Question about Behringer POWERED MIXER, 20 CH, 400 WTS AMPLIFIER => Model PMX5000 Car Audio Amplifier
BEHRINGER EUROPOWER pmx 1000
When turned on lots of "popcorn noise appears"
Seems to be related to the Voice Canceller switch.
Do you have any experince with this problem. Any idea as to where to get parts?
Thanks Claus Henriksen
604 886 1980
Canada
  • Behringer Master
  • 5,603 Answers
The voice cancellor switch basically subtracts the left and right signal because the vocalist is usually centered... The noise would likely be in an op amp associated with this feature...
Compare your circuit to a PMH1000. On that unit first thing to check is the two electrolytic caps at the left and right noise cancellor outputs.
There are a wholle bunch of resistors and IC's 48,50,37 are all involved.
Troubleshoot this one with freeze mist (ccircuit cooler). The problem should show up easily by heating and cooling.
Posted on Jun 04, 2010
How do i hook up my laptop and my tablet to a behringer Europower PMX 2000
Easy to do - just get a patch cord that has a stereo 1/8" plug on one end and two phono (RCA) plugs on the other end. Plug the phono plugs into the "Tape IN" jacks on the mixer and use the "Tape" volume to adjust the sound level. It's best to turn your laptop or tablet volume up to maximum, then adjust the volume on the mixer.
Jan 15, 2015 | Behringer Audio Players & Recorders
All light blinking
Fix the short. It appears the 15 neg supply supplies the LEDs. If you need the service manual try: http://www.eserviceinfo.com/index.php?what=search2&searchstring=behringer+pmh+3000
Jan 27, 2014 | Behringer PMH3000 - EuroPower 2 x 400W...
My behringer europower EP2500 poweramp has a bad hiss on channel 2 What could this be?
There is a possible noise build up on your CH2 due to failure or weakness of the LCR network of the preamp circuit. It could also be a noise within any semiconducctor or the preamp IC. Unless you can do a signal test with the elimination of the input to the output amplifier, the fault will not be say to isolate. Hence if youarre familiar do the test by approching from the output amplifier's input, proceeding to the main input where the faulty section can be identified. Hope this helps. Good day
Jul 18, 2010 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 trips immediately when turned on
Power supply section is overloading probably because of audio power amp problem.
Paul
Mar 31, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer pmx 2000 missing knob
If the shaft broke, then you will have to replace the whole encoder for it. You cannot glue a shaft and expect it to hold.
Mar 17, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Have Beringer Europower PMH 1000
The clicking could be the protection relays kicking in and out.
Check your speaker cables for short circuits.
Also make sure that the load you are applying to it does not go below the minimum impedance which i believe is 4ohms on this unit.
Mar 10, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer pmp2000 europower no sound
Probably the power amp has arced and popped a lot of components.
When teh amps go usually the final pwer transistors, their drivers and sometimes even the power supply gets zapped.
Check the output of the preamp at the inserts for the final amp with headphones to see if anything is coming through.
Jan 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer PMX 2000 Amplifier
Hi aliciacarol,
The best place to go to get parts for Behringer parts I have found is straight to Behringer themselves, or an agent nearest to you. They are generally inexpensive to buy, and delivery are better than most. Steer your way to your nearest agent to you from the map . If you have any troubles, feel free to get back to me here. Good luck, thanks for using FixYa
regards
Graeme
Feb 23, 2008 | Behringer EUROPOWER EP2500 Amplifier
Car Audio & Video Logo
1,767 people viewed this question
Top Behringer Car Audio & Video Experts
xxxxxx xxx
Are you a Behringer Car Audio and Video Expert? Answer questions, earn points and help others
