Question about HP Laser Jet CM2320NF Laser Printer MultiFunction Color 600dpi 21ppm 1
Over the past 5 years I have used an HP4100 MFP to print text files from a spooled printer that delivers raw text to HP print driver. Recently I purchased a new CM2320 MFP from HP expecting to do replace the 4100. However even though I have set the lines/page to 63 lines on the new printer (just like the 4100), I can only get 60 lines per page regardless of what I do. I don't understand why. If I take the same back end system and deliver my raw text file to an HP4600 where I also set the number of lines to 63, this printer works fine too. At this point in time on the CM2320, I know I have correctly set the number of lines to 63, but no matter what else I try either by changing setpoints in the XP driver or at the printer, the output is always 60 lines/page. Why?
4 Suggested Answers
worldvet
  • 859 Answers
SOURCE: Slow printing of Acrobat pdf files on HP Laserjet 1300
Hey look, sorry for all the BS you've been given. Its an issue here.
How much ram does your laser jet hold right now?
This would be the choke point on an HP laser jet.
A typical PDF file in high res can be many many megabytes in size and the HP Laser treats these documents as an image file, same in true in Windows, but uses local ram not printer ram like an Apple.
So, if you have a 256K chip, its possible, on your printer and the file is 4-6 MBs in size, you could be looking at a 16-20 minute print job.
I'm not familiar with any tricks to get your printer to use local ram as a cache. If you have Boot Camp, you might consider starting that emulator up and printing from that interface. No real hope for a difference but its worth the try.
Hope that give you some real thoughts to chew over.
Regards,
Worldvet
Posted on Sep 29, 2008
  • 48 Answers
SOURCE: How do I change fuser sleeve on HP4100 laser printer?
You can print out a parts diagram at www.printerworks.com.
Posted on May 28, 2009
SOURCE: Laserjet cm2320 fxi mfp has scanner error 5
when Printing from my HP 2320 there is a slight blue streak on the Right side of the page
Posted on Jul 07, 2009
HP psc 1100/1200 all-in-one stopped printing
Press and hold the cancel button and then press the start copy button release them together.
You should print a test page. No Test page an internal printer problem is likely!
If test page is good reset the spooler \. More than one way to reset spool file. Spool file controls transfer from computer to printer. Spool file a mess then printer hangs!!!
Method 1
a. Go to Start / Control Panel / Administrative Tools / Services
b. Select "Print Spooler".
c. While Print spooler is stopped, start it by double-clicking on "Print Spooler" and then click the "Start" button.
d. Verify that the "startup type" is set to "automatic".
Method 2
Create a new txt file
Type in exactly as the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Rename txt file killspool.bat
save on desk top
Double click off of desktop file to run
Next time printer hangs you can use this file again
Hope this helps?
Dec 03, 2016 | HP Office Equipment & Supplies
I accidentaly changed the language, how do I get back to english
Go to the Printer Properties, Printing Preferences, or Document Defaults are Displayed in an Unexpected Language so trie changing the language from there if not then there are two ways to correct this problem. The first is to download the printer driver from the HP Web site and install it. The second involves replacing the .DLL file the printer driver uses to obtain the text that is displayed on the screen.
There are two ways to correct this problem. The first is to download the printer driver from the HP Web site and install it. The second involves replacing the .DLL file the printer driver uses to obtain the text that is displayed on the screen.
1. Uninstall the printer driver.
2. Run the Scrubber, located as shown below on the Starter CD, for the desired operating system.
1. For Windows 9x and Me: \UTILS\SCRUBBER\WIN9X_ME\SCRUB9X.EXE
2. For Windows 2000 and XP: \UTILS\SUPPORT\SCRUBBER.EXE
3. Download the latest version printer driver from the Internet and install the new driver.
4. If the properties are still displayed in the unexpected language, proceed to the Replacing the language .DLL file section below.
(To install the driver go to the hp website that is hp.com/support )
Select Start and then Search.
2. In the All files and folders box, type the name of the .DLL file and select Search.
3. Using the Explore window, locate the first occurrence of the .DLL on the hard drive.
NOTE: Replace each occurrence of the .DLL file in the \WINNT\SYSTEM32\SPOOL\DRIVERS\W32X86\3 directory and any subdirectory where the file is found, \WINNT\SYSTEM32\SPOOL\DRIVERS\W32X86\hpdeskjet_6800421c.
4. Right-click the folder that contains the .DLL file to be replaced and select Paste.
5. Select Yes when asked to replace the file.
6. Repeat Steps 1-5 for each occurrence of the .DLL file that was found.
ALL THE BEST
Jun 02, 2010 | HP LaserJet 3030 All-In-One Printer
HP laser jet 1522nf mfp ( firm ware corrupt ready 2 download)
Perform the following troubleshooting in the order listed:
  1. Turn off the printer, with the communication cable still attached.
  2. Clear the print spooler by doing the following:
    1. Go to Start then choose Run .
    2. Type net stop spooler , and press Enter .
    3. The Windows XP spool directory is located at: C:\WINDOWS\SYSTEM32\SPOOL\PRINTER ; Delete every file within this folder.
