Question about Xerox DOCUMATE 510 Flatbed Scanner
Xerox Documate 510 Scanning via Print server
I have a Xerox Documate 510 Scanner that I would like to share over our network. Are you aware of any Print servers that would support this device since it does not function as a multi-function printer/scanner? Thanks!
  • Anonymous Jan 30, 2009
    The software CD shows a solution using Active Directory setup. But i have a windows xp network and do not have active directory. so i m also looking for a solution to this
4 Suggested Answers
SOURCE: Server is busy message
How I can remove the code LL-91 from my printer xerox 510
Posted on Aug 28, 2008
Arius
  • 446 Answers
SOURCE: Where to buy Power Supply for Xerox Documate 510
part number 70- 0497-100, you can buy this around 50$ , visit www.superwharehouse.com and provide this part number...
cheers dont forget to mark this pls
Posted on Sep 04, 2008
nyilasrobert
  • 627 Answers
SOURCE: Is there a Xerox DocuMate 510 driver download for
Hi there. Sorry to tell you, but there is no driver for Windows 7. Maybe, soon, Xerox will provide the driver.
Posted on Jan 06, 2010
Is there a mac driver for xerox documate 510?
The short answer is no. Very frustrating. For three years they have promised to develop it and now have chosen to discontinue any support for the 510 and instead tell you to spend several thousand dollars for a new Documate 3220 scanner.
No thanks - so long Xerox
May 16, 2012 | Xerox DOCUMATE 510 Flatbed Scanner
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
Where can I get ADF parts?
eBay: Find Xerox Documate 510 Workgroup Scanner w/ADF - PARTS UNIT in the Computers Networking , Scanners , Standard Flatbed Scanners ...
cgi.ebay.com/Xerox-Documate-510-Workgroup-Scanner-w%2FADF---PARTS-UNIT
Dec 03, 2009 | Canon imageCLASS D880 All-In-One Laser...
Issue installing xerox documate 510 scanner using windows vista
Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
Apr 07, 2009 | ScanSoft PaperPort Deluxe 9...
My Xerox Documate 510 adds a line from top to bottom down each scanned document. The line only appears when something is fed into the paper feeder and does not happen when scanned single sheet at a time on...
you probably have something on the scanning bulb when it goes through the feeder. The scanning bulb is directly to the left of where you use the flatbed. Clean that glass with a dry, clean cloth and you should be back in business.
Jan 11, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Images scan black via flatbed or auto feed
Check your software settings, Try Auto Brightness for scanning a white sheet.
S. Mohan
Nov 06, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Jul 23, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox DOCUMATE 510 paperport error
Have you tried going to the Xerox.com site and downloading the new drivers, software available there?
Sounds like there is some corruption in your file system.
Feb 20, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox DOCUMATE 510 Flatbed Scanner Logo
375 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
