Question about NetGear WGT624 Wireless Router
How to connect HP JetDirect 600n to WGT624 Router?
I have an old HP laser jet 8000DN, would like to connect to the router so I can print wireless from my laptop. Thanks.
    Genius:
  • 1,124 Answers
In that case you need a printer wireless server
Posted on Oct 29, 2008
  • Pablo Csaky
    Pablo Csaky Oct 29, 2008
    1. Make sure the print server is a wireless print server.
    2. Determine to which type of port your printer connects. Most modern printers connect directly to a USB port, so a print server with a USB port is a safe bet in most cases.
    3. Purchase a print server with enough ports to accommodate all of your printers.
    4. Check the security features supported by the print server.
  • Pablo Csaky
    If you need due the age of your printer you can set an adapter to make the connection from the printer to a wireless printer server.
I have a HP WINDOWS 7 64 BIT laptop...just purchased a HP 4050TN laserjet Can't see printer if connected to wireless router OR if I hardwire between laptop and jetdirect 600N adaptor on printer
You need to connect the printer with a cable to the wireless router. Then you must enter the printer menu and set an IP address, subnet mask and gateway corresponding to your NAT network or switch the DHCP option on (e.g. to get them automatically from the router). I suggest you to enter them manually if you are not going to switch the printer every day. Then in Windows 7 you must go to devices and printers, select Add printer, select local prinet and choose TCP/IP port from the list. After clicking next you will be asked for the IP address of the printer, you fill the one you entered in the device menu. Next you will be asked for the printer model and you must select it from the list or show a location with the driver. Click finish and a test page will be printed. Hope this helps. Alex
Sep 13, 2011 | HP LaserJet 4050tn Printer
I want to connect my HP P2015 Laser Jet printer to my Dell Studio XPS deskto computer for wireless printing. What to I need? Thank you.
Your printer has an cable/wired ethernet connection. To use it wirelessly, you need to purchase a wirless print server from HP.
HP Jetdirect Fast Ethernet
embedded print server
(RJ-45 port) for flexible
networking (standard on
the P2015dn and
P2015x models only)
http://www.hp.com/sbso/productivity/howto/it_networkprintserver/basic.html
Jun 12, 2011 | HP LaserJet P2015dn Printer
After moving to a new house/ new state, I can not get my HP 2035n to connect wirelessly to the router. It will print from any of our computers, but must stay connected to the router. I can find no...
The HP P2035N doesn't have a built-in wireless ethernet connection. It has a wired ethernet port. To connect to a wireless router, you need the HP Jetdirect ew2400 802.11g Wireless Print Server or the HP Wireless Printing Upgrade Kit or a similar device (note: not all third-party wireless print servers will work with the HP printer). Did you have something like this and misplace it during your move? If you did, try to find the print server to use the wireless option. Otherwise, continue wired ethernet option since it is working.
HP support for the printer (manuals, set up infomation, and drivers) is available here: http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3662025&lang=en&cc=us .
I hope this helps.
(HP models with a W at the end of the model number have wireless capabilities without any additional hardware.)
Apr 30, 2011 | HP P2035N LaserJet Monochrome Printer
Trouble with wireless connection JetDirect ew2400 on Dlink DIR855
I found that the EW2400 Jetdirect will not work UNLESS you use WEP security. I have tried several times setting up using the WPA, but with no luck. Once I changed my wireless router to WEP and configured the EW2400 with the WEP settings, it worked with no issues - hope this helps
Jul 22, 2009 | HP Jetdirect 615n Print Server
Need to install network printer to DLink Router
It has been a few months, so you probably have resolved this -- but just in case someone else is looking to find out the IP address on the internal print server of an HP Laserjet 4000n printer so they can set it up on their network, here are the steps to find the IP address on the HP JetDirect internal print server:
1. Have the Ethernet cable plugged in to the router and the JetDirect 600n card and power it on.
2. Make sure display screen on printer says "Ready".
3. Press the Menu button on the printer until you see Information Menu.
4, Press the Item button on the right (+) side until you see Print Configuration page.
5. Press the Select button and a configuration page should print.
One page is the printer's configuration and the other page is the print server configuration page. If you have a good JetDirect card, and good connection to your router, the IP address of the printer, plus its subnet mask and default gateway should be shown on the EIO configuration page.
If the printer has been manually set with a static IP address, subnet mask and default gateway that will not work on your network, you will see the settings will indicate "Configured by" User Specified.
To clear those settings and allow DHCP setting, perform a cold reset on the JetDirect card, by powering off the printer, holding down the green "Go" button and powering it back on until you see "COLD RESET," let go of the green Go button, wait a couple of minutes, then run another configuration page to see the freshly assigned DHCP address of the print server.
Hope this helps someone.
Mar 14, 2009 | HP JetDirect 600N Print Server
PROBLEM CONNECTING
check on netgear's website but if i remember correctly your router, wgt624v2, isn't compatible with vista. i had to buy a new updated router, wtg624v3, last year for that reason.
hope this helps...
Sep 23, 2008 | NetGear WGT624 Wireless Router
I can not print when I connect to my jetdirect print server.
Hi, sorry for late answer, I have been offline for a while.
Connect RJ45 to router and parallel to computer
You need to download Software here first selecting 300x and windows version.
Then you can use the HP JetDirect Wireless Setup Wizard
to setup your printer on network.
You may also be required to install printer drivers, to do this use printer CD or download them from the Internet.
Regards
May 01, 2008 | HP JetDirect Print Server
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
141 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