    4. Go to Start , then Run , and type net start spooler , and press Enter .
  3. Manually delete and reinstall the driver:
  4. To uninstall printer driver, refer to the following steps:
    1. Open Printers folder and right click the driver that you wish to delete.
    2. Within the menu, select Remove .
    3. For the confirmation message displayed, click Yes .
    4. Right click the Printer Folder and select Server Property .
    5. Click Drivers tab, and select the driver for deletion. Click Remove .
    6. For the confirmation message for the deletion, click Yes .
  5. Install the printer driver manually as follows:
    1. Select the Printers and Faxes option from the Start menu.
    2. Click "Add a printer" then, on the resulting "Add Printer Wizard" dialog, click Next.
    3. Ensure the option "Local printer attached to this computer" is selected. Untick the checkbox "Automatically detect and install my Plug and Play printer". Click Next.
    4. Ensure that the option "Use the following port:" is selected then select the appropriate port from the drop-down choice box. When choosing port, use one of Virtual Printer Ports for USB to which is your printer connected to. Click Next.
    5. Click the "Have Disk..." button. On the "Install From Disk" dialog, click Browse... then navigate to the appropriate directory to which the software/driver extracted.
    6. Select an inf file then click the "Open" button. Click OK on the "Install From Disk" dialog.
    The Add Printer Wizard will start to copy driver files to the PC.
  6. Run the firmware upgrade with the printer turned off so that the printer accepts the firmware only after the entire file is spooled.
  7. In the firmware update program's window, choose your printer (manually installed) and press Send Firmware button, and wait for the firmware to be spooled completely.
  8. Power-on the printer.
  9. During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display Printing Document and will change to Erasing . After a short while, the LCD display will change to Programming . After a short while, the LCD will display complete The Ready LED on the printer will start flashing. The printer will automatically power off and then back on to reboot, and will make noises similar to that of a power-on operation.
May 11, 2010 | HP LaserJet M1522nf Multifunction Printer...
Duplex still has problems printing double sided.
Hi, Please find the work around steps to resolve duplex printing issue in Windows Vista. Please the send the *.gpd files to the cu via mail before doing the steps. Duplexer Printing for Windows Vista Troubleshooting steps 1.start-all programs- accessories ? cmd -right click-run as administrator 2.Stop the Spooler service - Type net stop spooler 3.Change current directory Type cd windows\system32\spool\drivers\w32x86\3 4.Backup the old gpd files - Type copy hp*.gpd *.bak 5.sent the zipped file to customers email address through astro and then download the file to customers desktop 6.extracted the files from the zipped folder and then pasted those files to windows\system32\spool\drivers\w32x86\3 7.Remove old BUD file Type - del HP*.bud file 8.Restart to spooler service - Type net start spooler 9.checked under printing preferences if the both sided printing is selected as automatic and then tried printing a two page document 10.checked whether its printing or not. 11.) Start-Control Panel- Printer & Faxes- Right Click On the printer -Properties-Device settings-Disable the manual Duplex printing-Click on Installed Two sided printing-click on apply & ok. 12) Then Go to Right Click on the Printer-Printing preferences-Paper quality-Select Two Sided Printing from the top drop down list where its showing What do you want to do? 13) From Print on both sides-Select Automatically from the drop down list. 14) Try to print on both side check whether its working or not.
Sep 18, 2009 | HP PSC 1510 All-In-One InkJet Printer
Laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Oct 18, 2008 | HP LaserJet 2430dtn Printer
1020 PRINTER DRIVER HP
There are no drivers for fixya but I have found a workaround by some anonymous poster
Xp software&drivers will work in Vista after a little tweaking in printer properties.
1)Install the CD-Rom HP Software/Drivers that came with your Printer at the time you purchased it. These Xp software&drivers are Vista Compatible after tweaking the Printer Properties. Reboot after installing.
2)Goto Start/Printers. Right click HPLaserJet1020 then Left click Properties. An HPLaserJet Properties window should have popped up.
3)Click the Advanced Tab. Click the Print Processor button located at bottom of window.
4)Select print processor as>>>IMFPrint. Then Select Default Data Type as>>>RAW. Click OK.
5)Now return to the Main HPLaserJet Properties window and click the General Tab. On the Bottom of that window; Click the Print Test Page Button. Finished! A test page should be printing out if you adjusted the printer properties correctly. Enjoy!
optionally you may have to disable print spooling
Quote "This did not work for me until I changed the option in that same window (advanced settings) to "print directly to the printer". Spooling does not work. "
Jul 14, 2008 | Office Equipment & Supplies
F2100 printer
My HP Deskjet F2100 All-in-One series printer worked up until today. It printed three sheets and then stopped.
Dec 16, 2007 | HP PSC 1610 All-In-One InkJet Printer
Print out is too small
To resolve this, try the following actions:
* Check the default fonts within Microsoft Windows.
* Select your entire document and set it to a larger font.
* Make sure all your fonts are loaded properly.
* Change the resolution to quick print at 600 dpi. To do so:
1. Click Start, Settings, Printers.
2. Right click the Lexmark printer icon and choose Properties.
3. Choose the Document/Quality tab and set the resolution to 600 dpi quick print/draft.
* Change the Spool Data Format to RAW. To do this:
3. Select the Details tab and click Spool Settings.
4. In the Spool Settings screen, set the Spool Data Format to RAW.
5. Click OK and then Apply.
Nov 19, 2007 | Lexmark X2350 All-In-One InkJet Printer
HP Laser Jet CM2320NF Laser Printer MultiFunction Color 600dpi 21ppm 1 Logo
49 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
