Question about Denon AVR-1906 Receiver
Unit starts to come on and then shuts off and the stand-by light flashes
I have checked the speaker connections and found that a couple were slightly loose. I tightened them but have found no improvement.
  • 463 Answers
By the wires being loose it sometimes blows the main power circuit.If you unplug everything from the back and it still does it you'll need to take it in and get it fixed..The main power circuit blew or the diode for the speaker power is shorted..
Posted on Mar 30, 2009
HDMI light flashing
Unit is in protect mode. Hold "advanced Surround" button and power switch for a couple seconds and it should turn on. If it turns back off, disconnect all your speaker wires and try again. If it still shuts off, the amp is bad and needs to go in for repair.
Apr 02, 2014 | Pioneer VSX-823-K
It keeps shutting of and the power light just flashes if there is too much bass? what do i do? the volume is low to begin with
Hello, the protect circuit is likely detecting a damaged speaker or speaker wire.Check the unit with one speaker at a time connected, or if you have an ohmmeter measure each speaker they should read approximately 8 ohms.When you connect a speaker thats bad the unit is designed to shut down and flash protect.
Jan 14, 2011 | Sony MHC-GX450 CD Shelf System
Will not light flashes code ignition lockout
The unit will go into lockout after a couple of attempts to start and fails. The most common reasons for this are the gas is shut off or not reaching the unit somehow, either the gas line in or the gas valve itself is defective, or you can also have an ignitor out. Depending on your model, you can have a ignitor the glows hot (hot surface), standing pilot, or spark (which you can hear sparking). Hope this helps.
Jan 01, 2011 | Coleman Heating & Cooling
Standby Output LED is flashing fast
This is the "protect" mode -- the unit has detected a short circuit in the speaker output and has shut down to keep from burning out the amp.
Remove the speaker wires, then reconnect one at a time. If the LED starts flashing again before you've connected any wires, then the problem is within the receiver.
If it starts flashing again when you connect a particular speaker, then the problem is in the wiring to that speaker or the speaker itself.
Sep 05, 2010 | Audio Players & Recorders
When I turn the unit on it cycles through its start up but turns right off. little red light blinking. I checked the fuses did the reset on the micro processor with no luck. I also detect a slight burning...
check your speakers for loose or frayed wires touching across causing ashort. if not , remove 1 speaker at a time unit the the unit stops shutting off. replace that speaker and you should be good to go!
Apr 20, 2010 | Denon AVR-1403 Receiver
Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
Apr 17, 2010 | Marantz SR4002
Unit only stays on for 4 seconds then turns itself off.
This is a short or unstable ohm load. Remove all speaker wire connections to see if the amp will stay on.
If the problem goes away when disconnecting the speaker wires try this:
1) Check volume level on zone one and zone 2 if connected. If it is too high the amp will go into protect mode and shut off exactly as you described.
2) Make sure no wires are touching any other wire or the metal surface of the amp. This will cause a short and send the amp into protect mode.
Nov 21, 2009 | Denon AVR-1705 Receiver
Cutting off and stayin in Stand by mode
To me it sounds like you might have blown a channel(s). The speakers that you are using with unit, did they come with it? If not you need to check the ohms of the speakers. It looks like the Onkyo HT-SR800 can only handle a minimum of 8 ohms. If your unit is under warranty definately send it in for repair
Jun 03, 2008 | Onkyo HT-SR800 System
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Power on problem
Time for a little repair here. It seems that one or more channels have developed an excessive drain on the supply, and has caused the threshold to trip and shut you down. It's more than likely shop time at this point....accordianman
Sep 03, 2007 | Denon AVR-2106 Receiver
Denon AVR-1906 Receiver Logo
193 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
