Question about RCA D52W19 52" Rear Projection Television
Problems with 52in HDTV
TV comes on, but everything is in 3D. Does this mean the picture tube is bad? What is the problem and how expensive would it be to get it fixed?
  • honeygale2 Oct 29, 2008
    my television does not have the convergence or autoconvergence option. what else can I do?
  • mrod1 Jan 20, 2009
    I also have screen when turned on looks like in 3d does have auto converg. but no longer works. Looks like its going to but screen still looks the same
    RCA D52W19 52
  • 905 Answers
This a projection television! and it does have conversion IC's and settings!
but if you never went into the settings and never changed anything then resistors on the conversion IC's chips are bad and you may also need new conversion IC's
this will show you that you do have conversion
http://tv.rca.com/RCATV/RL/D52W19SS.pdf
Posted on Oct 29, 2008
  • jason Oct 29, 2008
    and a matter of fact is that yours is an auto conversion
    Genius:
  • 1,030 Answers
NO this is a condition known as convergence problems. first question in menu then go to setup and see if the option of convergence is in the menu. is the picture bowed in from the top and bottom. do you have the option of autoconvergence. does it work and how far does it get. there is a common problem with these sets. and may be a simple fix if you can solder a part. so let me know and we will continue to troubleshoot.
  • Willie Howell Oct 29, 2008
    The itc222 chasis or t d52w59 Does not contain the standard convergence chips. Since you do not have the convergence option under the. i would suspect that you might have what is known as the fl231 fuse problem. i have wrote a article on this problem. it is quite common and i see it all the time at the shop. look under my profile in tips and tricks for the fl231 article. if you can solder this can be a simple inexpensive repair
    if you do not have this convergence option then i would almost gaurante you have a blown fl231 fuse. this little special fuse can be bought at union electronics or anywhere that sells parts for rca. Consult the fl231 poblem under tips and trick section of my profile for detailed instruction for repair. If you are not electronic tech. try to find one someone that can solder,,, we charge at our shop 150 for something that is as easy as 5 dollars and no more than an hour
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
My Mitsubishi 1080HD model WS-55315 colors are not correct. The blue is good and the green seems to be, everything else seems to be a shade of light brown or tan. I thought maybe the red tube was bad but...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines like R,G,B mis alignments,also tv have any colors shaded shadows pictures or a 3D pictures look alike?Yes,than the tv have a convergence board problems and it is dead to causes all of these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops repair a DLP tv convergence board will cost u like $300-$350 for parts an labors.
Sep 12, 2011 | Mitsubishi WS-55315 55" Rear Projection...
My Panasonic television has shadows on every image displayed. I have heard it could be something as minor as a tube, and they are not expensive to have replaced.
Ur tv is a DLP projection tv?Yes,than this tv have a problems known as a convergence pictures problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board is it dead,to causes this problems.The tv convergence board must have it parts to be replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 10, 2011 | Panasonic TH50PZ80BCAB 50 in. HD-Ready...
Everything looks out of focus and the color hue is really bad. how can i fix this
Tv have a problems known as a convergence problems.The tv convergence board it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to fixed the tv convergence board to solved the tv convergence picture problems.U have all the tools and also can do ICS chips soldering?Yes,than tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a tv convergence kit that belong to ur tv make and model and repair it ur self.Or the shop will cost u like $300-350 for parts and labors.
May 07, 2011 | Mitsubishi VS-50605 50" Rear Projection...
Hello, when I connect my Wii to a Samsung 3D plasma tv I get a black and white (non-crisp) picture but I do get sound. When I do the same set up on a tube tv everything works. I tried the set up on...
a 3D tv is another form of an HD TV, you need the Wii HD cable to play it right, and make sure you plug it into the HD ports on the TV to get the color and sound back.
Sep 12, 2010 | Nintendo Wii Console
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
Picture display
The digital convergance is going.In Canada it's a $450 repair which is not worth it
Sep 28, 2009 | Philips 43P8341 43" Rear Projection...
I think my picture tube is going out on my Zenith System 3 Tv
Hi, Sorry it took someone so long to get back to you, but nobody likes to give bad news. This tv has a 1.7R tube with 530 resolution and an NTSC tuner which means it is analog and with the new change this month you would need a converter box anyway unless you have cable or satellite. Because of this particular tube and the labor to change it, it would indeed more expensive to replace it than buy a new one. Best of luck to you!
Jan 24, 2009 | Zenith C27A24T 27" TV
3D Looking Colors
yes its most likely the STK392-110 ICs change both at the same time. You can get replacements at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 31, 2008 | Panasonic PT-53WX54 53" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
158 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
