Question about Plumbing
How do I, myself, fix a faucet leak?
The faucet leaks a very thin stream of water, even when the knobs are closed.
  • Anonymous Dec 16, 2008
    On gooseneck, two-handle faucet, I have a thin stream of water when the valve is in the closed position. This happens only with the cold water. My husband thinks there is an adjustment without dismantling the whole faucet, but he has been unsuccessful so far. Help, please.
My bathroom hot water faucet will not completly shut off the water
Posted on Jan 07, 2009
  • 374 Answers
Faucets in general operate either with a one handle valve stem or valve stems that uses small pieces of rubber to precent the water flow. In a single handle model this is usually caused by mineral deposits building up and the valve not being able to fully restrict the flow of water. The fix here is usually a new stem. On models that use a two handle system and do have replaceable valve stems one must get a repacement seat from a hadware store and reinstall the stem. In extreme cases the valve body may need to be ground internally and will require a professional. If you do not a have replaceable stems than the only alternative is a new faucet. I hope this assists you and thanks for using Fix Ya.
Posted on Nov 09, 2008
How do i fix my leaky moen bathroom faucet?
Moen faucets are easy to repair. The cartridge you're looking for is most likely the #1224 cartridge, sold in pairs, and available at almost any home improvement store.
Shut the water off, unscrew the handle, remove the nut that holds the old, cartridge in, swap it out, and put the handle back. The whole job should take you about ten minutes.
Good Luck!
May 21, 2014 | Plumbing
Tip
Fix leaking faucets yourself
always rember , anyone having problem with leaking water faucets,for example a bathroom sink faucet is leaking,you don't have to go and buy a new one.save youself some money,buy putting new washers in,and if that don't stop it you will need to change the set that the washer seat agains't.<br /> the way to do this first,you would need a screw driver and take off<br /> off the knobs off the faucets,then you will see the washer you would <br /> replace ,but the water has leaked so long you would need to change the<br /> copper set to do this you need a wrench that you can remove the copper<br /> seat then reassemble the faucet and to make this fix last.<br /> always rember don't tighting the knob just enough to stop the water<br /> from leaking and the washer will last alot longer.doing this yourself<br /> you have saved alot of money.
on Mar 09, 2011 | Plumbing
Search Fixya...
    • Test the dripping water with your hand to make sure that it is the hot water side that is leaking. Lay a rag over the sink drain to keep parts from falling down it. Locate the hot and cold shutoff valves under the sink and turn the knobs clockwise by hand until they close. If the knobs remain stiff, use a pair of pliers to gently turn them until the knob begins to move, then finish turning by hand.
    • 2
      Pry the decorative cap off the faucet top with a small thin, flat-head screwdriver. Remove the cap that has the "H" letter on it. Depending upon the handle screw configuration, use a flat-head or Phillips-head screwdriver to remove the handle screw. Gently pry up on the handle from all angles and pull it up and off the splines of the stem.
    • 3
      Use a crescent wrench to turn the hot water stem nut counterclockwise until it comes completely off the stem shaft. Wiggle the stem with your fingers and pull it out of the faucet. If the washer on the bottom of the stem is deformed, it indicates the source of the leak. However, remove the old seat from the faucet base with an Allen wrench or a seat removal tool.
    • 4
      Wipe out the inside of the seat housing with a rag. Replace the seat with the new one included in the repair package, using an Allen wrench or seat removal tool.
    • 5
      Place the new hot water stem shaft into the valve seat, and start the stem nut in by hand, turning it clockwise. Finish tightening the stem nut with the crescent wrench, but only to a moderate firmness -- do not over-tighten it. Place the handle back over the stem shaft and tap it down until it seats firmly. Replace the handle screw and tighten it with a screwdriver.
    • 6
      Turn the hot and cold water supply knobs counterclockwise until they are fully open. Turn the hot water faucet knob to the "On" position and check for leaks.
Jul 09, 2013 | Computers & Internet
Heater comes on with water
please see the next step:
he pilot light may be out or may not stay lit. There may not be enough hot water, or the water may be too hot. The water heater may leak or be noisy, or the hot water may be dirty.
A problem with your water heater may be due to overwork, not mechanics. If your water heater holds less than 15 gallons per family member (tank volume is stamped on a metal plate affixed to most water heaters), consider a larger unit or staggering your use of hot water.
Drain a hot water tank:
  1. Turn the gas-control knob to off and close the gas-shutoff valve.
  2. Close the cold-water supply valve and open a hot-water faucet in the house to speed draining.
  3. Attach a garden hose to the drain valve and run it outside to a drain. If the heater is in the basement you may need to run the hose to or through a sump pump.
  4. Open the drain valve and allow the tank to drain.
  5. Once done, close the drain valve, open the cold-water supply valve, and open any nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full; close the hot-water faucet.
  6. Once the tank is full, turn on the gas and relight the pilot.
Jul 31, 2012 | Heating & Cooling
I have a pull out spray kitchen faucet and the spray faucet leaks around the pin that changes the water from a spray to stream. Can I get a replacement for the spray/stream head?
take old sprayer with you and you should be able to get one at a hardware or even at homedepot.most sprayers come apart. maybe the rubber ring is bad on inside of sprayer.
Apr 21, 2011 | Plumbing
I have a kitchen faucet that is leaking at the base where the faucet connects to the base. It leaks all the time. Do I need to replace the O rings in the stem of the faucet? Or do I need to replace all...
hi! if tightening the knob(s), (or if you apply pressure on the knob of the faucet,for the models with no thread for open/close), modify the amount of water leaking ,you need to replace the seats in the faucet. if not ,just replacing the o rings should fix your problem.
Feb 20, 2011 | American Standard Kitchen Faucet 6310 020...
I have an american standard shower knobs for cold and hot with a center control that directs to shower. Tub faucet leaks. How do I fix this?
Pull the knob off...usually the screw is behind a cover in the center of the knob...
Behind the knob you will find a nut that is the packing nut ... this is what keeps the water from running out around the stem...turn that nut clockwise a quarter to a half turn or until snug...
this iwll fix your leak...
heatman101
Aug 14, 2010 | Plumbing
Severely reduced water pressure from lavatory faucet
Take the strainer off the spout and check to see if there is any dirt or rust buildup in the strainer. This happens when repairs have been done. It usually collects at the first place the water comes out of.
Nov 07, 2009 | Elements Of Design Chicago Polished Brass...
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Nov 12, 2008 | Kohler Forte entertainment remote valve...
Plumbing Logo
378 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
