Question about Daewoo DTQ-26S1FC 25" TV
TV shuts off
My tv shuts off after 15 minutes. Turn it back on and it stays on for another 15 minutes and it will keep doing the same. I think it has to do with the timer circuit, ie.. "sleep mode". Any ideas?
  • 1 more comment
  • ramangireddy Jul 10, 2008
    Mine is also Daewoo,it was shutting down after 1 hr
  • Anonymous Oct 09, 2008
    i have one that stays on for awile(1-4 hrs) then turns off then you can turn back on after a few minutes then doesnt do it again then it might..
  • Anonymous Mar 14, 2014
    My TV turns itself off and on whenever it wants
    Day or night. How can I just shut it off. Because I don't use the sleep mode.
  • 68 Answers
There are some capacitors in the power area that need to be replaced. open the set and do some checking there and I am sure you will find the problem. good luck
Posted on Apr 08, 2007
SOURCE:
MY ILIVE SOUND BAR KEEPS TURNING OFF WHEN WATCHING TV
I'm having the same problem. I don't think it has anything to do with the Sleep settings, you can play with them all day & the only benefit you may get is forcing it to stay on for 90 min or whatever instead of 15.
(I've tried setting to 00, obviously the first thing that comes to mind is that it's a Sleep Setting issue, but I seriously doubt this. You can't even set the Sleep Setting to 15min anyway)
Instead, I'm pretty sure that the problem exists in the sound bar not recognizing that there is an active signal & is shutting off due to what it sees as inactivity (timing out after use). I've come to this conclusion due to multiple complaints of the same problem.
Some people are reporting that it's not happening when they watch movies, others have tested & said the radio stays on as long as you like, a couple people have posted that theirs works fine & only shuts off when they turn off about 15 minutes after they shut off the audio source, which leads me to think that this is what is going on, the system thinks the audio source (TV, Bluray, etc) is off & no sound is coming through. It must have a funny way of detecting it...
I will try a few tests & if anything works I will pay the results. One person claimed there's stayed on after turning their TV all the way up... I could try this but will have to turn TV speakers off (currently I am running both TV speakers & sound bar). Anyway, I'll keep digging, must be some way to get this to work, I hope...
Jan 20, 2013 | iLive ITP582B Soundbar iPhone Dock
TV comes on, but shuts off after 3 minutes. I must wait at least 5 minutes to get it to turn back on again. TV will ONLY stay on if DVD drawer is OPEN!
dvd is overheating its circuit. Keep the tray open to dry up condensation. then leave TV on standby to keep moisture out.
Dec 07, 2010 | Toshiba MD13N3 13 in. TV/DVD Combo
Toshiba 27af45 turns off by itself every 15 minutes..how do I fix
I think the timer setting in your TV is broken. Try fixing this.
May 07, 2009 | Toshiba 27AF45 27" TV
Sony 36xbr800 shuts off on own
sounds like one of your color tubes or a system board is failing and will have to be tested and replaced by repairman
Feb 11, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV Turning on and off by its self
You have problems with a condenser that allow the power supply to maintan an acceptable level of voltage in order to keep the TV on. take to a tech to be fixed. unfortunatelly, this problem needs a tech to take measures in the circuitry to find the component that causes the problem.
Nov 06, 2008 | Philips Magnavox TS3260C 32" TV
Sony LCD Projection TV turning OFF!!!
I also have a Sony KDF-42WE655 42" Lcd television. We just changed the lamp (bulb) several weeks ago and has noticed that everytime we turn on the television it stays on about 30-40 seconds then cuts off. After about 15-20 seconds it cuts itself back on. Weird!! It must have something to do with changing the bulb!?!?
Apr 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
Tv shuts off
When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times. during 15 mts of your sitting do you get sound & less brightness then problem in video or luminance section. if picture is dim & color will fade in and out at times then possibility of crt is getting less voltage on g2. if set is old then there is a possibility of crt getting weak. but if the above things are not there then problem in power supply. good luck
Sep 22, 2007 | Mitsubishi VS-55707 TV
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Daewoo DTQ-26S1FC 25" TV Logo
182 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
