Bosch washing machne error E04
I have a problem with my mashnig machine. In the middle of cycle, when it is supposed to spin, I get an error E04. I am also unable to open the door. Can please anybody give me solution for this problem? at least how to get my laundry out?
Thank you.
This happened to me this morning and I did this. I found my daughters sock in the trap. After fixing I drained the load and started again. Works great. Bosch E04 Solution:
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say! I'd guess you could get wet.
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole to 6'oclock and it should come free.
  5. Once the door out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hands. There is a small collector lip at the bottom of the cap, that is where I held my wet/dry vac to catch the water. Unscrew slowly so you don't get flooded. Take your time and keep unscrewing it until it is free.
  6. Pull out the trap that you just unscrewed and you'll most likely see the item that caused the E04 error code. There is an side of the trap that is marked that it needs to be installed facing downward, so watch for that when you put it back in.
  7. Read these directiosn upside down and backwards to put it all back together.
  8. Run a load and watch for leaks. You could leave the door off until you are sure you screwed the cap in tight enough.
Posted on Jan 13, 2009
What is error code e04 bosch front loader washer
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
Nov 22, 2016 | Bosch Washing Machines
What is error code E04 on hoover washer
E:04" on the washing machine. Check to ensure there is no water in the tub. This is a common error often associated with too many suds blocking the pump. It is caused by using the wrong laundry detergent which is not designed for high-efficiency washers. You can adjust your use of detergent and reset the machine to eliminate the error code.
Read more : How to Reset Bosch Washing Machine With Error 04 eHow
Jun 21, 2015 | Hoover Washing Machines
What does fault code e04 mean
There are many brands of washers and the error codes are different.
What kind of washer do you have. Brand name and model number.
Open door and look around the frame for the model number.
Here is a link to e04 on a Bosch washer.
Repairing 04 Error on Bosch Washer
Sep 10, 2014 | Washing Machines
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
Jan 13, 2014 | Bosch Washing Machines
E04 Error
E04 is a time out on the heating phase, to confirm this run a cold cycle, if the machine completes the cycle but sticks on any program above 40 degrees, best bet it's a faulty heating element.
Nov 27, 2011 | Bosch Washing Machines
Machne not spining fast enough to dry clothes, clothes still very wet after spin cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Feb 19, 2011 | Washing Machines
We are getting error message E04 on our Bosch front loading machine and it won't drain and it makes a grinding sound.
We removed the round panel in the front and there was a knee hi stocking stuck in the filter - great advice - it's fixed and working perfectly.
Jan 03, 2010 | Bosch WFMC 2100 Front Load Washer
Washing Machines Logo
1,371 people viewed this question
Top Washing Machines Experts
