Question about Microsoft Windows XP Professional for PC
Windows XP Problem
Windows is starting but desktop is not showing and also taskmanager is not working
When i try to install windows xp pro. an ACPI porblem is occuring and same problem in installing Server2000 operatin system. I am very tens please suggest me.
Thanks & Regards
(My E-mail address is tripathi1amit@gmail.com)
  • tripathi1ami Oct 29, 2008
    This is very helpfull for students
  • 86 Answers
  • 1st Disable ACPI in your BIOS then you have three options, one remove ACPI from the device manager ore reinstall XP with no ACPI support.
The easy and safe way to disable ACPI from the device manager in XP. Just right click on it in the device manager, choose update driver, click I will choose the driver to install, and click on Standard PC. Reboot the PC and it will redetect all your devices.
A easy way to do the Fresh Install with no ACPI. When setup is loading, the blue screen will ask if you have any raid devices, and to press F6. When it does that, press and hold F7, & ACPI will not be installed.
The third way Just press F5 after the first screen asking if you have raid devices to install (will ask at bottom of screen to press F6) keep pressing F5 to the second screen where it will ask to press F2 for recovery console. Keep holding F5 and should get another screen where it will say that it cannot recognize type of pc. There you have two choices: standard pc and other. Select standard and voila no ACPI will be installed.
This should solve your ACPI issues and your devices will be assigned their own IRQ, disabing ACPI in WinXP affects power management etc...but it looks like you have no choice.
i hope good...
Posted on Oct 29, 2008
  • 3 Answers
If you got the OS cd, insert and boot from cd and try a repair.
or check for solutions in the solution range i used to fix similar problem from http://www.tinyurl.com/52mwor
source:
solution dictionary for fixing all pc problems on htpp://www.tinyurl.com/52mwor
http://www.digitalpowering.blogspot.com
Dear sir, my toshiba m45-s2652 has followsing problems: 1- i was trying to install windows xp sp3 and its was showing ACPI compliant problem. 2-I tried to restored original xp by dvd and now each time...
After insert the CD restart the PC and press F2 , F10 , F12 whatever is the case to change the boot order settings and select CD-ROM.Then start your installation from the CD-DRIVE.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 16, 2010 | Toshiba Satellite M45-S2652 Notebook
Dear Friends, My Toshiba Satellite M45-S2652 (PSM40U) is showing problem during windows XP/Vista/7/Even Windows ME installation. This system BIOS is not compliant with ACPI. Bios ver was 1.5 which upgraded...
Please go through the following Article if you are trying to install XP in the Compute. This should help you resolve the problem.
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q314830
Dec 06, 2010 | Toshiba Satellite M45X-S331 Notebook
Xp installation problem
Goto bios - disable sata operations and select hard drive type as normal, disable ahci, disable acpi
May 29, 2010 | Gateway T-6330U Notebook
Ibm 845 e motherboard problem
IBM Netvista PC is not ready for Windows XP, you should update its BIOS on its version so that you can install windows XP, maybe ACPI is not ready yet for this motherboard compliance to Windows XP, so download it at www.ibm.com
Jul 21, 2009 | IBM NetVista PC Desktop
Computer Freezes During OS's (both xp and vista) setup.
This sounds like a HAL problem, have you tried to intall by disabling ACPI. You do this by hitting F7 during the screen that asked if you want to install additional drivers. You hit F6 to install additional drivers and F7 to skip the ACPI check. You can also hit F5 to try one of the ACPI layers that comes up. If you hit F7, this disables ACPI silently, you never see anything come up. If you hit F5 a screen will come up with some options, use the arrow buttons to scroll through the choices as only three choices show at a time.
Jun 29, 2009 | Sony VAIO R-Series (VGC-RA718G) PC Desktop
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Desktop is not appering on xp sp3
Trying going back to before you have installed Service Pack 3 using System Restore (restart PC > let BIOS load > Press F8 > Safe Mode > When it asks you if you want to System Restore accept and load the date before you installed SP3. Try re-installing Service Pack 3.
Mar 03, 2009 | ASUS Computers & Internet
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
Feb 26, 2008 | Compaq Presario 700 470024-192 Notebook
Microsoft Windows XP Professional for PC Logo
197 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
