounds bright." When I changed the flash to "Auto", it seemed to get rid of the blurry pictures.
Dec 08, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Can't take picture with flash on
Hi
Your flash is defective and needs to be replaced, nothing else will fix the problem.
One solution is to look online for a defective camera and use the parts to fix yours. Another is to buy a flash from someone like us who sells new and used parts and performs repairs if you can't do it yourself.
Please feel free to check us out, Google: Darntoothysam and you will find us, I cant post a link.
Thanks and good luck from Darntoothysam com
Thomas
Sep 20, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Flash not working...
I have a DSC-W80 CyberShot I had a problem with the error code on the LCD Screen that said E:91:01. I played with the camera for a little bit and found the if you push the home button and go to settings. When you get to the settings go to main settings, When you get there go to initalize and follow the instructions. MAKE SURE YOU SAVE YOUR PICTURES OR TAKE THE MEMORY CARD OUT OR YOU WILL LOSE ALL THE PICTURES. I hope this will help you.
Jan 21, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Cyber-shot DSC-W80
The camera is probably is "Burst" mode where you hit the picture button and it contineously takes the picture. Hit menu and look to see if you have it set to burst mode if so take it off and it will work..I just found the answer on here :)
Dec 25, 2007 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
112 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
