Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Fridge works only on the max setting
My whirlpool fridge works only on the max temperature setting. But at this setting, everything in the refrigerator compartment also becomes frozen.
Needs a defrost heater, keeps it from freezing up. my friends did the same thing, she changed defrost heater and works fine now.
Posted on Oct 29, 2008
Hi, i need to set temperature for my 6th sense american fridge/freezer.. panel shows -24 deg for freezer and 5 deg for fridge..can you help me pls ?
There are buttons for fridge temperature and freezer temperature on the control panel. Just press the relevant button repeatedly until the temperature you want is displayed. http://docs.whirlpool.eu/_doc/501931501055GB.pdf
Jul 15, 2014 | Refrigerators
My whirlpool fridge is freezing the food in it. What can cause that and how do you fix it?
set at minor temperature,set the thermostat dial at warm temperature.maybe its a little bit empty of food and at full coldest settings
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
There fridge side is freezing everything!
Hi
What is the model of your fridge.
On the older fridges, a faulty thermostat would cause the fridge compressor to run continuously and therefore, would not regulate the temperature.
On newer electronic models, you have temperature sensors giving signals to the control board. These can fail.
Ash
Sep 11, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I bought a whirlpool fridge freezer last two weeks it was working fine but i noticed that the freezer is making too much ice when i set it at temperature 7 which is melting and i keep seeing water under...
Water under it is fine as long as it is not on the floor. It should be in a pan that came with the unit. You should have 2 temp setting for the unit..1 for the freezer and one for the frid. set the freezer for 5 to start. and then set the frig at 5. and adjust only the fridg side after a few hours. If this does not wrok call the place you bought it from as it may have a bad swthch on the indoor fan or a bad flapper door that allows cold air from the freezer to cool the fridg. But you have to start at mid range and adjust only the fridge side moving it up or down buy 1 number at a tiem.. Let me know know. I hope this helps Jon
Aug 13, 2011 | Whirlpool Heating & Cooling
Refrigerator temperature running too high
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 03, 2009 | Whirlpool ED2FHEXN Side by Side...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
162 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
