Question about Pride Mobility Products Jazzy 1170 XL Plus
Removeing Jazzy 1170 wheel
How do I remove the rim from the axle of a Jazzy 1170? Will I need a gear puller?
Matt
  • 118 Answers
Yes, you need a puller:
1 Remove the Nylock nut and washer (3/4 socket)
2 Pull the wheel with a 2 tooth wheel puller
Posted on Nov 29, 2008
How to replace rear axel wheel bearings on 97 ford explored
You will need an internal bearing puller. You will have to remove the rear axle by pulling off the differential cover. Then remove the bolt holding the spider gear cross shaft in place. Remove the shaft and spider gears. If your tire is already removed and brake drum is off, push in the axle and remove the circle clip. Once this is out you can slide your axle out you can remove the backing plate for your brakes and get to the bearing. Pull the seal out and pull out the bearing with a puller and slide hammer. Install the new bearing by hitting on the outside race ONLY. Install a new seal and install in reverse order.
Nov 01, 2012 | 1997 Mercury Mountaineer
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
Hi i was after the process for replaceing rear wheel bearings on a 1994 jeep cherokee thanks
You need to remove the tire and brake drum. After doing that, remove the cover from the differential and remove the roll pin or bolt that retains the cross shaft in the spider gears. slide the cross shaft out then push the axle in and remove the C retainer on the axle end. The axle can then be removed. Use a bearing puller to remove the bearing, then remove the seal. Reverse process to install.
Be careful if turning the gear set after the pin has been removed. If you turn it and don't pay attention, the spider gears can fall out.
Feb 04, 2011 | 1994 Jeep Cherokee
How to replace rear wheel bearing on 2003 hyandia sonata
Hub & Bearing Removal & Installation To Remove:
  1. Release parking brake.
  2. Remove rear wheel assembly.
  3. Remove rear wheel speed sensor from carrier.
  4. Dismount brake caliper and support with mechanic's wire.
  5. Remove brake disc.
  6. Remove 4 axle hub mounting bolts. Special tool 09432-11000 (Typical) hyundai-08-00-6021.gif
  7. Using tool 09432-11000 (or suitable gear puller), remove tone wheel.
  8. Remove carrier.
  9. Remove stakes and remove flange nut.
  10. Support bearing outer race flange and press rear axle hub out.
  11. Using tool 09432-11000 (or suitable puller), remove inner race from axle hub.
To Install:
  1. Apply thin coat of grease to bearing contact surface and hub.
  2. Using and appropriate tool, press bearing into hub. CAUTION
    Do not press against outer race of wheel bearing.
  3. Install flange nut and stake nut until it meets concave portion of spindle.
  4. Install carrier.
  5. Use an appropriate tool to press tone wheel.
  6. Install hub/bearing assembly with rounded portion of outer race facing up.
  7. Install 4 hub/bearing assembly bolts and rotate hub to seat bearing.
  8. Measure wheel bearing starting torque with a spring balance or equivalent device.
    • Starting torque should measure 15.9 in lb (1.8 Nm) or less
  9. Install brake disc.
  10. Mount brake caliper.
  11. Install rear wheel speed sensor to carrier.
  12. Install rear wheel assembly.
Oct 28, 2010 | 2001 Hyundai Sonata
How to Replace rear wheel bearing
first remothe the diff cover and drain, find the bolt that retains diff gears and remove then remove pin holding the diff gears, at this point do not rotate any part at all, axle or crown, push axle inward and remove c clip holdin axle in, pull axle out and using a bearing puller remove bearing, lubricate new bearing and install using new seal, examine axle for damage to bearing contact surface is good install , reverse procedure to finnish and fill rear end with new oil
Sep 16, 2010 | 1998 Chevrolet S-10 Pickup
HOW TO REPACE REAR WHEEL BEARINGS
To replace the bearings, you need to first remove the axles by removing the diff cover, taking out the small bolt or drift pin that holds the spider gear shaft in place, removing the shaft and pushing in on the axle to remove the "c" retainer on the axle end.
You can remove the bearing by prying it out using the end of the axle or by using a puller made to do that. Install is the reverse of removal. Don't forget to re-fill diff before driving!
Aug 10, 2010 | 1992 Jeep Wrangler
How do you remove the rear axle to change the axle seal, from a 2004 Coloraro?
remove the center cover facing the rear of the truck. you will see side gears with the shafts axle end at each side gear. a C clip will have to be removed from each shaft at the end of each axle. Then remove the wheels and pull out the axles
Feb 06, 2010 | 2004 Chevrolet Colorado
Replace front left wheel berring on 2002 GMC Yukon
do not replace only the bearing. replace hub assembly. remove rim/tire , remove caliper, mounting plate, rotor. . un bolt hub assembly, unplug abs. remove front axle nut if 4x4. you may need to rent the axle nut remove kit and hub puller. pull out hub. drive axle reward out of hub. install new part. do not torque hub over 90lbs. check with parts sell for spec
Jan 03, 2010 | 2002 GMC Yukon XL
How to change lower ball joint
u need 35mm nut socket to remove wheel nut then remove brake caliber and rotor then you to with a gear puller pull the wheel axle from cv shaft ,then remove upper and lower ball joint nut with ball joint fork start banging with hammer or airtools
Dec 21, 2009 | 2000 GMC Jimmy
How do i remove the axles from the rear diff of a 1990 subaru leg
This a fairly simple task,you're going to need a set of roll punchs to remove the pins that hold the axles to the differential.You need to remove the large nut(32 or 36mm) that holds the end of axle in the drive hub,the nut may be punched or "staked"into the grove of the axle end and can usually be pushed out with a cold chisel .On the diff end of the axle there will be a large pin holding the end of the axle to the differential,knock the pin out,you should be able to push the end of the axle off the differential drive splines,if there is not enough room to get the end off you'll have to separate the bottom ball joint from the spindle housing,remove the drive hub to brake rotor bolts and use a large three arm gear puller to pull the drive hub off the end of the axle,torque the puller lightly and tap the the end of the puller push shaft and apply another small amount of torque to the puller,so you don't damage the hub,once its off you may lightly tap the end of the axle,use a piece of wood between the axle and the hammer and the axle should slide out the wheel bearing fairly easy.I based this off axle removal on an 88 XT and 84 Wagon so there may be a few differences,but I think you'll find its actually fairly easy,if you run into problems go register at autozone.com and they should have an on-line repair guide.
May 17, 2009 | 1990 Subaru Legacy
Pride Mobility Products Jazzy 1170 XL Plus Logo
148 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
