My Iomega eGo hard drive will mount on a Mac G5 and let me copy to the mac, but when I try to copy to the Iomega Hard drive it gives me a message saying "The item "file name" could not be moved because Iomega cannot be modified. What gives? When I GET INFO on the Iomega drive I noticed that the premission is for read only. How do i change that.
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
I recently bought a 500gb Iomega eGo portable drive - I intended to use it as a back up and for 'work in progress files' for files from my Windows XP lap top and my mac G5 and prefered the idea of firewire for higher transfer speed - Since the drive is formated for the mac it works fine using firewire on the mac but didn't show on the PC at all - I re-formated the drive on the mac using Disk utilities using the FAT format - The drive now seems to work fine on both machines.
Gary Thomas
I am having the same issue. But the problem is that I have quite a few files already on the hard drive from my PC--so I DO NOT want to format it, because I do not want to lose the files. But I can not get the files onto the mac, due to the read only, and it will no longer even show up on my pc!! What can I do??
I can't put files on to the iOmega from my MacBook, with Mac OS 10.5, as listed as 'compatible'. It says that the contents cannot be changed, and the thing is listed as 'read only'. WTF?
I had that problem today with a brand new Iomega eGo portable, and my Mac genius told me that it's a given that you must "bless" a Mac. That means you must reboot anytime you install a new device. So, I did that, and the Iomega works fine, now.
Hope this helps.
GintGotham
pics on how to open iomega ego portable
The portable drive is not displaying an icon in the disk drive options to be able to save documents
