Question about Compaq TFT5030 (Carbon, Silver) 15.1" LCD Monitor
No monitor power
My lcd monitor just turned off and now wont work,have changed the fuse in the plug still no it worth getting it fixed or would i be best getting a new one?
    Problem Solver:
I had the same problem with my technosonic, power leads lit up but no power to monitor. was about to throw it away when i realised my laptop lead would fit monitor, so as one last ditch attempt i plugged it in and lo and behold the monitor came on. so the problem was the power lead, even though it lit up and appeared to be working,not the monitor.
Posted on Jul 15, 2008
Monitor will not power on
The monitor has entered permanent sleep mode. After four years of service, it probably is not worth repairing
Oct 21, 2012 | HP W2408H 24-inch Widescreen LCD Monitor
There is zero power to the monotor. I tried a new cord and tried the cord from the monitro on something else. Cord works...outlet works...It is the monitor itself. The little round on/off button DOES NOT...
The monitor has a power supply problem, if you are very lucky it might be a fuse. To access remove back cover follow the power cord to the power module and there should be a fuse close by, if changing fuse fails, replace monitor "repairs not cost effective"
Jan 05, 2011 | LG L1920P 19" LCD Monitor
Viewsonic VX2035WM monitor buttons no longer working
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC and ALL monitors to get some ideas what goes wrong:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Apr 08, 2010 | ViewSonic VX2035WM LCD Monitor
Dell 1800FP monitor. Will not power up at all. Checked power cord on another machine, works fine. Monitor is from 2002, but was working perfect till yesterday. Is this worth fixing?
Take it apart and check the fuse. Sometimes is just a simple component damaged.
Have it checked in a specialist electronics house if you prefer.
Sep 17, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor times out and wont come back on.
Try this settings:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 03, 2009 | Acer AL1914 19" LCD Monitor
    HP Pavillion 170 no picture
    It sounds like it just died, it was a coincidince, that you were cleaning. There is no fuse,and 6 years is pretty normal if not great for an lcd. Even if you could send it back, it wouldn't be worth it, I sent back a 19 that only lasted aboy half as long, and just to pack and ship it was $70.00. You can get a 19 inch replacement from for under $150.00. More than likelly if you checked the connector going into the monitor and both that and the end going into the computer, you blew the main board. not worth fixing. By the way, if you sprayed the monitor with a cleaning solvent while connected, that may have caused the problem.
    Feb 02, 2009 | HP Pavilion F1703 17" LCD Monitor
    No image
    Sounds like the monitor power supply may be faulty or noisy - most probable cause is that it needs the capacitors changing. If it has an external supply try changing it as that is a cheap fix worth a gamble - if power is internal then change the monitor.
    Jul 23, 2017 | Samsung SyncMaster 930BF 19" LCD Monitor
    VX900, Backlight Works, But no picture.
    It is impossible to see defective components visualy, unless there was a serious burn-up or something like that.
    Without at least a DVM you cannot even verify if the power supply is functioning properly!!!
    There is no support at the component level service for these monitors. The service tech will change the main input board to solve the fault that you have. If the back plane lamps are failed, he will change the power supply for the back plane lamps. In some of these models, the back plane lamps are not replaceable. This means that the screen would have to be replaced.
    If you want to service the monitor the non supported way, call Viewsonic and see if they will sell you a copy of the detailed schematics, and engineering data for the boards. Most monitor companies will not sell any schematics or service information to no authorized contractors for their service.
    If you can have the details, get a digital scope, a DVM, a logic analyser, and start troubleshooting according to the service manual. This can involve hours of work to figure out the fault. Then you will have the task of seeing if Viewsonic will sell any of their proprietory EPROM's or processor type parts.
    This is why when the warranty is finished on these monitors, they are not worth to send back for service. The shipping cost, plus the parts and labour can come out to more than the monitor is worth!
    Jerry G.
    May 18, 2008 | ViewSonic VX900 19" LCD Monitor
    Compaq TFT5030 (Carbon, Silver) 15.1" LCD Monitor Logo
    124 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Lee Durbin
    Lee Durbin
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
