Question about Refrigerators
Westinghouse Aurora Frost free fridge
Water leaking out from inside the fridge onto the floor in front of the fridge
  • Anonymous Nov 17, 2008
    my fridge is leaking on the inside and water is on the floor but the tray at the back is not overfilling, the water seems to be coming from in between the back of the tray and the fridge wall..seems to be a slight gap behind the tray and the water is leaking from there..is there some sort of connector missing?
  • Anonymous Mar 28, 2014
    water dripping onto top shelf of fridge on westinghouse fridge
  • 108 Answers
You need to remove the clog in the drain line from the freezer to the condenser, Look under the fridge for the plastic drain line and blow it out or otherwise clear it, Then insure that the unit is level. Sooner or later you need to clean the freezer drain pan. After using up your frozen food, remove the back panels of the freezer and clean the area well.
Ray
Posted on Oct 29, 2008
Water is leaking into my fridge from defrost.
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system.
If in case the water is leaking on the floor then:--
There are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Unplug the unit from main power outlet and empty whole unit and keep both the doors open and then connect the power after 24 hours and recheck.This procedure is called manual defrost reset.If this helps then its OK,but if this procedure not helping then its the faulty defrost unit and it needs to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | GE Refrigerators
Water is leaking onto the inside floor of the fridge. when u used the water dispenser it leaks even more
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
May 12, 2010 | Refrigerators
Lickage of water from frost free fridge
actually a frost free fridge should leak water but it should not make it to your floor. every frost free fridge goes into defrost every 8 hours for 15 minutes where it will melt the ice off the coils. there is a pan underneath the fridge to catch this water. it should evaporate before the next defrost cycle there is not much water that comes out. you may want to pull the front cover and look under the fridge make sure the pan is in place and there is not a crack in it
Apr 27, 2009 | Refrigerators
Water runs out of freezer door overnight ,at times
Have a look at this link:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/7670-leaks-water-floor-front-freezer.html
or this one:
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Apr 17, 2009 | Westinghouse Refrigerators
Water dispenser keeps running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking from freezer into fridge
there are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchangertubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
click this link for more help  http://www.applianceaid.com/refrigerator.html
Mar 31, 2009 | Kenmore Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Water leaking
Hi
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Thanks
Rylee
Feb 16, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Refrigerators Logo
922 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
