Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Repair Procedure Sound works well. Picture comes on for a period of time then goes to broken black and white of last color picutre frame
  • Hoot Gibson Oct 29, 2008
    Samsung > HLN5065W 50 in. Rear Projection HDTV-Ready Television
    Sound works well.
  • 899 Answers
The black and white circut is seperate from the the color circut
so the only other thing controling the color is the convergence IC's
video works color don't or is off (3d look or bowing in the picture) is the conversion IC's resistors and or the IC's themselfs
you will need a tech to come out and repair the problem
Posted on Oct 29, 2008
  • 3,037 Answers
Well, if it will still go back to color, then most likely it is your digital board that needs to be replaced. If it would stay black and white and not go back to color and possibly produce a high pitch squeal, then it could be your color wheel. Which is your problem?
Either way will be a good price part
  • 4,472 Answers
Does it do this on every input? Like no matter if its DVD or something else? How long have you had this problem? Are you attempting to repair it yourself or have it repaired? Once I have more information I can assist you further.
Thanks,
Lee
I have what I think is a Hitachi 55 inch ultravision rear projection TV that is 12 years old. I think the model is 55UX58B. The color goes out and it becomes black and white. It comes back after a few...
When the tv is it totally black and white and the tv picture are good and clear wright?when the tv colors are fade in and out are clear up and when the tv picture it is in colors it is look good normal picture wright?Tv have no shadows of any kinds of colors when picture are good in colors wright?Yes,take ur hand make fist or take a wooden hamer bangs all around the tv bazel frame if the tv colors come back or tv stay in colors it is have good picture in colors.Tv it is still good just have components parts are cold soldering or CRT colors guns R,G,B just require resoldering works only.
Aug 22, 2011 | Hitachi 50UX57B 50" Rear Projection...
After the tv has been on for about 30 minutes the picture starts flickering really bad and eventually will go completely white like where it looks kind of like negatives? it works perfect for that first...
The colors wheel could dies at any time of the tv life,at any monent without any period of times.The colors wheel run at RPM spinning revolution are 1000 RPM a min. to make colors for this tv.The problems u discribing are one problem of the effect of the colors wheel is dying and worn out.The colors flashes like film negative,the picture flashes Black&White withtin the picture.Replace the colors wheel again,will solved this problems.
Nov 20, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Color poor, essentially black & white
Hi
Thanks for using FixYa. This issue is caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. Please also check the convergence board for cracked solder. If you want to do the repair yourself there are repair kits available which includes instructions on how to replace them. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | Philips 50P8341 50" Rear Projection...
I have a panasonic pt-60dl54, the sound works but green picture
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.You will need to replace the DMD board. Have a blessed one!
Apr 13, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Apr 29, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Picture Problems
check for poor grounding of the input signal cable wire.
easy way to check this is put in a dvd and is that in color?
Feb 01, 2008 | Sony KP-53XBR200 53" Rear Projection...
Our Color TV is now Black & White
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
May 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
65 people viewed this question
cce772000
Level 1 Expert
