Question about Philips HTS3400/37B System
Home Theater Philips HTS3410D Audio problem
I just got this installed and found out that after playing (either DVD,CD, or FM radio) for about 40 minutes or so, the sound suddenly got lowered automatically before being shut off. If I turn it off for about 12 hours or so, I can restore the sound but the same problem emerged again. Could you please help
  • 3 more comments
  • Noahmom Dec 06, 2007
    My system just shuts off (does not power off) the audio quits working. It does not seem to have a regular interval. However we have gone through and made sure the sleep timer is turned off. I replaced the cooling fan because the previous one was squeaking really bad.
  • richiespain Jan 08, 2008
    had my system for 2 years, just started to switch off, then about 1 hour later swiches on. It does seem to get hot, does anyone know if the fan should be on all the time or just when it gets hot?
  • SamsungQ Feb 07, 2008
    iI have the Samsung HT-DS610 and it just stopped working one day. The screen reads "PROTECTION". Can it be fixed? If so, how?
  • lucky000 May 07, 2008
    i m also having same Sound problem with my Philips Home Theatre 3410 D. The sound automatically goes down and then completely gone.....
    Plzzzzzzzz help me out....
  • Anonymous Apr 17, 2009
    I thought my DVD system was haunted. I use it as surround sound for my television and frequently it will shut off with no explanation. I'll turn it back on and it's normal again--no overheating or remote control interference.
I opened mine up and installed a different fan that i got from a computer system. It seems to work just fine now. I can watch it or listen to it at full blast. It seems to be that the system is overheating. Not sure what the previous fix post was about. aka "IC"...not sure what he is talking about. My fix seems to have worked however.
Posted on Mar 18, 2007
  • 38 Answers
Your sytem is going into protection power regulayor ic needs to be renewed
Posted on Dec 12, 2006
SOURCE:
No Disc
The drive needs repairs, or replacement. Check your warranty you may still have it and in that case you will most likely get free repairs.
Jun 28, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Why can't I play burned dvd's in my system?
http://www.p4c.philips.com/files/h/hts3410d_37/hts3410d_37_dfu_eng.pdf
What's on them?
Page 22 describes what will paly on it but it assumes certain standard formatting and files and finalization. (Page 37)
Feb 26, 2011 | Philips HTS3410D/37 700W DVD Home Theater...
I have purchased a new Philips DSP 3300 hometheater. I have installed the same. However I have not connected the DVD player to the TV and have not changed its factory setting. Its conencted as is from the...
i have purchased philips dvd and philips home theater 5.1 3300w model. how to connet to the home theater to dvd and tv. because i miss my home theater manual book.
Oct 06, 2010 | Philips Audio Players & Recorders
I have a HTS3410D Home Theater system. I cannot
a blinking or pulsing power light usualy means a problem with the power supply. Check for burned resistors or swallen capacitors on the power board it will be the one with the one with the main power running to it.
Nov 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Black and white
Unplug the home theater for about 2 minutes, and see if the default color has been reset once you replug it.
Mar 23, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Dvd player won't stay on
your unit sir or maam, it has a deffective parts you need to replace the parts the two channel of the power output ,because this parts is shorted,you need a good technician to fix it. and buy the parts to replace it
kira_ryuk99@yahoo.com
Jan 11, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Philips HTS3410D home theatre system. DVD is stuck inside - won't play, won't open. any ideas?
Power off the system
Unplug the power cord
Wait 5 minutes
Plug back the power cord
Power up the system
Press the open/close button
Load a DVD and play
If the tray still will not open, the cover will have to be removed and manually operated. You may have to have a technician look at the unit.
Please rate this solution - Thanks
Dec 27, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Philips HTS3400/37B System Logo
996 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
