Question about Car Audio & Video
Sony xplod xm 2165gtx problem
I have a 1000watt sony xplod xm-2165gtx. it was working great untill i went to switch it to my new car. it was running fine and when it was working it would have a green light.  now that i have moved it over it has a red light and i dont no what is wrong i am pritty sure that i hooked it up right and the same way. please help
Ive had that problem it is more than likely ur ground get a god ground scrape paintof surface were ever u ground that should fix it nathan ordoyne louisiana
Posted on Apr 13, 2010
Try turning on the radio
Posted on Oct 30, 2008
How to hook up my sony xm-2165gtx
You need a splitter box for both ground and power wires
Now always up size the wire coming in, and lower gauge going out.....
for remote wire simply split the wire......
Do not do that for your ground and power wires you will start a fire, get the blocks
Hope this helps...............
Feb 14, 2011 | Sony XM-2165GTX Car Audio Amplifier
Have SONY Xplod 1000watt dual ch. amplifier pushing two 12" MTX Terminators. About a week ago my my Sub on the right side quit working, while the left side sub is still banging hard as ever. I...
Check your subwoofer for resistance. It is more likely you blew a sub than a channel on the amplifier. If your subwoofer has no resistance, which can be checked using a multi-meter, then it is blown.
Jan 17, 2011 | Sony Xplod XM-1652Z Car Audio Amplifier
XM-2165GTX Car Audio Amplifier: i have a kenwood 1000watt amp model # kac-7204 i h...
I would try to remove the top cover of the amp and you might be able to push them out from the inside. Just a shot in the dark.
May 16, 2010 | Sony XM-2165GTX Car Audio Amplifier
I have a sony 2/1 channel power amplifier (XM-2165GTX) that will produce sound untill my pioneer headunit (deh-3050) hits 25 in volume..the sub then goes into protection mode and will not turn off..not...
Not enough power going to the amp..?
1) Your negative ground wire needs to be in a better spot.
scrape paint from the grounding surface.. This will ensure better contact between the negative power wire terminal and the vehicle ground.
2) Get thicker wiring cables.. for Positive, and Negative
3)Turn the gain right down.
Jan 12, 2010 | Sony XM-2165GTX Car Audio Amplifier
Light goes on everything is pluged in and no sound comes out
check all ur connection on ur xm and ur antena too. the antena needs to b on the roof. it wont work if ur in a garage test out on the open
May 26, 2009 | Sony XM-2165GTX Car Audio Amplifier
My xplod amp gets power
If the power light is lit and the amp is not in protect mode, the power supply is probably blown.
Have you confirmed that you have a good signal reaching the amp and that the speakers are not blown?
Aug 10, 2008 | Sony XM-2165GTX Car Audio Amplifier
1000 watt amp sony xplod
That's not a 1000w amp. It's a 400 watt amp when loaded to it's lowest rated load. If you have one speaker per channel (the only safe load if you have single 4 ohm coil speakers), you're only getting 165 watts/speaker. It's probably distorted because you're driving it to clipping.
Jan 01, 2008 | Car Audio & Video
Amplifier, not as loud, getting quieter
Have you tested your speakers yet? They will sometimes age and cause a problem.
Apr 24, 2007 | Sony XM-2165GTX Car Audio Amplifier
Car Audio & Video Logo
229 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
