Says This is a brand new DVD player. When I set it up the power goes on and everything seems to be working except when you press play either manually or by remote control the unit does not play and it says "invalid key" on my TV screen. It also says OPEN on the DVD player at all times even when the lid is closed. HELP......Thank You, Maureen
  • 903 Answers
Sometimes if condensation gets into a dvd player it can mess things up and make it not work properly, I would take it back to the store and get it replaced.
Posted on Oct 29, 2008
Gpx d200b dvd player. Why won't it play certain dvds? It plays all my other movies except for one that I just bought brand new.
The format of your new disc is probably NOT COMPATIBLE with your disc player. Verify through your owners manual & the format of your new disc.
May 15, 2015 | GPX Televison & Video
DVD player won't play new movies
Try this
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu.
2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote.
3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2.
4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support
1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Excerpt from email tech support Walt Disney
Dec 07, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
I have a Magnavox DP170MW8B DVD player. It worked fine yesterday. Now the player will not turn off nor will it play. I have use the remote and the buttons on the machine and it still does not work. There...
If the unit works with the disc inside, stop it from trying to play.
Reset to default (except parental setting):
(from page 23 of the owner's manual)
Press SETUP in the STOP MODE to enter the menu.
Select 'INITIALIZE' then press OK.
Select 'YES' and press OK twice.
Press SETUP to exit the menu.
Suggestion: You could do a "power reset" - unplug the unit from the wall socket for approximately 10-15 minutes, then reconnect. Turn the unit on - the DVD tray should open and release the disc.
http://tv.manualsonline.com/manuals/mfg/magnavox/dp170mw8b.html?p=23
(you may already have the owner's manual - the URL is a reference guide only)
Dec 23, 2017 | Magnavox DP170MW8B DVD Player
I have an auvio 15-304 remote that I am trying to program to my gpx DVD player and can't remember how because there is no code for the DVD player brand.
i have an Auvio 15-305, so this might help. Manual Code Search.
1) Power on the device that you want to control. For VCR and DVD players, you must insert a tape or disc first.
2) Press and hold SET, then press (TV, VCR/DVD, AUD, DVR,SAT/CBL, AUX) at the same time on the remote. The LED will stay lit indicating it is on setup mode. NOTE: DO NOT HOLD DOWN THE KEYS MORE THAN 3 SECONDS OR THE REMOTE ENTERS AUTO SEARCH MODE.
3) Press POWER on the remote. The remote enters a manual code search mode, the LED will start flashing.
4) Press POWER on the remote continuously until the device turns off.
5) When it turns off, turn on the device manually. then try pressing the other buttons on the remote except for the POWER, SET, and DEVICE keys.
If most of the buttons work then press the selected DEVICE key that you selected in Step 2.
i hope this helps.
Dec 02, 2010 | Televison & Video
I played a dvd and now can't get the tv to come on. How do you switch between dvd and television? This is a Westinghouse DVD LCD combo television.
on the remote there are various button at the top to control the functions. these include tv dvd cable etc.
When the remote is set on tv all the functions on the tv work together with the functions of dvd such as play stop etc.all except power channel up channel down etc.
THE REMOTE MAY JUST BE SET TO DVD JUST PRESS TV AT THE TOP OF THE REMOTE OR YOU MAY NEED TO SET IT BACK AND THE PROBLEM IS FIXED!!! THE USER MANUAL SHOWS YOU HOW TO SET IT.
Feb 27, 2010 | Televison & Video
IDVD: Problems with burned DVD.
Try a different brand of blank DVD.
If that doesn't work any better, and your MacBook Pro is in fact "brand new," bring it to the Apple Store, because you have warranty redress.
Mar 02, 2009 | Apple Computers & Internet
Hi I need to unlock my Sanyo DVD player HV-DX350A
HI this works as i have unlocked my own Sanyo HV-DX350A player with it Hope it works for you
Unlock region code for Sanyo HV-DX350A DVD/Video player.
1. Turn on unit
2. Select DVD
3. Open tray
4. Press 0520 then in sequence press arrow up, down, left and right.
5. The region management screen is displayed on your monitor ( Code is displayed on the unit LCD display).
6. Note - Your current EEPROM region code setting is displayed on the screen.
7. Enter desired Region Code ( 0 for multi region).
8. Press PAUSE to exit.
9. Turn power off and turn on again.
If you repeat steps 1 to 4, you can view your new setting.
Feb 29, 2008 | Televison & Video
DVD picture is black and white
Sounds like you are either trying to play an NTSC (US or Asian) DVD on a PAL (European) TV.
Go into the DVD settings and look for picture, video or display options.
If the DVD is set to NTSC, then set to PAL.
Jan 06, 2008 | Philips DVD 622 DVD Player
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
Dec 01, 2007 | LG DV276 Recorder
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
