Question about RCA HD52W59 HDTV Projection Television
Tv powers on then off
My television powers on and then turns off I can power the tv back on after about a minute. I took off the back panel and I have sparks arching on the under side of the board in the middle of the board. Do I have to replace the board or can it be repaired. If I need to replace do you know the part number?
  • michael9803 Oct 29, 2008
    Thanks for the help
    Genius:
  • 1,030 Answers
Whch board the one on right the one on left.. i would suspect the one on left. called the power deflection board,.. depending on the component that is arching. as a technician i might could do component repair if you have no technician then board replacement may be nessary depending if the traces or the board is burnt through. to correctly identify the board you need to know they entire model number which includes what is known as ext number. it will be sort of like hd52w59yx1 this number can be found in smaller letters on the back sticker with the larger model numberl. this number has to be exact to get the right board
Posted on Oct 29, 2008
Polaroid tlx 04244b
Loose contact to input power point. Replace the power input socket. Contact any service technician. Gopakumar Gopalan Google
Feb 21, 2014 | Televison & Video
Does not turn on anymore. black screen and red led blinckiing... samsang le40a552p3rxxc
You likely have the infamous Samsung capacitor problem. A capacitor(s) on your power supply board has failed, or is failing. Youtube has several videos (search "samsing capacitor) that are generic to Samsung TVs, showing how to identify and replace the failed capacitors with parts that are readily available. What it takes, more than anything, is soldering skills. I own the exact same TV you have (P3F variant), and have fixed it. I'm an electrical engineer with the parts available in my basement, but for me, the fix took about 15 - 30 minutes with the most time removing the back cover, plus if you don't have the parts, a trip to an electrical parts store or Radio Shack, or an order to DigiKey (less than $10). Some have reported that haranguing Samsung customer service brought free fixes even though the warranty has expired. If all else fails, I'd be willing to repair your power supply board, but you'd have to mail it to me and I'm not sure how contact info is passed on Fixya.
There is the possibility that your main board is what is bad, but with Samsung sets, the problem is most always the power supply. Inspecting the power supply for capacitors that have either leaked liquid or have bulged, points to the power supply.
Jan 19, 2011 | Samsung Televison & Video
32" polaroid lcd tv has picture for about 1 minute then smoke rolls from back of tv took back off found no wires burnt only smokes
Now,turn on the tv again describe what the cause now like power LED light indication flashes or no power at all or have sound no video.Tell me the current cause of the tv now,so i will tries diagnose the problems and help u to buy refurbishes boards to fix it.
Oct 13, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
52'' Sony Bravia will not turn on
Its fixable problem like power supply board replacement will solve the problem.
Unplug tv from wall socket for couple of minutes, replug back in and turn it On.
If problem still exist then most likely power supply got fired and will be replaced, local tv repair shop will help you to replace power supply board.
Thanks.
May 02, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
My tv power box is making a loud noise
good day brend, hi, my suggestion is unplug the TV and call your dealer/service shop for repairs, the loud noise could be high voltage arching which prolonged may lead to high voltage sparks and fire.
Jan 19, 2010 | Televison & Video
When i turn the power on there is a high pitch sqeal and ozone smell. then the power goes off
If there is an ozone smell, that usually indicates arching high voltage which should also be visible through the back cover vents (or back cover removal-better yet) if arching (blue sparking) is observed it is usually on the left side -back - rear and is likely the flyback transformer that has a crack in the casing - check there first- if the source of arching is identified post back here with details.Caution since High voltage is present.
Oct 14, 2009 | RCA F36444 36" TV
TV fell over, took a hit on top, no picture
Sorry to hear this happened but you most likley you craked the panel.The only other thing I can reccomend is to remove the back cover and inspect for arch marks on the inside of the cover.If I`m not mistaken that is a metal cover, and i could be arching to one of the internal heatsinks.
Jan 20, 2009 | Panasonic TH-42PX60U Television
Westinghouse W33001 Will not power on
I had that happen to my tv and took it to be repaired and it was the power pack where it attaches to the tv it just like snaps on and will arch and burn the power pack and it wont power on so the repair guy charged me $89 parts and labor he put one in but sodered it so it will not draw moisture and arch and it works great now....
Aug 25, 2008 | Westinghouse W33001 30 in. HD-Ready LCD...
Rca tv picture blurry and arched up at bottom
Replace the Sanyo I.C. chip on the heat sink of the power supply convergence board STK730-XXX. Last 3 could be 130/010/020, any will work.
http://www.electronix.com/catalog/product_info.php/cPath/6_308/products_id/9541
Sep 20, 2007 | RCA P60921 60" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
