Question about Zenith L20V26C 20.1 in. LCD Television
How do I reset my 15inch lcd bush tv?
The picture on my television has gone all dark because i acciedently pressed something and turned it to another setting whilst laying in bed. how do I reset it??? please comment back asap!
Sony Brovia TV the picture went dark. You can see it but not to well.
Picture Become dark means there is some problem with the back light of the tv. can be problem with the back light led drive or the led array.
www.electro-medical.blogspot.com
Sep 06, 2015 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Just brought a 32"lcd bush tv from Argo the
Get this TV replaced. The back light inverter board has the problem. Being new, why do you spend more for repair?
Jun 07, 2012 | Televison & Video
My 52 ince screen stopped showing picture. It is just red, or yellow or green with thin vertical lines. I can hear that the channels are changing but no picture. Is there a reset button or something?
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Thanks.
Aug 04, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Polaroid TDX 01530B 15inch Black screen, no picture except POLAROID is visible briefly as TV fires up. Sound works.
The tv have a long board that call the LCD inverter board it is dead.This long LCD inverter board only job are to provided a backlight for the tv LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
May 13, 2011 | Polaroid TDX-01530B 15.4 in. LCD HDTV
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Picture on all channels is dark
    seems like its the inverter thats either not working or the tubes are faulty
    Mar 26, 2010 | LG 42LG50 42 in. LCD HDTV
    LCD TV has dark smears on picture
    This not repairable,it a LCD screen have minor pixels cracks in the LCD screen itself,some body hit the LCD Screen with somethings.
    Jan 12, 2010 | Panasonic VIERA TX-26LXD80 26 in. HD-Ready...
    Bush lcd 24 inch tv
    REPLAXCE THE DEGAUSING P.T.C
    Oct 24, 2008 | Bush 5693D 24" TV
    Zenith L20V26C 20.1 in. LCD Television Logo
    385 people viewed this question
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
